Old 08-02-2010, 05:42 PM   #1
HKS Subaru
Member#: 253765
2004 Sti
WR Blue
Default Plz help me fix my header problem
i have a 06 2.5i i bought an obx equal length header and test pipe now the car is ****ting the bed with check engine lights (bad o2 heater, bad high and low circuit reading and they keep coming up right after i clear the codes) i need a inspec. sticker last month so i wanted to change my equal length obx header set up to a borla rep uel headers, stromung high flow cat and a o2 spacer does anyone know where i can find this stuff for a 06 impreza...
HKS Subaru is offline   Reply With Quote
Old 08-02-2010, 06:13 PM   #2
razrielle
Member#: 205698
Read the exhaust thread thats a sticky, useful info, you will be very lucky to not get cel lights without a tune
razrielle is offline   Reply With Quote
Old 08-02-2010, 07:22 PM   #3
flightwatch
Member#: 231058
2015 F-150
Heck, I'm tuned and I still get the cel's. I had the P2096 code...got rid of that...I then had a P0000 code which magically went away, and now I'm getting a P0037 every other time I start my car. An OBDII scanner becomes your best friend after a header install. The o2 spacer does nothing for 05 and newer cars. The best way to kill the random cel's is to have a tuner on speed dial.
flightwatch is offline   Reply With Quote
Old 08-04-2010, 06:21 PM   #4
GrundleJuice
Member#: 165749
P0000 is the ready code, it goes away when there is a DTC for something thats actually wrong. HKS and flightwatch, on your 06, the only code you "should" get if the front O2 sensor is working correctly AND the headers were installed correctly is the P0420 cat efficiency code. The other codes you have are not a result of the cat itself. either the O2 sensor is toast, was damaged during install (guess that would count as being toast, too) or the headers have a leak.
The best way to kill random CEL's is to know what your doing before your waist deep in it. I'm not saying that to be condescending and sound like a snob, just to say that there is more to header swaps than swapping the parts themselves.
Old 08-04-2010, 06:28 PM   #5
Chi_San
Member#: 53558
2005 Baja Sport
Gray/Silver two tone
You could warp your exhaust manifold using manifold wrap. You could coat it using ceramic coating.
And, there's the option to get a Wideband O2, replace the front O2 with it (if that is the one giving you problems), and use a Wideband controller that will allow you to plug that into the computer where the stock front O2 originally plugged in, and it should read properly.
Chi_San is offline   Reply With Quote
Old 08-05-2010, 07:16 PM   #6
GrundleJuice
Member#: 165749
Last I heard, this was not possible on the 32 bit ECU's. I wanted to do the same but it was impossible when I looked into it.
Old 08-05-2010, 09:02 PM   #7
kewlboxer2
Member#: 161322
06 2.5i
Regal Blue
Yes it is impossible. The LC-1 only gives voltages as feedback. ECU looks for amperage to read AFR.
kewlboxer2 is offline   Reply With Quote
help me fix my stupid headlight problem... scoobyi Electrical & Lighting 4 12-13-2009 09:22 PM
Help me fix these ej20g problems! JDMFLCL Pre-2002 Factory Turbo Powertrain 12 12-17-2008 11:35 PM
some plz help me with my power FC knight2.5 Pre-2002 Factory Turbo Powertrain 0 04-04-2008 08:00 PM
Help me fix my electrical problem JohnGalt00 Electrical & Lighting 0 01-28-2005 07:38 PM
help me fix my cel problem Dr. J Service & Maintenance 0 06-10-2003 10:42 PM
