Old 08-04-2010, 10:00 PM   #1
tavsport
Member#: 204281
2005 wrx
white
Subaru Stars what would happen if you put a sti intake manifold on n/a 2.5l?
i was woundering if there would be an plus in putting on a sti or wrx intake manifold on a n/a 2.5l over using the stock one?
tavsport is offline   Reply With Quote
Old 08-04-2010, 10:23 PM   #2
Back Road Runner
Member#: 60082
2004 Forester STI
You'll lose power. Actually I'm not entirely sure. Chances are you will lose some power though.
Look at two specific things. The intake manifold and exhaust manifold are tools for controling the torque band of the engine, along with the cams and heads. It's all about air flow and optimizing that flow. The two things you look at are the intake manifold runner diameter and the intake manifold runner length. The diameter defines where the optimum scavenging occurs and subsequently maximum torque. The length has to do with pressure wave tuning, sort of like a musical instrument. The length is tuned to a specific frequency and helps optimize power around wherever that length correlates to engine rpm. Realize that the flow should be optimized the same way through the whole engine. This means the intake manifold design matches cam setup, head porting, and exhaust manifold. It's just not the intake manifold alone. You still need to address the rest of the car. You also need to understand if the STI intake manifold is even suitable for the NA engine in the first place. The design may work great on a turbo motor, but you may find that the design is completely inappropriate for any near stock NA engine.
Old 08-10-2010, 07:10 PM   #3
TheNateums
Member#: 243917
2000 Impreza 2.5RS
Sedona Red Pearl
kaboom. JK.
I'd imagine it wouldn't be beneficial in any way...
TheNateums is offline   Reply With Quote
Old 08-11-2010, 08:44 AM   #4
GEE-OTTO
Member#: 201277
2009 Legacy GT
The STi and your 2.5i are both cast aluminum manifolds. This must be a asthetic oriented question so my answer would be take yours off and paint it red
GEE-OTTO is offline   Reply With Quote
Old 08-11-2010, 09:00 AM   #5
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
VHT red wrinkle in spraybomb form works nicely!
LetItSnow is offline   Reply With Quote
What would happen if you put r0bman and Dicmo in a room... alone... Asinine Off-Topic 59 02-22-2011 05:08 PM
What would happen if you put a bird in an indoor skydiving room thing? attitude Off-Topic 31 11-20-2008 06:53 PM
What would happen if you put a negative tip on a restaurant bill? Cjchaps Off-Topic 44 11-14-2007 05:06 PM
what would happen if i put this vf22 on with stock moorebl Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 11-27-2004 11:28 AM
What would happen if I put test pipes on? Supapooh Normally Aspirated Powertrain 3 01-28-2002 06:36 PM
