Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 08-02-2010, 09:45 AM   #1
ValpoFz
Member#: 228126
Default Starter troubles? not starter, now what?
Wifes car a 06 Saab 9-2x, was fine. She drove it to the store and it wouldnt start when she left. I tried to jump it no good, it acted like a dead battery. My son and I was able to push start it and drive it home. I pulled the battery and took it to Autozone and had them test it, everything passed. So i pulled the starter and took that down to be tested it passed, but the gear didnt initially draw back into the house after the voltage was removed. A little oil solved that.
We re installed the starter and it still doesn't start, nothing, I tried to get a voltage reading at the starter solenoid on the lead from the ignition switch and couldn't get a reading.
I am thinking ignition switch? These arent cheap parts so does any have any ideas before I start switching them out.
Thanks
Ed
**update**
I put the starter back in and fed power to the ignition power in on the solenoid, guess what? It started. So it is either the ignition switch or the clutch safety switch, how should I check these? Is there a fuse that I am missing? There is no voltage at the yellow wire to the starter even with the clutch depressed. Can I bypass the safety switch?
ValpoFz is offline   Reply With Quote
Old 08-02-2010, 10:02 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Check the starter safety switch on the clutch pedal. It could be bad, out of adjustment or the floor mat could be preventing the pedal from going down far enough to activate it.
Old 08-02-2010, 02:14 PM   #3
ValpoFz
Member#: 228126
It is the clutch safety switch, can I just by pass that and leave it that way long term?
Old 08-02-2010, 02:33 PM   #4
talvai
Member#: 136358
2006 WRX Limited
6mt/5x114/vf43/S204
My clutch switch just died on me too. To test that just unplug it(top one, as their is 2 there). Put paper clip between the pins and done. If you want replace the switch its like $17 from subaru or just leave the paper clip there.Been doing that for a while. Won't need clutch to start car but don't forget when you leave it in gear though.
talvai is offline   Reply With Quote
Old 08-02-2010, 03:56 PM   #5
Tahoe SC
Member#: 131996
2006 CGM WRX Wagon
Yimi Tuned 296AWP/322TQ
mine failed on my as well. I just took it apart, bent the internal clips so that it has more tension and it's been working fine ever since.
Tahoe SC is offline   Reply With Quote
FS (OH): 07 STi starter, JDM v7 STi starter coolblue05 Engine/Power/Exhaust 19 09-01-2009 10:07 PM
push button starter trouble (zerosports) Rickyh Electrical & Lighting 16 08-23-2007 07:45 AM
Q's Trouble with catch can Extreme trouble moorebl Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 01-24-2007 08:37 AM
Can a remote starter ruin the starter motor? Please Help! big67 Car Audio, Video & Security 4 12-21-2005 09:15 AM
('93-'01) My starter mototr fell off! smallschip Impreza Forum 4 04-28-2001 06:26 PM
