Old 08-06-2010, 12:47 AM   #1
386kustoms
Member#: 161803
2002 wrx
Default bug eye hid question
ok ok first off i read all the stickys and faq and have not found a answer. second i know hids are not good in our stock headlight assemblys but i wanted to try it out anyway since i needed new bulbs.
here is the question, i bought a kit from ddm i got the 9007 that only has lowbeam no high beam. i installed it corectly and they work fine. problem is that when i have my low beam on and foglights on the high beam light on the dash is lit up about halfway bright, and also the little green light on the fog button is lit up about half way as well. if i click the fog lights off the high beam light on the dash goes off. i also noticed the fogs dont work every time i turn them on with the light on.
i noticed ddm sold a relay harness is this something i should get and will that fix the problem?
i have put the old halogins back in for now but i was wondering if anyone has any input
386kustoms is offline   Reply With Quote
Old 08-06-2010, 02:10 AM   #2
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
It seems as if you've answered your questions and shown why rebased HIDs in halogen housings are a very bad idea. Honestly a retro can be done for not a lot of money but if you cannot save around $400 for a proper kit or even less using components you source yourself then quality halogens are your best bet. Theretrofitsource.com just came out with a mini morimoto bi xenon kit that looks quite interesting for around $278 which comes with everything you need for a complete retro: projectors, bulbs, ballasts, wiring harness and even shrouds. I just retrofit a pair of FXRs from them in a friend's bugeye and they are the same projectors I used in my Wife's Hyundai Santa Fe. You will never get what you want from PNP kits, period. BTW, if you could bake apart you lights it looks like the morimotos just screw into place and you put your lights back together. If you have any more questions just pm me.
Old 08-06-2010, 10:33 AM   #3
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
Old 08-06-2010, 01:58 PM   #4
Henry H
Member#: 184330
2008 Impreza 2.5i
Dark Grey Metallic
Short of a complete retrofit, you can get away with HID kits on some cars. I have it on my 08 and its absolutely fine. However, it is not for all cars.
Sounds like something is not grounded properly. There should be a ground wire coming out of the ballast or the ballast should at least be grounded onto the chassis via a bolt or direct contact with bare metal.
Personally, I wouldn't bother and just stick with halogens or HIR bulbs.
Henry H is offline   Reply With Quote
Old 08-06-2010, 03:48 PM   #5
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Originally Posted by Bluefoton View Post
Great answer Love the trash can!
Consider bi-xenon high beam is basically removing the cover from the hid bulb. So be kind to other people's eyes and use projectors.
Jdm Bug Eye Hid Headlights CrAzY AsIaN Private 'For Sale' Classifieds 1 03-20-2006 08:52 AM
OEM Headlights 02-03 bug eyes HID lense blocker TKRbeast Private 'For Sale' Classifieds 5 10-19-2005 12:29 AM
Headlight Trade? I need Morette or Bug EYE HID! wrxwhip Tri-State Area Forum 3 07-01-2005 07:23 AM
Bug Eye HID JDM car_cursed Private 'For Sale' Classifieds 14 06-23-2005 10:54 PM
highbeam for jdm bug eye hid lights elixirvtec Electrical & Lighting 0 07-05-2004 04:59 PM
