Go Back   NASIOC > NASIOC Classifieds > Vendor Announcements
Closed Thread
Old 08-05-2010, 12:39 PM   #1
KillerBMotorsport
Vendor Sales Rating: (43)
Member#: 198281
2005 WRX/STi
WRB of course
Default NEW Killer B Motorsport Oiling products - Sneak Peek
Another part brought into the fold here at Killer B Motorsport thanks to the voices of our customer. Prices TBA.
Here are some of the Features and Advantages of the Killer B Motorsport Windage Tray / Baffle over the OEM piece.
• Closed rear section to prevent oil from sloshing into the crank under hard acceleration and aggressive shifts.
• Block contoured profile to minimize oil returning from the heads interfering with the crank.
• Directional louvers prevent oil in the pan from splash/sloshing into the crank.
• Low profile design to control windage and strip oil from the crank immediately to reduce oil “roping” on the crank.
• Improved oil entry to the pan/pickup to help prevent oil starvation.
• Made from stainless steel for long life, durability and corrosion resistance.
Here are some of the Features and Advantages of the Killer B Motorsport Windage Tray / Baffle over other aftermarket baffles.
• Uses OEM baffle mounting locations
• Not a sandwich between pan & block design that is difficult to install and more prone to leak.
• No rubber parts that can sag and stay open after repeated heat cycling.
• Not Holy Cow expensive!
So what’s all this mean? It means more power due to the reduction in oil interfering with the rotation of the crank and allowing it to spin more freely. Unless it’s in the bearings, anytime oil comes in contact with the cranks or connecting rods it robs power. Reduction of oil splashing and beating off crank & connection rods will also lower oil temperatures.
__________________
- Highly Advanced and Full of Awesomeness - Patent Pending
vs.
V2 High Performance Aluminum
Brushed & Polished Delrin Shift knobs!
KillerBMotorsport is offline
Old 08-05-2010, 12:55 PM   #2
FunkDoctorSpock
Member Sales Rating: (1)
Member#: 196559
04 Sti
subject to change.
Does it have anything to do with the transmission?
FunkDoctorSpock is offline
Old 08-05-2010, 01:08 PM   #3
08WRbX
Member Sales Rating: (18)
Member#: 206630
'15 CWP STI
texastrackworks.com
oil baffle - "windage tray"
08WRbX is offline
Old 08-05-2010, 01:17 PM   #4
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
DING DING DING DING DING... We have a winner!!! Good Job!
__________________
vs.
Old 08-05-2010, 01:20 PM   #5
Baay
Member Sales Rating: (2)
Member#: 139645
07 WRX
UGM
How would you compare your design to say the Cossy tray.
Baay is offline
Old 08-05-2010, 01:25 PM   #6
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I'm going to put together all the technical highlights tonight; how it compares to other aftermarket pieces, OEM, and how it will make your car into a piece of superawesomeness
__________________
vs.
Old 08-05-2010, 02:43 PM   #7
cessna152
Member Sales Rating: (5)
Member#: 7523
1999 Impreza 2.5 RS
Oh god, an alternative to the cosworth part.
cessna152 is offline
Old 08-05-2010, 11:25 PM   #8
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Yep
Full features and description added to the OP.
__________________
vs.
Old 08-05-2010, 11:33 PM   #9
monkiboy
Member Sales Rating: (35)
Member#: 202958
2008 wrx
subscribed. eager for a gb!
monkiboy is offline
Old 08-05-2010, 11:42 PM   #10
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
There will be an introductory group buy once we get the manufacturing timeline and costs set.
__________________
vs.
Old 08-06-2010, 09:14 AM   #11
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Product description updated.
This was a response from another forum regarding oil spilling out the side...
I'm working on timelines and costs right now. There will be an introductory group buy.
It's a big misconception that oil starvation is caused by oil spilling out of the oil pan. Can it happen, yes, but it takes extreme conditions to make this happen. Conditions you'd see on a car that was on slicks and dedicated to race track duty. What does cause oil starvation LONG before you ever spill oil up and out the side of the oil pan, is pooling oil in the head that's facing the outside of the corner. You will continue to pool oil in that head until the pickup eventually starves or the corner straightens out.
This baffle is for controlling oil and removing it quickly from the crank area. To prevent starvation a larger capacity oil pan (like our spiffy aluminum oil pan) is a safe bet. It increases the spill out angles and because it holds more oil it buys you more time in the corners nearly eliminating the possibility of oil starvation.
The problem with just adding a baffle that inceases the spill out angle is that it also directs the oil away from the pickup area under cornering load AND inceases the amount of oil that can pool in the outside head beafore it can flow back into the pan.
__________________
vs.
Old 08-10-2010, 02:56 AM   #12
08WRbX
Member#: 206630
'15 CWP STI
texastrackworks.com
Yay!!! So, do I win something for being right?
08WRbX is offline
Old 08-10-2010, 02:02 PM   #13
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Hmmm... have to see what I can think of on that one
__________________
vs.
Old 08-12-2010, 11:20 PM   #14
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
MSRP will be ~$79
__________________
vs.
Old 08-13-2010, 07:55 AM   #15
FunkDoctorSpock
Member#: 196559
04 Sti
subject to change.
Good price as usual......Ready when you are!
Old 08-13-2010, 08:01 AM   #16
TXSubieDood
Member#: 199859
2004 Impreza WRX/STi
AWDTuning delete!
"Reduction of oil splashing and beating off crank & connection rods will also lower oil temperatures."
o rly?! lol
i recently had the killerb oil pick up tube installed...wish this was already fabricated and for sale i would have had it put in at the same time.
TXSubieDood is offline
Old 08-13-2010, 08:54 AM   #17
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
^ Yes it brings down temps... You should google it.
__________________
vs.
Old 08-13-2010, 09:13 AM   #18
cessna152
Member#: 7523
1999 Impreza 2.5 RS
Nice price!
Old 08-13-2010, 11:30 AM   #19
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Nice price!
Thanks!
__________________
vs.
Old 08-27-2010, 10:18 AM   #20
D-NaSty
Member#: 156456
2005 92x aero
any update?
D-NaSty is offline
Old 08-27-2010, 10:55 AM   #21
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I'm hoping to have some pics next week
__________________
vs.
Old 09-01-2010, 04:05 PM   #22
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Pictures updated
__________________
vs.
Old 09-01-2010, 04:27 PM   #23
monkiboy
Member#: 202958
2008 wrx
thanks! ready to buy!
monkiboy is offline
Old 09-01-2010, 05:42 PM   #24
jutes85
Member Sales Rating: (6)
Member#: 127232
E90 M3
98' Foz
Nice piece. Although the thought of dropping the pan again pisses me off.
jutes85 is offline
Old 09-01-2010, 05:55 PM   #25
notjustforshow
Member Sales Rating: (14)
Member#: 143277
05 STI PPP OBP
1098, Z1000
nice! any combo pricing planned?
notjustforshow is offline
Closed Thread
Killer B Motorsport Oil Pans for sale Legba Engine/Power/Exhaust 2 12-11-2009 10:01 AM
Killer B Motorsport Oil Pans for sale Legba Private Vehicle 'For Sale' Classifieds 4 12-11-2009 12:09 AM
Killer B Motorsport Oil Pan & Pickup Group Buy $580 Shipped! KillerBMotorsport Vendor 'Group Buy' Classifieds 51 11-25-2009 10:51 PM
