Old 08-02-2010, 03:07 PM   #1
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
Default Turn signal kills cluster
another weird problem
sometimes, when I engage turn signals, my cluster glitches for a second - RPM needle drops, then comes back again
as the turn signal continues to work, everything is fine, it's just for this first second
a short somewhere?
Hyper is offline   Reply With Quote
Old 08-02-2010, 03:57 PM   #2
Notnice
Member#: 116554
06 founding member
of Tom Banks Hanks
a short somewhere
Notnice is offline   Reply With Quote
Old 08-02-2010, 08:28 PM   #3
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
The trouble may be due to a bad ground to the dash area. Running a ground jumper to a known good ground point will eliminate that possibility. The trouble could also be due to a faulty power connection to those things. It's not a short problem.
Old 10-06-2011, 09:28 PM   #4
tbssubaru
Member#: 200058
2004 Forester XT
my 2000 outback is doing this, did you ever find a fix ?
tbssubaru is offline   Reply With Quote
Old 10-07-2011, 03:15 AM   #5
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
yes, I stopped using my turn signals
there are three possible causes that I see
1. I did a retrofit which involved HID kit and rewiring headlights completely
2. I changed the lights stalk, but I believe I put old one back
3. I moved my battery to the trunk
Old 10-07-2011, 08:02 AM   #6
BlackJavaPearl04
Member#: 198522
98 LGT Limited
00 LGT -WRX swap
a short somewhere?
mine has a bit of an issue as well... when the head lights are on and i use the turn signal it flickers the head lights and gauge cluster lights...i can hear the relay click on and off under the glove box...Im guessing its the headlight siwtch, must be corroded or worn. Im going to replace the whole thing...you might have the same issue
BlackJavaPearl04 is offline   Reply With Quote
Old 10-07-2011, 11:15 AM   #7
Cougar4
Member#: 53443
Winestone
Replacing the headlight switch won't fix the trouble. The problem is due to either a resistive connection to power or ground, most likely ground. I suggest you try cleaning the grounds under the hood first. Start with the battery to chassis ground.
Old 10-07-2011, 12:38 PM   #8
tbssubaru
Member#: 200058
2004 Forester XT
thanks for the replies so far , i plan to inspect, clean, and maybe try adding a ground wire or two this weekend and trying a fresh battery
Front turn signal, brake light, and running light won't turn off Floor it Electrical & Lighting 0 06-27-2009 10:34 PM
Electrical help? 1995 Civic EX - no gauge cluster, turn signals, reverse lights... Dennis ex24 Off-Topic 1 04-24-2006 03:03 PM
Turning the side marker light into a turn signal romanom Interior & Exterior Modification 3 03-20-2002 08:48 AM
Prices for clear rear turn signal clusters Bassem Legacy Forum 1 01-17-2000 07:39 PM
