Welcome to the North American Subaru Impreza Owners Club Tuesday August 23, 2016
Old 08-05-2010, 03:59 PM   #1
BKRush
Member#: 169125
2005 2.5 RS
Black on Black
Default crazy low idle... but drives fine???question for the masters
okay so a little background first. i have a 2005 2.5 RS with the only mod to the engine is a CAI. I took off the negative to my battery yesterday to reset my ECU. Immediately when i turned my car back on, it would idle at about 350 but would drive fine. At every other stop light it seems, the car dies and i have to re start it. i have heard somethings about the ecu having to relearn everything. but its been a day and a half and im still idling at around 350. if it is the case that i have to let the ecu relearn everything, how long is this gonna last? and has anybody else ran into the same problem? thanks in advance guys
BKRush is offline   Reply With Quote
Old 08-05-2010, 04:08 PM   #2
Mr_Hox
Member#: 118789
I just went from
six to midnight...
Any CEL displayed?
Check/clean the MAF and see if that helps.
Mr_Hox is offline   Reply With Quote
Old 08-05-2010, 04:14 PM   #3
Lord Stinky
Member#: 182700
2002 bugeye
SRP
I was having rough idle issues, they went away when I cleaned the Idle Air Control Valve.
IBsearchn00b
Lord Stinky is offline   Reply With Quote
Old 08-05-2010, 04:31 PM   #4
BKRush
Member#: 169125
2005 2.5 RS
Black on Black
yeah the car was working perfectly fine then when i took the negative off this crap happened. i cleaned the maf....
@lord stinky... was this after a reset or just in general.
what messes with me is that one the car was perfectly fine till i did that and secondly that it is taking forever for the car to re learn
Old 08-05-2010, 04:32 PM   #5
BKRush
Member#: 169125
2005 2.5 RS
Black on Black
and the only cel that is popping up is the low idle one
Old 08-05-2010, 04:55 PM   #6
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
why did you reset the ECU in the first place? Was there a code? How can you tell the car was idling at 350rpm? the tach on the dash doesn't read that low. (starts at 500rpm)
Zefy is offline   Reply With Quote
Old 08-05-2010, 04:59 PM   #7
BKRush
Member#: 169125
2005 2.5 RS
Black on Black
@ Zefy......i have a scanguage which reads the tach digitally
Old 08-05-2010, 05:01 PM   #8
flightwatch
Member#: 231058
2015 F-150
What's the actual DTC?
flightwatch is offline   Reply With Quote
Old 08-05-2010, 05:05 PM   #9
BKRush
Member#: 169125
2005 2.5 RS
Black on Black
not sure what your asking flight watch
Old 08-05-2010, 05:13 PM   #10
shibby2821
Member#: 229778
04 WRX
WR blue
its the intake lol. needs to be tuned, ur either running to lean or rich. the MAF is used to reading the stock airbox
shibby2821 is offline   Reply With Quote
Old 08-05-2010, 05:20 PM   #11
BKRush
Member#: 169125
2005 2.5 RS
Black on Black
it wasnt tuned before. i was running stock flash. does anyone really know if it will work it self out or anything i can do to help it learn? leave it running? something?
Old 08-05-2010, 05:41 PM   #12
SPACEMAN5000
Member#: 221689
03 JBP Fozzzzzy
05 RS OD! WARHAWK GREEN
i have the same problem on the same car running a hybrid intake...i just ordered an injen cai but i also have an accessport with preloaded maps for the cai so im hoping itll get fixed when i get the right intake on. my advice.....get a tune
SPACEMAN5000 is offline   Reply With Quote
Old 08-05-2010, 06:53 PM   #13
GrundleJuice
Member#: 165749
anytime you reset the ECU, you should let the car idle for 10 min at least before you touch the gas pedal or turn on the A/C (or put it in gear if its an auto). otherwise the ECU will take much longer to relearn the idle settings, like days-weeks of driving. Why this is, I do not know. Some kind of idle learn procedure after a reset i guess. Others may have more info on the "why this is necessary".
Even with a completely stock intake, idle problems can occur if this procedure isn't followed. Usually they are not as severe, though.
Old 08-05-2010, 08:14 PM   #14
shibby2821
Member#: 229778
04 WRX
WR blue
dont matter if its stock map bro, ur gettin colder temps in the intake. i seen a lot of posts like this and most of them cuz its not tuned. even on the stickys they say so get in tuned. its ur call on the tune. my idles messed up too since i moved from a sri to cai, ima wait a lil longer till i get tuned. no $$$ in my pockets
Old 08-05-2010, 10:51 PM   #15
flightwatch
Member#: 231058
2015 F-150
I have ran intakes on almost every car than I have ever owned, and I didn't have to tune for them. DTC stands for diagnostic trouble code, and it starts with a P (i.e: P0037, P0420.) What raceface said is true. After an ecu reset, my car will take up to 3 days to relearn a stable and proper idle.
Old 08-06-2010, 08:03 AM   #16
zavier
Member#: 141189
2007 2.5i (NBP)
2014 BRZ (DGM)
Yea my car has this problem and it seems 10min is no longer the time it takes to relearn, for 3yrs it was 10min and go and it would be fine, now it takes almost 20-30min (I think something needs to be cleaned) but the code I get for low idle air sensor is P0506...I wonder if that is what he gets...
Mine throws a temp code for a bit and then eventually throws the CEL after a few miles
zavier is offline   Reply With Quote
Old 08-06-2010, 12:28 PM   #17
BKRush
Member#: 169125
2005 2.5 RS
Black on Black
zavier_____ yeah that's exactly what it pulls up as P0506... Cleaned the maf and still having the trouble.. I'm curious what you did, did you just let it idle for that long? 20-30 minutes for it to re learn?
I need an 05 sti+ wiring diagram for the Master Controls snowcrzy Electrical & Lighting 1 03-28-2007 12:13 AM
Who is pumped for The Masters?? rickeyj23 Off-Topic 27 04-07-2004 09:26 PM
twin BOV question for the masters gooter80 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 07-29-2003 05:06 AM
suspension question for the master techs: bushing differences between FWD/AWD? RaceCarRiot Brakes, Steering & Suspension 2 05-14-2002 09:08 AM
Newbie questions for the Subaru masters...:D RSarte Newbies & FAQs 10 04-02-2001 08:25 AM
