Old 06-19-2002, 03:56 AM   #1
ScoobieSnaX
Member#: 10844
2004 Acura TL Navi
Pearl
Question What are your Blitz boost control settings?
Just installed my SBC-id today. To confirm, the "OUT" hose goes to the wastegate actuator and the "IN" hose goes to the turbo inlet -correct?
Also wondering if anyone is keeping the stock restrictor?
Most important though.......what is everyone using for the "SET" and "GAIN" settings?
Thanks!
ScoobieSnaX
ScoobieSnaX is offline   Reply With Quote
Old 06-19-2002, 05:38 AM   #2
dgp
Member#: 15593
If you mean the sbc-id, I use a set of 61 and a gain of 15. I have also heard of lower set and higher gain. Like 49 set and 20 gain.
dgp is offline   Reply With Quote
Old 06-19-2002, 09:23 AM   #3
JaMa
Member#: 5206
Default Blitz settings
I have my boost at 66 and gain at 40 with almost exactly the same mods as you. I did find that my FMIC requires more gain to achieve the same boost, so you may want to try lower settings than mine. Plus, I am at altitude so higher boost numbers will achieve less pressure up here.
Cheers
JaMa
JaMa is offline   Reply With Quote
Old 06-19-2002, 12:22 PM   #4
ScoobieSnaX
Member#: 10844
2004 Acura TL Navi
Pearl
Is it possible to control boost based on speed or gear?
Old 06-19-2002, 12:29 PM   #5
NEWAGEWRX
Member#: 8814
Go to the Speed Map Option, This will allow you to base it upon speed, which in theory is also based on gear for the most part.
AKA ~35mph in 1st
~60mph in 2nd and so on
BTW, I have mine set at Set 58/ Gain 18. Max Boost 15.9
Nick
NEWAGEWRX is offline   Reply With Quote
Old 06-19-2002, 12:31 PM   #6
ScoobieSnaX
Member#: 10844
2004 Acura TL Navi
Pearl
The manual indicates this feature is only available if you have the Power Meter-ID....is this true? Mine shows "no connect"...
Old 06-19-2002, 12:40 PM   #7
NEWAGEWRX
Member#: 8814
Default yea
this is true, powermeter required.
sorry
Nick
Old 06-19-2002, 01:49 PM   #8
krave
Member#: 13908
2002 WRX Sedan
296 whp
i have mine set at 13 gain / 53 boost maxing at about 16.5psi
krave is offline   Reply With Quote
Old 06-19-2002, 02:20 PM   #9
ScoobieSnaX
Member#: 10844
2004 Acura TL Navi
Pearl
It seems to be working great now. I've been aiming for about 19psi and I'm getting there.....I hit 18.7 today. A bit more fussing with it and I'll be there.
Thanks!!
what are your tokico d-spec settings? ASpec818 Brakes, Steering & Suspension 7 07-30-2006 06:26 PM
FS: Blitz Boost Controller, Blitz Power Meter, Blitz Mirror Meters D1GP_old Private 'For Sale' Classifieds 5 07-15-2006 12:56 PM
Blitz Spec-s boost controller settings scwrx02 Engine Management & Tuning 1 08-13-2003 07:38 AM
What are your CLB stg 4 settings? bobsterswrx Engine Management & Tuning 3 04-01-2003 10:23 PM
What are your S-AFC settings with Turbo Greg 99 Normally Aspirated Powertrain 2 12-28-2000 06:17 PM
