Old 08-06-2010, 03:43 AM   #1
alenk37
Member#: 211850
03 WRX
Midnight Black Pearl
Default left headlight fuse keeps blowing???
I have had an aftermarket hid kit on my bugeye for 2 years now with pretty much no problems up until now. I have had 4 fuses blow on me in the past 2 weeks, and the last 2 to blow, were back to back, so its blowing instantly. Any help would be deeply appreciated because on a scale of 1 to 10, 10 being nikola tesla im probably a 1.3 at best when it comes to electricity
alenk37 is offline   Reply With Quote
Old 08-06-2010, 12:44 PM   #2
Henry H
Member#: 184330
2008 Impreza 2.5i
Dark Grey Metallic
HIDs may use 35W as opposed to halogens using over 50W but HID ballasts also require higher INITIAL amperage to ignite a current through gas in the bulb (striking an arc), afterward the ballast should level out the wattage to about 35W. This would often require a higher rated fused (an extra 5 amps should do).
It might be possible that your kit is going bad and requires a higher initial current to charge the...hmmm its either an inductor or capacitor. Now try and use a fuse that is rated 5 amps more (anything higher increases chance of electrical fire). If that does not work, check the wires on your kit.
Seeing your expertise with electrical is pretty low. Search for HIR bulbs. They are a bit pricy but they are nice and bright with better longevity-to-brightness ratio than halogens.
Good luck.
Henry H is offline   Reply With Quote
Old 08-06-2010, 01:47 PM   #3
alenk37
Member#: 211850
03 WRX
Thanks for the info henry... Im takin it to my boys shop after work, just wanted some input on what to look for and you were very informative, thanks again, my dad things one of the ground wires might be a little exposed so gonna take a look at everything when i get the chance
Old 08-06-2010, 01:55 PM   #4
alenk37
Member#: 211850
03 WRX
Ever since i bought the kit, i had poblems sometimes when first turning on the lights it would start turning on ( or heating up til it became the brightest ) and the left head light would sometimes turn off then i would turn my lights back off and on and then it would stay on until i turned off my car so it seemed like there was an issue? I was told it was a bad ground but i cleaned, and sanded all my grounds, made sure no wires were touching each other and was never able to figure it out?
Old 08-06-2010, 02:45 PM   #5
Henry H
Member#: 184330
2008 Impreza 2.5i
Dark Grey Metallic
There is nothing wrong with ground wire exposure, unless your ground wire is prone to oxidation. Some ground wires are simply an un-insulated braid.
...the left head light would sometimes turn off then i would turn my lights back off and on and then it would stay on until i turned off my car...
...made sure no wires were touching each other and was never able to figure it out?
If you have to switch off and on to get your HID to turn on and stay on, then it sounds like a faulty ballast. Wire touching is okay in this case, that is what wire insulation is for.
Old 08-06-2010, 06:21 PM   #6
alenk37
Member#: 211850
03 WRX
Thanks henry, ill post and update once i get my resolution resolved... Hopefully in a couple hours
Illumination fuse keeps blowing DLUX WRX Electrical & Lighting 5 11-08-2006 12:21 AM
Speedometer/Window fuse keeps blowing Geoff Electrical & Lighting 0 05-31-2005 02:36 PM
*Urgent* Wiring some lights and fuse keeps blowing Subwoofer87 Electrical & Lighting 6 09-20-2004 11:23 AM
Radio Fuse Keeps Blowing Stilletto Electrical & Lighting 7 09-18-2003 12:12 AM
Main Fuse Keeps Blowing??? striklybidnis Electrical & Lighting 3 07-20-2003 11:36 PM
