Old 08-02-2010, 03:58 PM   #1
greanie
Member#: 194581
2002 Imp. Outback Sp
Default Differential or CV joints or what?
My 2002 Impreza Outback Sport (180k on odo) has developed an intermittent problem. When making a sharp turn at low speeds, it doesn't roll smoothly. It feels as if something gets caught in the gears that the car has to over come. It's as if it has developed a limp!! At first, I thought something like a ball joint was loose and something was rubbing, but everything is tight and nothing seems to be rubbing.
It doesn't do it every time but probably 50% of the time. It will do it with the clutch engaged as well as when driving but only at low speeds (at least for now). If I drive for a while on the highway (1 hr +), it will have a good chance of doing it when I pull into a parking spot. If I drive on windy hills, it seems to do it less.
I figured it was a CV joint. Seems to me like those work hardest when turning sharply. However, a friend of mine told me it was the differential. I don't really know what kind of differential my Subie has but I guess it has to work harder too during sharp turns too.
Any ideas?
greanie is offline   Reply With Quote
Old 08-02-2010, 09:15 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
Almost sounds like a center diff, but you'd be better off asking in the tranmission/driveline forum.
New CV Joints or just CV Boots??? hellraiser Service & Maintenance 7 02-02-2010 11:07 AM
cv joint or bearing bad? newanda1 Brakes, Steering & Suspension 4 08-21-2006 12:01 AM
Left Rear Noise CV joint or wheel bearing? RickV Newbies & FAQs 3 11-12-2005 08:52 AM
Problems: Wheel bearing or CV joint or... Help! Strider Tri-State Area Forum 8 03-27-2003 09:38 AM
Help! Wheel bearing or CV joint or something else? Strider Brakes, Steering & Suspension 0 03-26-2003 09:26 AM
