Old 06-19-2002, 01:04 AM   #1
jmott
Member#: 6713
2007 Prius
brown
Default USA's most powerful WRX!!
Here is the dyno on pump gas, 17psi, with catalytic converter in place:
Here is the dyno on race gas, cat removed, 18psi:
You can read more about the car at http://www.projectcobb.com/conebasher/
Whats impressive, is they weren't even trying, or aware that they were approaching the USA dyno record with this car. They just wanted good low rpm power for autocrossing. When I pointed out to Chris that they were close to the record with that pump gas run, they hit 400 just for fun
that was with the APS SR40 turbo which was maxed out
they say they will slap on the SR50 tomorrow just for fun to see what it will do
oh, for some perspective, check this out:
http://24.160.114.191:8080/power.xls
check the power band compared to some other cars
jmott is offline   Reply With Quote
Old 06-19-2002, 01:10 AM   #2
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
This a track car too, not a drag car. Totally useable powerband that isn't peaky. I think this shows things to come. Also notice that the car doesn't keep making power on the top end (looks like there is a LOT of untapped potential).
Just plain sick. btw,
Texas takes the HP Record!
TypeC is offline   Reply With Quote
Old 06-19-2002, 01:30 AM   #3
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
Very nice - - but its 2.5 Litre - so its a seperate catagory
Looks to me after close examination of the dyno sheets that the sr40 wont spool that great on a regular 2.0 litre block
On a 2.0 - I'd say it would spool up about the same as the pe1820 - - no telling how the peak HP would vary - becuase they have also thrown cams and other tricks in the mix as well
I would really love to see a dyno sheet on that SR40 turbo on a base stock WRX block motor
In conclusion - COBB seems to be doing great work and it shows with the amazing looking cone basher car !
alfriedesq is offline   Reply With Quote
Old 06-19-2002, 01:45 AM   #4
jmott
Member#: 6713
2007 Prius
brown
I see, displacement changes your category.
but not STI motors, FP Green turbos, etc.
seems kinda arbitrary =)
Old 06-19-2002, 01:53 AM   #5
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
Well - - if you look at motorsports - displacement is very commonly used as a limitation - e.g. - group N
I know nothing of 2.5 L turbo subarus - - it looks to be a totally unique animal - certainly very hard to compare spool up times with a 2.0 L
As far as sti motors - its the same 2.0 L
Old 06-19-2002, 01:56 AM   #6
jmott
Member#: 6713
2007 Prius
brown
turbos are also often used as a limitation.
as are restrictor plates
as is type of fuel
and nobody is comparing spool up times here.
the only point here is to declare victory, for now, in the petty and silly war that is WHOOPASSSS dyno records.
silly but fun!
and this is the most powerful WRX in the USA.
and it didn't need fancy STI heads, or intake to do it
but don't let me get to you. im just messing around.
MY car only puts down 250 to the wheels.
Old 06-19-2002, 01:59 AM   #7
In2Deep
Member#: 10651
2013 WRX - Silver HB
04STI(sold) 06STI(sold)
Either way you look at it, those numbers are VERY impressive.
In2Deep is offline   Reply With Quote
Old 06-19-2002, 02:12 AM   #8
wickedwrxwagon
Member#: 18948
UNREAL numbers!!!
Could you let me know what your set-up is I am very interested!!
Gregg
12.20 @ 114
wickedwrxwagon is offline   Reply With Quote
Old 06-19-2002, 04:24 AM   #9
Avedis
Member#: 8171
2005 WRX STi
Blue / Gold
"Could you let me know what your set-up is I am very interested!!"
It's Cobb Tuning's AutoX car.
Read about it here.
--jeff
Avedis is offline   Reply With Quote
Old 06-19-2002, 04:25 AM   #10
Avedis
Member#: 8171
2005 WRX STi
Blue / Gold
I guess I can understand being so excited from the dyno's that you didn't read the text that went along with it in the post. It took me a minute to calm down and climb back up into my chair after seeing the charts.
--jeff
Old 06-19-2002, 04:35 AM   #11
18hrwrx
Member#: 8516
Last I check this forum was to brag about Hp numbers and time slips. What evers in the motor COBB still got the record.
Mike
18hrwrx is offline   Reply With Quote
Old 06-19-2002, 09:55 AM   #12
STi_Pete
Member#: 14576
2002 WRX Sedan
Reason enough for me to get a 2.5 block
STi_Pete is offline   Reply With Quote
Old 06-19-2002, 12:01 PM   #13
dazz1
Member#: 10363
5.9 Turbo Cummins
Just in case some of you haven't seen this beast in person, here is a couple of pics of the ConeBasher in action at a local AutoX.
Some of the TXIC members were fortune enough to ride shotgun in this beast.
dazz1 is offline   Reply With Quote
Old 06-19-2002, 02:23 PM   #14
-=Ph/\t WRX=-
Member#: 9310
2002 Subaru
Thats nothing. I was told that there will be a much more powerful one coming from Cobb. About twice the HP to the wheels.
-=Ph/\t WRX=- is offline   Reply With Quote
Old 06-19-2002, 02:27 PM   #15
jmott
Member#: 6713
2007 Prius
brown
if you are referring to project 666, that wont be a WRX
and no telling what engine is involved
but nitrous is =)
Old 06-19-2002, 02:30 PM   #16
-=Ph/\t WRX=-
Member#: 9310
2002 Subaru
I know its not a WRX, thats why I didn't say WRX. Yeah its going to be on the older body. I'm guessing a flat 6 will be the engine.
but nitrous is =)
Old 06-19-2002, 03:25 PM   #17
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
I wonder why they use the 18" wheels on it. Some 15 or 16" wheels would probably work better for autocross. Unless they are using a different transmission with better gearing or something.
Old 06-19-2002, 03:30 PM   #18
-=Ph/\t WRX=-
Member#: 9310
2002 Subaru
If I remember correctly the tires are 285/30/18 on the front and back! Rims are about 11 or 12" wide.
Old 06-19-2002, 05:32 PM   #19
I am b
Member#: 9341
2000 Landcruiser
2001 Triumph Sprint RS
I hate to say it but I agree with Al. Those are sick numbers and much respect to those guys but it is a 2.5l. It is the most powerfull wrx in the U.S. but i'm not really impressed with the numbers from a car that has that much more work done to it.
Later today or tomorrow you will see why i'm not very impressed with those #'s.
I am b is offline   Reply With Quote
Old 06-19-2002, 06:14 PM   #20
jmott
Member#: 6713
2007 Prius
brown
later today cobb will also have dynos from that car with a BIG turbo on it =)
besides, the car with more work done to it will always win, unless one of the car's tuning is out of whack.
there is no magic in engine output.
Old 06-19-2002, 06:20 PM   #21
I am b
Member#: 9341
2000 Landcruiser
Very true jmott but I think it's really impressive what some cars are doing right now with simple bolt-ons.
west coast will ownz all of you by tomorrow.
Old 06-19-2002, 06:33 PM   #22
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
Those fenders look badass!!!!
djerickd is offline   Reply With Quote
Old 06-19-2002, 06:46 PM   #23
jmott
Member#: 6713
2007 Prius
brown
which cars?
EVORACE1 is making 390hp
but its a lag beast. It would be useless for anything but drag racing
Old 06-19-2002, 07:21 PM   #24
boxerT
Member#: 16311
2004 STi
WR Blue
The Cone Basher does not seem to perform as well on the track as the looks and numbers would indicate.
boxerT is offline   Reply With Quote
Old 06-19-2002, 07:24 PM   #25
jmott
Member#: 6713
2007 Prius
brown
iirc, last year it was the texas SMOD champ, and finished in the middle of the pack at nationals....
we shall see how they do this year I suppose.
mebe we need to let a different Chris drive it....
How/What is most power possible on stock turbo 06/7 wrx? confusedxpanda Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 40 08-09-2007 09:52 AM
most powerful stock WRX? Lysis Proven Power Bragging 65 06-24-2005 09:57 PM
most powerful wrx with stock block and transmission Hot XXX Pics Newbies & FAQs 25 06-10-2005 12:12 PM
Hot off the web - Subaru’s fastest and most powerful Impreza ever – the WRX STi ‘WR1’ Oldalfaguy News & Rumors 61 06-15-2004 01:15 AM
Who has the most powerful, stock ECU, no electronics WRX? BADWRX Proven Power Bragging 25 07-17-2002 10:18 AM
