Welcome to the North American Subaru Impreza Owners Club Monday October 24, 2016
Old 06-18-2002, 09:54 PM   #1
Member#: 2301
Default Pro ECM and aftermarket turbo
I did a search on this. I haven't found much. I was wondering if anyone was running this setup on their cars. Would this work well? How confident would one be running one of these with a aftermarket turbo setup? What about on a daily basis? Any info would be appreciated.
RS_NW is offline   Reply With Quote
Old 06-18-2002, 10:08 PM   #2
Member#: 1903
2000 2.5 RS-T coupe
T3/04 Link'd 2 10 PSI
The Pro ECM will clamp the voltage on your MAP sensor so when you reach IIRC 4.1 V you wont get a fuel cut. Larry Ganz should know the most about the Pro ECM and turbo because thats the setup he is running. Just wait till he jumps on this thread. Plus you are going to need a whole lotta piggies, you might want to consider stand alone engine management like the LINK II.
ac_gohan is offline   Reply With Quote
Old 06-19-2002, 02:04 AM   #3
Red RS
Member#: 1433
2000 RS
Im running this setup right now.
Id recommend a J&S safeguard too.
However the chip works alot better than the crappy zener diode included with my ludespeed kit. I also noticed that the car runs and idles smoother after the chip.
Red RS is offline   Reply With Quote
Old 06-19-2002, 05:15 AM   #4
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
I ran the ScoobyRacing Torque chip for a year with my turbo kit (like the ProECM), and then this January I swapped in a ProECM adjustable MAP voltage clamp (from their powerchip).
It works great. I was running 12 psi today with only 6 degrees timing retard using an ITC on 93 pump gas (at 6,000 feet elevation) in 85 degree weather.
[edit - pesky typos]
ImprezaRS dot com is offline   Reply With Quote
Stock and Aftermarket Turbo PJPerformance Engine/Power/Exhaust 11 11-09-2008 06:50 PM
WTB turbo legacy ecm and sti spare tire serious Private 'Wanted' Classifieds 0 06-26-2006 03:39 PM
FS: Pro ECM Torque Chip and JDM Clear Tails SSLegacyGT Legacy Forum 27 07-25-2003 03:22 AM
Perfect description of Pro ECM chip Dolphin Overton Normally Aspirated Powertrain 28 03-03-2002 08:01 PM
pro ecm, torq chip II ???? synapse79 Normally Aspirated Powertrain 3 01-22-2002 02:17 PM
