Old 08-02-2010, 11:15 AM   #1
ericsson
Member#: 208672
2013 WRX STI Limited
Obsidian Black
Angry Cleaning TMIC - citrus engine brite fail
With the exception of intercooler, the engine bay is clean. I read about how is better to use Citrus based degreasers for the engine. It did a really good job, but it did not clean the intercooler. So I decided to use simple green to clean the intercooler, and it didn't work.
So then I decided to try pressured water. I read about the how one should avoid the use of pressured water, but it used it anyway. Tried simple green with pressured water.. nothing.. and the citrus degreaser along with pressured water.. nothing again...
Can anyone suggest a good chemical to clean the IC w/out having to remove it?
ericsson is offline   Reply With Quote
Old 08-02-2010, 11:17 AM   #2
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
maybe try some neverdull aluminum polish, pics of what you are trying to clean off the intercooler?
06HAWKMAN is offline   Reply With Quote
Old 08-02-2010, 11:18 AM   #3
vms150
Member#: 172917
2004 WRX
vms150 is offline   Reply With Quote
Old 08-02-2010, 11:20 AM   #4
ericsson
Member#: 208672
Obsidian Black
Originally Posted by vms150 View Post
The IC in this thread was removed from the car....
Old 08-02-2010, 11:29 AM   #5
SebassScoobie
Member#: 222428
2004 wrx
mmmm java
ive heard gasoline. from a couple people too. idk if this is correct or not. havent really searched it.
SebassScoobie is offline   Reply With Quote
Old 08-02-2010, 11:31 AM   #6
EROC263
Member#: 96887
This my be a dumb question but have you tried using a soft brush? Is it not cleaning dirt off or is it just leaving a residue?
EROC263 is offline   Reply With Quote
Old 08-02-2010, 11:31 AM   #7
BlackJavaPearl04
Member#: 198522
98 LGT Limited
00 LGT -WRX swap
Its not hard takes about 5 minutes to remove...
BlackJavaPearl04 is offline   Reply With Quote
Old 08-02-2010, 11:35 AM   #8
ericsson
Member#: 208672
Obsidian Black
Before taking that route, I'd like to hear if other people have had better results w/out removal of the IC.
Old 08-02-2010, 11:36 AM   #9
ericsson
Member#: 208672
Obsidian Black
I did try a soft brush, but it didn't seem to help. I didn't want to put too much pressure to avoid bending the fins.
Old 08-02-2010, 11:44 AM   #10
T_Racer69
Member#: 188079
2003 Stg 2 Bug Wagon
Sonic Yellow
Have had really good luck with the Black Magic degreaser and protectant. Doesn't leave an oily sheen, but does a great job on busting up grease when I do underhood detailing. Love the stuff. Better than the engine brite foaming crap.
Travis
T_Racer69 is offline   Reply With Quote
Old 08-02-2010, 11:57 AM   #11
ericsson
Member#: 208672
Obsidian Black
Travis
did it leave your IC looking like new?
Old 08-02-2010, 12:07 PM   #12
Davenow
Member#: 23676
I assume you are talking about making the ends look nice and not all grey and dirty.
Pull it out, get some various grit sandpapers, some rubbing compound and some polishig compound. Get some beers, and sit down in front of your TV and polish the end tanks. That is about the only way to keep it looking good, make it too smooth for the dirt to really etch into.
Old 08-02-2010, 12:14 PM   #13
T_Racer69
Member#: 188079
Sonic Yellow
Damn near. I am assuming you are talking about the core, and surrounding areas, since you mention the fins not wanting to get bent. Worked great, and just worked it with a soft nylone bristle brush. The end tanks I would think as Dave said would look great smoothed and polished.
Travis
Old 08-02-2010, 12:17 PM   #14
ericsson
Member#: 208672
Obsidian Black
Travis
Yes, the core... Ok I'll give black magic a try. I should be able to find a soft nylone bristle brush in Walmart right?
Old 08-02-2010, 12:22 PM   #15
BlackJavaPearl04
Member#: 198522
98 LGT Limited
00 LGT -WRX swap
Also did you try some of that engine brite "gunk" stuff? it def works
Old 08-02-2010, 12:24 PM   #16
ericsson
Member#: 208672
Obsidian Black
I went with the Citrus Engine Brite since it's supposed to be better for hoses and plastic in the engine. It worked nicely for the engine, but it didn't clean the IC. Going to give black magic a try...
Old 08-02-2010, 12:45 PM   #17
Cbgrandtheftauto
Member#: 184977
99 Impreza RS
'13 BRZ
Purple Power FTW!!
if it doesnt get it then its not coming off
Cbgrandtheftauto is offline   Reply With Quote
Old 08-02-2010, 12:51 PM   #18
ericsson
Member#: 208672
Obsidian Black
Originally Posted by Cbgrandtheftauto View Post
Purple Power FTW!!
Is purple power available at places such as autozone/walmart?
Old 08-02-2010, 01:12 PM   #19
T_Racer69
Member#: 188079
Sonic Yellow
I think that purple power is one that may be somewhat caustic on alum. Will clean it good, but some cleaners will cause them to get a slight oxidation film on them from the cleaners active cleaning agents if they aren't nice to alum.
Travis
Old 08-02-2010, 03:50 PM   #20
ericsson
Member#: 208672
Obsidian Black
in that case i think i'll stay away from purple power..
Old 08-02-2010, 04:25 PM   #21
Ruvim555
Member#: 247724
2002 WRX WRB Stage 2
2007 CBR 600RR
Found this..harley guys love that stuff..
http://master-formula.com/Metal%20Polish.htm
Ruvim555 is offline   Reply With Quote
Old 08-02-2010, 04:41 PM   #22
ericsson
Member#: 208672
Obsidian Black
Have you used that before for your engine?
Old 08-02-2010, 05:36 PM   #23
T_Racer69
Member#: 188079
Sonic Yellow
That is a polish type product. Meant for bringing metals to a nice shine. If you are trying to clean up the engine bay, you want a good degreaser, and some 303 to wipe the plastic and rubber down. Make it look great without the cheap armor all shiny look.
Travis
Engineering that wins and engineering that fails Yoo Shin Off-Topic 44 02-14-2009 09:08 AM
Cleaning TMIC core.... txl146 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 09-25-2008 10:53 PM
NJ Inspection-Check Engine Light = Fail But What About ABS Light? ScoobyNubieToo! Tri-State Area Forum 2 05-30-2007 12:56 PM
Oil starvation cause the engine to fail garboplateNY88 Built Motor Discussion 8 01-05-2007 04:38 PM
CT: Garage cleaning-TMIC,td04,car audio dirtyhartland Private 'For Sale' Classifieds 2 05-28-2006 02:23 AM
