Vancouver Impreza Club
Go Back   NASIOC > NASIOC Chapters > Vancouver Impreza Club Forum -- VIC > VIC Vendor Classifieds
Closed Thread
Old 08-02-2010, 11:18 PM   #1
dalesalignment&brake
Vendor Sales Rating: (47)
Member#: 173316
'13 BRZ
We are the Canadian Distributor for Racecomp Engineering
RCE Yellows for STI and WRX will be here very soon, ETA 2wks.
RCE Yellows(GR chassis) should be here very soon, '08+WRX Bilstein/Yellow spring packages should be here very soon also.
Still taking deposits-very popular and I only have 30 sets alotted at intro-pricing:
1) RCE Yellows for the GRB('08+STI)
Teaser pic courtesy of Myles at Racecomp Engineering
'08+WRX Bilsteins/Yellow springs-shocks are in transit from Germany, springs will be here in two weeks.
3) I also have GD('04-06 STI, *'07 STI) and GRB('08+STI) swaybars coming-pm or email to pre-order, these swaybars are very popular.
RCE swaybars are here!!!!!
Racecomp Engineering 25mm Swaybars for STi (2004-07)- pm for pricing
The Racecomp Engineering swaybar set will work well with stock springs, lowering springs, or coilovers. The settings for the front bar are 25.5 and 28.5mm. The settings for the rear bar are adjustable from 25.5, 27.0 and 28.5mm. You can run these and not have to go to a bar that is actually 27mm thick. 25.5mm physical diameter. 4142 Chrome Moly Heat treated and cold finished. Ends are hot forged on a 125 ton press. Includes polyeurathane bushings and lube. Washer tabs on front and rear to prevent walking.
Racecomp Engineering GR Sway Bars-
pm for pricing
[center][/CENTER[/url]]
These front and rear 25mm hollow 2 position adjustable swaybars are a must have for your 2008 and later Impreza STI. Featuring carefully chosen swaybar rates and a tubular design, these swaybars weigh less than other solid bars with a similar stiffness.
Racecomp Engineering GR Sway bars for the 08+ STI. Rear bar will fit the 2008+ Impreza / Impreza WRX.
Pm/email for more info
Bilstein Struts-GH chassis '08+WRX
Finally something available for the '08 WRX where you don't have to break the bank.
Bilstein struts will transform your WRX into a cone eating monster when matched to a set of RCE Yellow springs.
Details:
Front:
Monotube, Gas, inverted struts.
NON DAMPING ADJUSTABLE.
For use with OEM springs or lowering springs and top hats.
Rear:
Monotube, Gas, shock absorber.
Adjustable sir CLIP for + 10 or -10mm rear height.
For use with OEM springs or lowering springs.
Shocks will come with dust covers and be powder coated.
Racecomp Engineering Parts List
Coilovers
GR Chassis Clubsports- $2,370US pm for pricing.
GH/GE Chassis 08+ WRX non-STI-$1,995US pm for pricing
GD Chassis-$2,275US pm for pricing
Tarmac 1 Coilovers for 05-09 Legacy $1,675US pm for pricing
Tarmac 0 Coilovers for 02-07 Impreza $1,775US pm for pricing
Sway bar Solutions
04-07 STi Sway bars Front or Rear-$219US pm for pricing
08+ STI Sway bars Front or Rear-$229US pm for pricing
Spring Solutions
Yellow 04-07 STi $339US $375Can
Black 04-07 STi $339US $375Can
WRX Wagon 04-07 $339US $375Can
08+ Regular Guy STI $359US $395Can
Mounting Solutions
Introducing the first in an all new line of parts from GTWorx, the sister company of Racecomp Engineering. Drawing upon the extensive chassis design knowledge and experience that comes from designing several suspension and brake components with RCE, GTWorx is proud to announce their Camber Adjustment Pillowball Mounts for 2008+ Subaru Impreza GR chassis and 2005+ Legacy. These camber plates are currently intended for coilovers only, however, testing is underway for use with OEM style fixed perch struts.
Key features of these new front camber plates include a very low stack height, which means that these top mounts are non-raising at most camber settings. For a coilover at a given ride height, the user will have MORE bump travel with the GTWorx plate when compared to most other currently available plates on the market which raise the car substantially.
In addition, +.8 degrees of caster are built in to the camber plate, which helps minimize dynamic camber loss in a turn for the camber challenged Impreza chassis.
These lightweight alloy camber plates use the same high quality PROVEN pillowball bearing used in the popular Racecomp Engineering Camber Plates, which are known for smooth, long lasting, and quiet operation. Hardware is zinc coated stainless steel. Each bearing is rated at 37,000 lbs radial and 7,730 lbs axial force.
A fact worth noting is that the relatively straightforward and simple design means that these durable plates are available at a realistic price much cheaper than the popular Racecomp Engineering camber plates.
To be used with coilovers
GTWorx GR front camber plates $389US $428Can
GTWorx GD front camber plates $359US $396Can
GTWorx GD rear camber plates $359US $396Can
Brake Cooling Solutions- in stock
Kool Brake Kit GD STI $399US $449Can
Kool Brake Kit GR/2010 Leg.TBA
GTWORX by BILSTEIN
2008+ GH Impreza and WRX shocks $999US pm/email for pricing
[/SIZE[/url]]
[size=3]We have Whiteline parts in stock for all make/model years of Subaru
Search here for your vehicles part#- http://www.whiteline.com.au/index.php[/SIZE[/url]]
Strut top-camber/caster adj MOTOTSPORT KCA255M
Anti-lift/caster kit - lwr c/arm KCA359
Anti-lift/caster kit COMFORT KCA362
Anti-lift/caster kit RACE KCA359M
Brace-strut tower alloy adj KSB554
Brace-strut tower alloy adj KSB599
4 point Brace-Lower control arm KSB723
Brace-strut tower alloy adj KSB568
Subframe lock kit KSB750
Front of rear diff support lock KSB751
Gearbox positive shift kit W0584
Gearbox positive shift kit-MOTORSPORT W0584M
Heavy duty steer rack mounts KSR202
H/duty steer rack bushes KSR206
H/duty steer rack bushes KSR207
Roll-centre / bump-steer adjust kit KCA313
Camber adj kit-control arm upper bushes KCA326
Anti-lift/caster kit - lwr c/arm KCA334
Anti-lift/caster kit - lwr c/arm KCA334M Race
Strut top-camber/caster off-set KCA335
Sway bar link conv kit - extra h/d alloy KLC26
Sway bar link-bushed allow link KLC32
Swaybar link kit-spherical rod end KLC39
Swaybar link kit-spherical rod-end KLC066
Swaybar link kit-spherical rod end KLC047
Anti-roll link kit- h/duty adj ball link KLC139
Swaybar mount-h/duty kit KBR20-22
Swaybar mount-h/duty kit KBR20-24
Swaybar 22mm-h/duty Blade adjustable BSF12Z
Swaybar 22mm-h/duty Blade adjustable BSF30Z
Swaybar 22mm-heavy duty BSF30
Swaybar 24mm-X heavy duty Blade adjustab BSF30XZ
Swaybar 22mm-h/duty Blade adjustable BSF33Z
Swaybar 24mm-X h/duty Blade adjustable BSF33XZ
Swaybar 24mm-X heavy duty BSF33X
Swaybar 24mm-X h/duty Blade adjustable BSF36XZ
Swaybar 27mm-XX h/duty Blade adjustable BSF36XXZ
Swaybar 22mm-h/duty Blade adjustable BSF39Z
Swaybar 22mm-heavy duty BSF39
Swaybar 24mm-X heavy duty BSF39XZ
Swaybar 22mm-h/duty Blade adjustable BSR33Z
Swaybar 22mm-heavy duty BSR33
Swaybar 24mm-X h/duty Blade adjustable BSR33XZ
Swaybar 22mm-h/duty Blade adjustable BSR36Z
Swaybar 24mm-X h/duty Blade adjustable BSR36XZ
Swaybar 24mm-X heavy duty Blade adjustab BSR37XZ
Swaybar 27mm-XX h/duty Blade adjustable BSR37XXZ
Swaybar 20mm-h/duty Blade adjustable BSR49Z
Swaybar 22mm-X heavy duty Blade adjustab BSR49XZ
Swaybar 24mm-X heavy duty Blade adjustab BSR49XXZ
If you do not see a part # listed pm/email for availability
I will match price with any Canadian vendor-just forward me a valid quote
dalesalignment&brake is offline
Old 08-03-2010, 12:09 PM   #2
j y
Member Sales Rating: (7)
Member#: 8829
GRB STI
My car is ready when you are...!
j y is offline
Old 08-03-2010, 04:16 PM   #3
HRCboy
Member Sales Rating: (4)
Member#: 167075
08 STI & 999R
Wayne has his sway bars installed... just waiting for your yellow GR shipment
HRCboy is offline
Old 10-08-2010, 09:33 PM   #4
GTWORX.com
Vendor Sales Rating: (10)
Member#: 97303
2009 WRX and Boxster
Gray and Black
We would like to extend our sincerest apologies to the 9 customers of GTWORX and the 10 of Dales Alignment (Canadian distributor for GTWORX/RCE). We haste fully unloaded front shocks after waiting over 95 days longer than the original due date and in the process we discovered that the last large 6x6’ palletized box was very low in quantity leaving us basically short on product. This was after we had processed and shipped many sets to GTWORX customers days prior. None the less Bilstein was contacted and are now producing the remainder of the fronts we need to fill these back orders with a date of October 22 and shipping DIRECTLY to GTWORX.
In the initial batch we did ship a set of shocks to someone in Canada who was one of the first to pre-order back in November of 2009. At that time Dales Alignment was not ordering from GTWORX and so his order was taken by us. So it made sense that his order was shipped in the initial batch within the first couple of days of receiving the front shocks.
Around that time that owner also had the misfortune of blowing his motor and decided to sell his shocks on the open market. A few of you who have ordered from Dales Alignment may have seen this set for sale and felt that this client had purchased from Dales and that is NOT the case.
So again, apologies to the 9 GTWORX customers who were effected and the Dales Alignment customers who were affected.
On a side note all of the “second batch” people will have their orders filled in this next shipment that is being manufactured on October 22. And that date is the date that Bilstein is saying this next batch will be produced by.
We very much appreciate the patience demonstrated by the initial group that ordered AND the others who were shorted this time around.
GTWORX
__________________
512 Shaw Ct, Suite 104
Severn, Maryland 21144
GTWORX - 410-846-5633
- BILSTEIN- Cobb - WHITELINE- Kartboy - KW - AST - STOPTECH - SPARCO-JRZ
GTWORX.com is offline
Closed Thread
How competetive do you think the '06 WRX will be in D Stock? RS_Racer Autocross 1958 04-01-2010 09:08 AM
New brake packages for STi and WRX! Cusco Bars in stock! Gruppe-S Suspension/Brakes/Handling 11 04-07-2006 08:15 PM
06 STI and WRX AccessPORTS ARE IN STOCK! Free Installation! P&L Motorsports Inc. Mid West Subaru Owners Club Forum -- MWSOC 2 12-06-2005 06:36 PM
2006 Subaru WRX will be in my driveway. Turb0Fr0gWRX General Community 101 03-26-2005 01:21 PM
Weasel will be in Tampa soon !!! Weasel 555 South East Region Forum 13 11-15-2002 10:19 AM
