Welcome to the North American Subaru Impreza Owners Club Saturday January 31, 2015
Old 08-05-2010, 01:46 PM   #1
paranoidWRX
Member#: 156932
2006 WRX
Black Pearl
Angry Driver side fog light keeps burning out
I searched, but I did not find anything related to my issue, so here it is:
I have 2006 WRX and I had to replace my driver side fog light 3 times in a short period of time... Few months ago, I figured it was that time to replace it since I never had any issues before... then it went out again after a month or so, I figured I put some ****ty bulb in.... and last night.
Without taking it to the dealer and have them inspect my electrical wiring to see where it is short circuiting, what can I do myself so I can save some money since I bet something like that is rather expensive to fix.
In addition, my other lights went one by one one (headlights and other fog light), I replaced them and they seem to work fine... for now. but it started to happen around the same time, which raises my concern.
and no, I did not install anything or touched anything...
thanks in advance!
paranoidWRX is offline   Reply With Quote
Old 08-05-2010, 08:25 PM   #2
Henry H
Member#: 184330
2008 Impreza 2.5i
Dark Grey Metallic
Search just a tad bit harder. I've seen this problem come up a few times.
Henry H is offline   Reply With Quote
Old 08-06-2010, 02:28 AM   #3
paranoidWRX
Member#: 156932
2006 WRX
Black Pearl
http://forums.nasioc.com/forums/show....php?t=2026472
this one seems to be hid issue... and like i said i did not touch any wiring... I will do more searching, but if you can point me to the right direction, it will be greatly appreciated!
Old 08-06-2010, 04:11 AM   #4
Henry H
Member#: 184330
2008 Impreza 2.5i
Dark Grey Metallic
Here's a laundry list:
- Make sure they are not no namer bulbs [manufacturer flaws]
- Check housing for cracks/leaks [excessive uneven cooling on bulb and/or debris]
- Check voltage flucuation [rare but it could happen]
- Check housing loose parts [constant vibration of hot filament not good]
Old 08-06-2010, 01:25 PM   #5
paranoidWRX
Member#: 156932
2006 WRX
Black Pearl
Thank you sir will do!
Btw... it was funny to read posts about fog lights issues and then to find "screw it, it just a fog light... where can I buy fog light covers?" post at the end
Old 08-06-2010, 01:33 PM   #6
wrxwhat
Member#: 87653
500 hp STI / 1100hp
Supra T / Stock G35
My fogs are always dying.. The irony is, my driver side fog has a leak, and is full of but the light works, the passenger side is fine with no leaks but the bulb doesn't work.
wrxwhat is offline   Reply With Quote
Old 08-06-2010, 03:49 PM   #7
Henry H
Member#: 184330
2008 Impreza 2.5i
Dark Grey Metallic
LOL...ah gremlins have a sense of humor. Perhaps your driver side fogs have found an equilibrium of cooling evenly and preserving your bulb while your passenger side fogs prematurely burn out from sweltering heat.
Old 08-18-2010, 08:39 PM   #8
cmatthew1978
Member#: 246523
2006 WRX Wagon
SGM
funny, my car just got here(2006 Wrx Wagon) and the damn DS FL is out so I am searching and saw this hoping it would help. GL with fix
cmatthew1978 is offline   Reply With Quote
Old 08-19-2010, 08:26 PM   #9
scoarer
Member#: 229320
Check for sitting moisture in wiring/light housing.. i had a car that did the same thing. Took the light off and water dripped from it when flipped upside down.
scoarer is offline   Reply With Quote
Old 08-22-2010, 05:58 PM   #10
genkidama20
Member#: 73635
04 WRX
WRB Wingless
I know the feeling. I've replaced my driver side fog light twice this year now with the Hella H3 12V 55W Yellow Star bulbs.
My solution: Don't use my fog lights. The temptation is there to turn on my fogs, but once I turn it on and realize that one of them is out, it annoys the heck out of me and I just turn it back off.
genkidama20 is offline   Reply With Quote
Old 08-25-2010, 12:11 PM   #11
bzbuzz
Member#: 116052
2011 STI ( Sold )
same things happened to me.
bzbuzz is offline   Reply With Quote
Old 09-07-2010, 02:16 PM   #12
cmatthew1978
Member#: 246523
2006 WRX Wagon
SGM
^^^^^ ME 2! There is obviously an issue. I just bought yellow H3's on Ebay. When they get here I am going to inspect and find the reason behind the water building up and blowing. I will update when I find out. I like the fogs, and am not going to quit until the problem is GONE.
Old 07-31-2014, 12:07 PM   #13
ScubaNoob
Member#: 360147
2004 WRX
BMP
Yea having same issue here too! Two bulbs out and now I waiting to sacrifice a third one.
ScubaNoob is offline   Reply With Quote
Fog lamps keep burning out Shootist Electrical & Lighting 5 08-22-2009 10:10 AM
WTB: WRB Driver Side Fog Light Bezel or STi Fog Cover (both) macdarwin SCIC Private Classifieds 6 07-28-2008 10:40 PM
fog lights keep burning out X-43a Electrical & Lighting 0 04-06-2008 02:23 PM
Driver side fog light bulb keeps blowing Dex Electrical & Lighting 14 03-06-2008 11:12 AM
WTB: 03 wrx driver side fog light or fog light lense. SinhCredible Private 'Wanted' Classifieds 2 07-01-2004 01:45 PM
