Old 08-03-2010, 03:12 PM   #1
wrxwagon1992
Member#: 208475
2002 wrx wagon
aspen white
Default How to replace a Broken CV Joint Boot
Hello, like the title says im looking for instructions on how to replace a broken cv joint boot.
Thanks
wrxwagon1992 is offline   Reply With Quote
Old 08-03-2010, 03:24 PM   #2
Haelan
Member#: 151045
2013 Subaru STI
CBP
You'll need to remove the axle to replace it. If you're unsure the amount of wear on the CV joint that has already occurred you'll want to replace the whole axle anyway.
A mod needs to move this thread to the Transmission & Driveline forum...
Haelan is offline   Reply With Quote
Old 08-13-2010, 04:38 AM   #3
atomicfire
Member#: 136296
2005 STi
Mine was torn, I had my dealership reboot it. Unfortunately, it requires a lot of disassembly to get to the cv boot. I think I wound up paying around $250 to get it done, including parts.
atomicfire is offline   Reply With Quote
Old 08-13-2010, 07:26 PM   #4
feint05
Member#: 152984
2004 jewbaru
jewbuilt, polish tuned
Dammit Nooo Its Childsplay Really, I Will Make A Thread Next Time I Do It Im Sick And Tired Of People Buying Crappy Repros And Getting Ripped Off Because They Are Afraid To Give It A Try.
Remove Springpin From Axel
Disconnect Lower Ball Joint
Remove Axel Nut
Remove Axel
Ignore That I Have Caps Lock On And Cant Spell Axle
Now That The Axel Is Out Of The Car Cut The Straps Off And The Boot Off
Inside The Green Housing There Is A Large C Shaped Spring In A Groove That You Remove, Now You Can Seperate The Cv Joint
With The Cv Joint Seperated There Are 3 Bearings That Only Go On One Way But They Will Fall Off So Keep An Eye On Them Immedieatly And Take Note Of Where And How They Came Off
Clean- I Used Gasoline
Using Snap Ring Pliers Remove The Snap Wring On The End Of The Axel That Secures The Cv Knuckle, Remove Knuckle
Put On Small Side Of New Boot And Band It Back On
Fill Green Housing Halfway With Grease
Put Knuckle Back On And Replace Snap Ring, Put A Little Grease On The Bearings So They Stay Put And Slide The Knuckle Into The Housing, Replace C Spring
Band On Big Side Of Cv Boot And Reinstall In Your Car
Hope This Helps Cause This Was More Than I Had Time For
feint05 is offline   Reply With Quote
Old 08-13-2010, 10:00 PM   #5
wrxwagon1992
Member#: 208475
2002 wrx wagon
aspen white
Thanks a lot man
Old 08-14-2010, 10:11 AM   #6
2milehi
Member#: 81633
'98 RS-T
Remove Axel Nut
Remove Axel
Very annoying to read with the first letter capitalized in every word.
2milehi is online now   Reply With Quote
Old 08-14-2010, 03:55 PM   #7
feint05
Member#: 152984
2004 jewbaru
GOOD
thats what nasioc does when you type in all caps
Old 08-14-2010, 04:07 PM   #8
feint05
Member#: 152984
2004 jewbaru
Old 10-06-2011, 07:49 PM   #9
LsedanMan
Member#: 263092
Does anyone have experience with the bands the come with the Subaru replacement boots? How do you get them nice and tight? I felt like mine could have been tighter when I did my inner boot. The shop manual I have talks about some tool. How do you all do it?
LsedanMan is offline   Reply With Quote
Old 10-10-2011, 03:03 AM   #10
oguitar
Member#: 206720
2002 WRX Wagon
I got a set of pliers and held the long part of the band pulling it as tight as i could. Then I get a screwdriver and used the pliers as a wedge and the screwdriver as a lever. I was able to get the band on nice and tight.
oguitar is offline   Reply With Quote
Should I replace the axle or try to regrease the inner CV joint? leecea Transmission (AT/MT) & Driveline 2 01-27-2008 06:25 PM
what causes CV joint boot to fail VideoGameWrx Transmission (AT/MT) & Driveline 16 02-21-2007 08:06 PM
How to separate inner/front CV joint ? jsteele22 Transmission (AT/MT) & Driveline 2 04-17-2006 11:24 AM
Does anyone have instructions on how to replace a torn cv boot? breathinez Transmission (AT/MT) & Driveline 6 04-03-2005 08:48 PM
CV Joint boot replacement in Chi-town Wacky Mid West Subaru Owners Club Forum -- MWSOC 1 09-14-2004 04:53 PM
