Old 08-03-2010, 01:27 AM   #1
Speedwagon
Member#: 19681
1998 Legacy Wagon GT
Green
Default Impreza is going crazy
1997 Impreza Outback 2.2L 4EAT
Tonight is the second time this has happened to this car. The first time was about 2-3 weeks ago. Both times it was rainy weather.
While driving, the car suddenly starts bucking, RPMs going up and down. At highway speeds, I end up slowing down because of this(the engine can't keep it at highway speeds). Both times, I pulled over and the engine stalled. As soon as I restarted, the AT Oil Temp light flashed at me(both times), and the engine stalled again. Eventually, the engine restarted and stayed running. After the first time this happened, the car sat for a few days and then seemed perfectly fine, but it did throw a CEL, which I pulled and it was a MAF code. This time, the CEL isn't on.
From searching, I've run across some threads that indicate the MAF sends some signals to the TCM to control the shifting, which might be why I'm getting the ATOL flashing? Would all this indicate a MAF going bad?
Speedwagon is offline   Reply With Quote
Old 08-03-2010, 02:03 AM   #2
Back Road Runner
Member#: 60082
2004 Forester STI
Old car, first check for corrosion. Clean up the battery connections, all the main grounds, and look for corrosion elsewhere. For example, when I got corrosion on my + terminal on the battery, I saw just as much corrosion build up on the knock sensor...which eventually malfunctioned.
The MAF is an obvious problem and will cause major running issues like you see. Just because it isn't throwing a code doesn't mean it is working properly. Clean the MAF.
A secondary main sensor used to control car operation is the air/fuel sensor in the exhaust before the cats. This is another one of those sensors that as it goes bad it starts causing some pretty crapping running.
Both of these sensors won't immediately throw codes. Typically the car will be running pretty darn bad as you've found out before you really even get a code to show up. I just tossed in the air/fuel as sort of a watch item. Your car's been using it for quite a while and it's one of those that will eventually start fouling out, especially if you're starting to burn some oil. It's not a sensor I feel is actually your problem right now. I'm just tossing it out there as one to look at in the future when the car starts to act goofy in a different way.
Old 08-03-2010, 10:09 AM   #3
yellowrs
Member#: 211754
1995 impreza 2.2L
sunburst yellow
check and make sure there is no water getting into the air filter my car did what ur saying it would buck and feel like its dieing and then if you stoped it would die but it would only happen when it rained
yellowrs is offline   Reply With Quote
Old 08-03-2010, 11:37 AM   #4
Qman
Member#: 964
'95 work in
progress
I second the MAF. Clean first, replace second!
Qman is offline   Reply With Quote
Old 08-04-2010, 09:38 PM   #5
Speedwagon
Member#: 19681
Green
Thanx for the advice!
Old 08-05-2010, 07:10 PM   #6
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
First, chk the connectors for the MAF and O2 sensors for damage, corrosion and moisture. If it only happens when it rains, it may be some water causing problems in the connectors. This would be the easiet thing to do, may be free to fix and would save you lots $ if you dont have to replace any parts. Wouldnt hurt to spray some moister repellent on the connectors, too. like WD-40 or Corrosion X or silicone dielectric grease. If you use something else, make sure its safe for electrical connections.
my cable modem is going CRAZY! nhluhr Off-Topic 12 07-11-2004 02:31 PM
my automatic WRX is going crazy brian1wrx Transmission (AT/MT) & Driveline 21 06-17-2004 11:08 AM
Help!, My wastegate is going CRAZY! mrubino83 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-11-2004 06:22 AM
AIM is going crazy.... 2k2 Off-Topic 21 05-09-2004 09:52 AM
Knocklink is going crazy with tune, i think its a pos Turbo Tin Can Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 55 07-17-2002 07:10 PM
