Old 08-04-2010, 09:41 PM   #1
Lspade
Member#: 245200
Question I haven't rotated my tires in a while, is it safe?
EDIT: Already have new tires installed and will be rotating them following the dealership's recommendations. Thanks for all of the replies.
Lspade is offline   Reply With Quote
Old 08-04-2010, 09:52 PM   #2
AkRsWagon
Member#: 227477
2015 WRX Limited
Galaxy Blue
how does the wear on the tires look
AkRsWagon is offline   Reply With Quote
Old 08-04-2010, 10:18 PM   #3
boost4life
Member#: 75129
09 WRX stg 2+
Lost the boxer rumble
Your suppose to rotate every 7500 miles under normal use.
boost4life is offline   Reply With Quote
Old 08-04-2010, 10:33 PM   #4
Lspade
Member#: 245200
The rubber is really chewed up from driving hard around paved corners.
Old 08-04-2010, 10:51 PM   #5
jesse_r
Member#: 200419
1998 forester
canyon red pearl
wow you could have just screwed your ceter diff to poop man change your fluids and pray to the subie gods that no metal shaving comes out
jesse_r is offline   Reply With Quote
Old 08-04-2010, 11:14 PM   #6
aigochamaloh
Member#: 188167
2016 WRX LBP
2016 Chevy Spark EV
You're not going to see metal shavings from the center diff. That's a sealed unit that goes bad when the silicone based fluid inside wears out from constant overheating and is no longer viscous.
aigochamaloh is offline   Reply With Quote
Old 08-05-2010, 12:29 AM   #7
Lspade
Member#: 245200
hold the phone. why is my center dif turning into poop??? because of what the shop did? or because I haven't rotated my tires and the front tires are probably more worn down than the rear tires which in theory is hard on the dif?
I'm pissed because i've owned only fwd before this car and never rotated the tires. I just wanted to know if it was still safe to rotate them but are you guys saying that I could have f'd something up by NOT rotating them???
Old 08-05-2010, 12:43 AM   #8
Nicklz
Member#: 94096
2003 WRX
Lspade your supposed to rotate your tires every 7500 miles. So it ultimately is your fault the tires are where they are now that it's been 18k miles. Subaru's awd requires that all the tires stay within 1/4 inch in circumfrence, if not the dif can be damaged. This also means that you usually need to replace the tires in sets of 4 at a time, and keep them rotated to avoid being out of spec. It also makes your tires last much much longer.
Without knowing how bad your tires are (you should probably messaure them) it's impossible for us to say if you can actually reuse the tires. You can be optimistic and hope your diff is still okay though.
Go buy 4 new tires.
edit/ here is a good link for you about awd and tire depths
http://www.tirerack.com/tires/tirete....jsp?techid=18
Nicklz is offline   Reply With Quote
Old 08-05-2010, 02:03 AM   #9
stwang314
Member#: 170474
2002 wrx
white
...... if you are still driving around, then your center diff is alright.
My advice is just buy 4 new cheap tires. Or, if you are on a budget, then measure your tire's tread depth, buy 2 tires, and have them shaved down. but considering we do not know what depth your tires are at currently, you could just be shaving tires down and wasting money.
Bottom line: your center diff is alright, buy 4 tires, and post this in the tires and wheels section.
stwang314 is offline   Reply With Quote
Old 08-05-2010, 07:09 AM   #10
NMZ_WRX
Member#: 198280
2007 BLACK MONSTER
WINGLESS
every 7500 miles? what. would rotating / getting an alignment correct diff issues?
NMZ_WRX is offline   Reply With Quote
Old 08-05-2010, 10:12 AM   #11
Joe
Member#: 34694
Some of these people sound overly dramatic. When I had my WRX, I would rotate the tires one time per set of tires if at all. When I sold the car, it had 143k miles and had no issues at all. I would say rotate the tires if it makes you feel better, but otherwise wait until you need new tires, which is most likely soon.
Joe is offline   Reply With Quote
Old 08-05-2010, 06:13 PM   #12
Lspade
Member#: 245200
Ya and the worst part is that I knew that! But I've never rotated my tires in my life so I just seriously didnt consider it until a coworker told me he had to get his tires rotated. Thanks for the link.
Old 08-05-2010, 06:15 PM   #13
Lspade
Member#: 245200
Thanks for the positive reinforcement. I've been stressing over it. AND thanks for letting me know there is a tires and wheels section. I didn't see it when I was looking for the appropriate topic to post under.
Old 08-05-2010, 06:19 PM   #14
Lspade
Member#: 245200
I am anal about scheduled maintenance so as soon as I get some new tires I'll be doing the 7,500 rotation. But it is very good to know that you drove further distances than me without rotating and without problems. It puts my worries at ease.
Old 08-05-2010, 06:40 PM   #15
Lspade
Member#: 245200
K, so I measured the tread depth with a quarter.
The p.f. was moved to d.r.
The d.f. and p.f. are new
The p.r. stayed in the same place
IF the tread has to be off by a 1/4 inch to do damage then I am fine at the moment because the thinnest tread is at most 3/32 off from the thickest tread. However, the new tires have a different tread pattern BUT they say the exact same thing on the tire walls so I'm assuming the tires that were replaced are just a newer version. I hope this doesn't throw off my equation.
Old 08-06-2010, 04:01 AM   #16
Nicklz
Member#: 94096
2003 WRX
yeah your not supposed to mix and match tires either
Old 08-25-2010, 11:50 PM   #17
classicaddict
Member#: 220619
04 wrx wagon
jesus. your worried about your center diff? how ridiculously ironic when you treat the entire car like dog ****. people like you are my job security, you dont rotate tires on an AWD car for 15k miles and wonder.........why did my drive-train implode? after all the threads i have read that you posted, this is literally the least of your worries. how many times a day do you drop the clutch/launch the car?
ha! its not a 1/4inch of tread depth newbie. subaru states there should not be more than 1/8 of an inch differance between any tires CIRCUMFERENCE.
oh, and you should have all the same tires, different tires have different rolling resistance = bad. and why is this in the detailing section?
classicaddict is offline   Reply With Quote
Old 08-26-2010, 10:01 AM   #18
WRBluRex
Member#: 193945
02 Corvette Z06
Torch Red
You can not missmatch tires because not all tires are the exact same size even though they all might say for example 215/45/17. A hankook might be slightly wider then a goodyear or a michilin might be slightly taller then a firestone.Iv witnessed this on my old f-body. I had hankook on my 17x9 wheels that were flush with the wheel. I changed to bfgoodrich and they ended up sticking out slightly past the wheel even though they were the same 275/40/17 size. Subaru states 1/4 inch difference could cause drivetrain damage. So basically you shouldnt have no more then 3/32s difference between all tires.
WRBluRex is offline   Reply With Quote
Old 08-26-2010, 10:14 AM   #19
Lspade
Member#: 245200
The subaru dealership in duluth mn installed the mismatched tires. Since I had only owned the car for a month or so I didn't realize that this was a bad idea or I would have said something.
Old 08-26-2010, 10:26 AM   #20
WRBluRex
Member#: 193945
02 Corvette Z06
Torch Red
That does not make sence that a subaru dealer would do something like that with out telling you this is temporary change your tires soon when all subarus are AWD.
Old 08-26-2010, 11:24 AM   #21
MMWRX
Member#: 175558
1993 Nissan 300ZXTT
1995 4Runner 4x4 5spd V6
How many dealerships have you been too, even Subaru dealers, where no one and I mean no one on the lot or in the shop knew WTF they were doing? Exact reason why I always stand over anybody that does any work on my car, I worked in a shop before and I know its a bitch when the client is standing over you but I am not about to let some ****up dumb**** highschool dropout (hopefully not at the dealer but weirder things have happened) **** up my car.
Moral of the story: Always always ALWAYS inspect your car before handing over the keys and right before they hand them back to you.
OP: hope everything will be cool and no damage was done, if everything is running smoothly now you should be good.
MMWRX is offline   Reply With Quote
Old 08-26-2010, 11:43 AM   #22
ZaQSTI
Member#: 142543
05 STi
I fail to believe that you are a stickler for maintaining your car if you never thought to rotate your tires. You are either too young, uneducated, or both to be the owner of a car.
ZaQSTI is offline   Reply With Quote
Is it safe to douse the calipers with brake cleaner while installed? mmiller2002 Service & Maintenance 14 05-11-2009 08:09 PM
My Pants Just Shrunk - Haven't Been This Amped In A While OriginalSin Off-Topic 35 05-13-2008 10:25 AM
got a lfat, is it safe to replace one tire? chrismindless Tire & Wheel 3 10-10-2005 10:35 PM
Is it safe to switch to summer tires yet? It is March after all... Samirr76 Tri-State Area Forum 38 03-06-2003 09:25 PM
Is it safe to turn my turbo charger up to 22lb livewirevoodoo Newbies & FAQs 29 11-24-2001 12:51 AM
