#1 |
Member#: 184330
Vehicle:2008 Impreza 2.5i Dark Grey Metallic |
I RARELY change these two, it doesnt seem that important to change often. How often do you guys change them?
Brake fluid: I only change them if braking starts to get too spongy. PS fluid: I only top off if it needs it. I don't think I've ever changed them on my 94 Accord and they've never been a problem. I could never think of what could go horribly wrong if I've never changed them. I don't track my car so its mostly DD with mild spirited-ness. Any other opinions, consensus?
#2 | |
Member#: 16200
Vehicle:OK Houston we have an Uncle |
any dot 3/4 brake fluid will do nicely.....and your car uses dexron ATF as power steering fluid...do NOT put 'power steering fluid' in it!!!!! |
#3 |
Member#: 226211
Vehicle:2002 impreza WRX JDM blue |
![]() or something equivalent, yes, it's DIII type |
#4 |
Member#: 184330
Ha! I'll make my title clearer. I was actually asking about your thoughts on CHANGING frequencies of these fluids. They are pretty much lowest on my list of regular maintenance.
#5 | |
Member#: 226211
PSF - if we believe subaru, manual says 100k KM |
#6 |
Member#: 48377
Vehicle:1996 Gutted, built XP class Impreza L |
In the DD, I change the brake fluid every 4-5 years and the PS fluid around 100K.
In the race car I change the brake fluid every year and the PS fluid at least every 2 years. |
#7 |
Member#: 216135
Vehicle:2011 Civic SI STX #66, 06 S2000 STR 180 |
Brand new brake fluid can take on as much as 1-2% water per year once in the brake system.
I read a disturbing statistic that 75% of cars with over 100k miles on the road have the original brake fluid it in. Anyway, I do my brake fluid every other year and PS ATF every 3-4 years. |
#8 |
Member#: 184330
I personally don't see much importance in PS fluid only because I've never heard of damage or failure due to old fluid. Can someone enlighten me on stories or findings?
Brake fluid: I only change if it feels different when brake. I'm guessing that feeling is when my brake fluid starts to boil at the caliper and I am compressing the vapor? A direct consequence of water getting into brake fluid I venture. Come to think of it, I should change my brake fluid more often if I go up and down the mountains. Mountain driving will heat up my fluid pretty quick and I don't need any spongy feeling while braking downhill. |
#9 |
Member#: 48377
If you work your PS pump hard (autocross or track days for instance) it can overheat the fluid. Once it's been overheated it's never the same anymore. Similar to brake fluid but not as bad as the steering just gets really heavy.
#10 | |
Member#: 75129
Vehicle:09 WRX stg 2+ Lost the boxer rumble |
That doesn't surprise me those are 2 neglected fluids in autos
#11 |
Member#: 216135
Yep, I've already changed my PS fluid to M1 ATF and my car only has 10k miles on it. I started noticing the steering getting very hard in fast transition elements in autox. I did the drain and fill method about 6 times.
#12 |
Member#: 131347
Vehicle:2007 Legacy 2.5i SE 98 Z/28, VN 900 custom |
Brake fluid is every 30k.
PSF I would replace it if it is dirty, usually it takes about 45k or so to get there. |
#13 |
Member#: 16200
#14 |
Member#: 52539
TXIC
Vehicle:2003 Impreza WRX BLUE |
I do my brake fluid every 30k, but if by a time basis, I'd say every 2-3 years or so.
Beats me with the power steering fluid. Probably every 60k wouldn't hurt. |
#15 |
Member#: 70470
Vehicle:2004 Impreza WRX aspen white |
very interesting. i didnt know my power steering fluid was actually automatic transmission fluid!
#16 |
Member#: 184330
SOME cars use power steering fluid for PS pump SOME cars use ATF for PS pump. Make sure what's what.
#17 | |
Member#: 253872
NESIC
Vehicle:2010 Imprezza Newport Blue |
You'll get a host of opinons...I generally "over maintain" my cars, changing fluids more often than the "recommended" intervals. I rationalise my regimen this way: he fluids are cheap and easy to replace. What is the harm in having new P/S, P/brake / tranny fluids? None. What;s the harm using contaminated fluids? Can be very costly!
OK...with that long-winded intro, I change my brake fluid each time the brakes are replaced (bleeding them out should be standard protocol, but you'll be surprised how many "brake specialists" will only top off the reservoir). I change the P/S fluid every 12,000 mi. At the same time I change the air filter. I change oil every 3,000. I change coolant every 24,000 and hoses every 48,000. The "extended" versions (100,000+) are fine, but really...the issue isn't the cooling capacity of the fluid (it doesn't change much) the real issue is the buffering capacity. Coolant also needs to neutralize the acids in the system. Basically the cooling system is battery-like since it is composed of mixed metals: usuially an aluminum radiator and a copper heater core, as well as iron in the some engine blocks. I change drive belt every 60,000. But I noticed that the Imprezza doesn't use a serpentine belt system. That's too bad. It is real nice thing. That also mans that you need to change belts more frequently since there is no tensioner to keep them perfect. Quote:
#18 |
Member#: 148061
NWIC
Vehicle:2002 2.5 RS Blue Ridge Pearl |
is there a drain valve somewhere to drain the power steering, or do you pump it out of the reservoir and just pour new fluid in?
#19 | |
Member#: 216135
Some people get under the car and remove the low pressure hose from the steering rack with the tires off the ground and have someone else spin the wheel back and forth to get all of the fluid out...this method requires thorough bleeding afterward. |
#20 | |
Member#: 148061
NWIC
so for the turkey baster method, I just remove as much as the liquid I can then refill with new fluid, then drive around a do it over several times? Is there something I should be worried about when doing the fluid change, like getting air into the system? The dealer is trying to charge me $100 for a power steering fluid change. |
#21 | |
Member#: 216135
#22 |
Member#: 184330
I've been looking up PS fluid changes too. I think I'll do that when it starts to get dark...I was helping my brother look at his PS fluid and it looks like a triple pull espresso with heavy cream (he RARELY takes care of his car).
That in itself compels me to flush it. He gets a whirring noise that seems to coincide when the steering wheel turns. I wonder if a thorough flush will help. I'll have him get plenty of ATF. |
#23 |
Member#: 117946
changed clutch fluid at 55k cause i changed the clutch. (its break fluid it counts)
power steering at about 75k cause it was making squeaking sounds which was really just a belt slipping at startup. (i did the ****ty siphon method instead of drain, demo please) but i figured it wasnt really important cause most ps pumps die around the same time whether or not u change the fluid (probably no longer true). still havent really changed brake fluid, though i did change my rotors and pads and mixed about half new fluid in at like 40k. just changed rear diff fluid at 75k for the first time changed tranny fluid at 55k with the clutch. changed the coolant twice in the last week. for the first time at about 80k (do this sooner )i changed my belts cause they ripped apart to shreds when i put in my utec.( just coincidentally at the same time probly at like 60-65k) still have yet to change washer fluid, can anyone tell me how often im supposed to do that?? does this mean my windshield is going to need replacing? Last edited by ucfchuck; 08-20-2010 at 03:58 PM. Reason: (sp) |
#24 | |
Member#: 123843
NESIC
Vehicle:2006 SGM WRX S2 Let LED's light your way! |
I change the brake, clutch, and power-steering fluids once every two years. Oil every 3-months, coolant once every 3-years, and the transmission and rear differential oils once a year, but I'm going to move the rear differential OCI to once every two years. |
#25 | |
Member#: 186972
NWIC
Vehicle:91 Legacy SS EJ20G Pearl White |
What happens if you use power steering fluid? |
| Thread Tools | |
| Display Modes | |
| Amount of power steering fluid needed | NJHK | Service & Maintenance | 10 | 08-08-2010 11:35 AM |
| Power steering fluid, manual tranny fluid, and rear diff fluid | ex_boyometric | Vancouver Impreza Club Forum -- VIC | 17 | 03-09-2008 05:54 AM |
| Any instructions on how to change power steering fluid? | SC2000 | Service & Maintenance | 7 | 03-07-2008 09:11 AM |
| So all my power steering fluid is on the ground... | MUGWUMP | Factory 2.0L Turbo Powertrain | 10 | 09-07-2004 11:48 AM |
| Power steering fluid ran on empty now what? | BlackWagon | Service & Maintenance | 1 | 09-11-2002 07:47 AM |
