Old 08-06-2010, 10:49 AM   #1
snoopyone8
Member#: 42970
1998 2.5RS BlkDmdPrl
2000 2.5RS SilverthornMet
Default 2000RS--Odd Starts directly after fuel fill-up
2000 RS, hybrid intake, Borla Headers, Factory Cat, Stromung 2.25" cat-back. All maintenance up to date.
This just started this year.... After filling up, the initial start is always rough. It doesnt matter if I completely fill it or just add 7-10 gallons. Ambient temp has no correlation and fuel grade/brand doesnt matter. I always make sure to overkill the gas cap tightening procedure as well (Full turn past "clicky")
The initial engine ignition is weak sounding and then it either stalls or "chugs" up to normal idle. After it reaches normal idle, its fine. No running issues and it doesnt happen again until the next time I fill it.
It happens more regularly when I run the tank down to a gallon or less.
Anyone else experienced this?
-adam
snoopyone8 is offline   Reply With Quote
Old 08-06-2010, 12:13 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
I get a little bit of surge after filling up all the way. Partial doesn't do it. Not sure if it's related to the evap system or what.
yarrgh is online now   Reply With Quote
Old 08-06-2010, 12:21 PM   #3
snoopyone8
Member#: 42970
Yeah, that is the thought that keeps going around in my head...its just odd, its almost as though the rails/injectors lose their supply of fuel.
Thanks for the reply!
Old 08-06-2010, 01:03 PM   #4
nasty_beer
Member#: 60990
Is it only after fill ups or does it happen if you stop the car after running hot and try and restart it 3 or 4 minutes later? You might have an injector leaking a bit causing a rich startup condition.
nasty_beer is offline   Reply With Quote
Old 08-06-2010, 01:36 PM   #5
snoopyone8
Member#: 42970
Its definitely happens only after fill-ups. Ive never had it happen any other time.
Although I know I shouldnt, I usually run the tank down down to 1/4 to 1/8, if not more
As I said, If I dont completely fill it (which I usually do) I will at least get it close (12-12.5 gallons).
I fill it up, cap it, crank it over and it will kinda cough and sputter. It will then either stall out after one revolution or slowly (1.5-3 seconds) chug up to normal idle. From that point on its fine...zero issues, no CELs.
Old 08-10-2010, 08:06 PM   #6
TheNateums
Member#: 243917
2000 Impreza 2.5RS
Sedona Red Pearl
It might be flooding it also, too much fuel can starve it for oxygen and and make it bog the same way it would if it were starved for fuel... more common with carbureted cars than fuel injected but still possible.
Check your plugs.
TheNateums is offline   Reply With Quote
Old 08-11-2010, 10:39 AM   #7
snoopyone8
Member#: 42970
Plugs are good, a nice tan color, even across all cylinders. Fuel filler neck is solid, no rust. Fuel Filter is changed every 10k.
I did have to replace the evap pump located by the canister a couple winters ago because of corrosion on the harness plug (stupid location for an electrical connection IMO)...but other than that, no issues
My educated guess is that it is in someway related to the evap system though...I just dont understand why it only happens when I fill the tank.
Maybe there is a valve or something stuck open and the increased pressure on the system during fueling is forcing the fuel out of the rails into the return line.
Only a guess. Any other thoughts? Anyone else have this happen to them?
Thanks all!
-adam
Old 08-13-2010, 05:14 AM   #8
connie808
Member#: 251735
2004 IMPREZA
CGM
IMO, its something to do with your EVAP system..I had something similar to your problem only after fill up. After I fill up, it cranks over but doesnt catch unless I step on the gas pedal flooding it. Then it would start.
The answer to my problem was that my Drain system for my EVAP was clogged with Road debris. Blew it out with Compressed air till all the Road debris shot out of the drain valve of the EVAP system. Then I had no problem starting after fill up.
connie808 is offline   Reply With Quote
Old 08-13-2010, 10:00 AM   #9
snoopyone8
Member#: 42970
Nice! Thank you Connie! Ill give that a go! Appreciate the advice!
Old 08-13-2010, 10:57 AM   #10
b4wantab
Member#: 21293
05 OB Black Bean
1969 W-30
I have had the same problem for about 35K. Used to be fine but then would buck a bit after fill ups, dealers said it was normal. Figured it was evap system but they both said it was fine.
Hey connie808 what does the drain system look like? I have an 02 legacy but it should look the same of be in the same general area.
Peace,
Greg
b4wantab is offline   Reply With Quote
Old 08-14-2010, 04:02 AM   #11
connie808
Member#: 251735
2004 IMPREZA
CGM
Peace,
Greg
Im not too familiar with the legacy setup especially for that year but assuming the layout is very similar, its going to be a black box located near the rear passenger wheel. There will be 3 lines coming out of the black box. One will be for Fuel Vapor labeled Fuel, Another line will be labeled "DRAIN", and the last one I forgot what it is. From the line that is labeled "DRAIN", follow that line. It'll lead upwards to a solenoid looking device. There is where your drain valve is. I'll try to dig up a diagram that I found and used as reference.
Old 08-14-2010, 08:58 AM   #12
snoopyone8
Member#: 42970
I found this B4...it might help a little.
http://forums.nasioc.com/forums/show....php?t=1584069
Old 08-16-2010, 05:45 AM   #13
connie808
Member#: 251735
2004 IMPREZA
CGM
Yups thats the same exact one that i used as reference. So did it solve the problem??
Old 08-16-2010, 11:59 AM   #14
snoopyone8
Member#: 42970
Hey Connie! Sorry, havent tried it yet...I'm gonna give it a shot this week. Thanks for checkin back though!
-adam
Old 08-23-2010, 10:16 AM   #15
b4wantab
Member#: 21293
05 OB Black Bean
1969 W-30
Thanks so much for the info guys. Been out on Vacation, will look at this this week. Great leg work for me, it is very appreciated.
Peace,
Greg
Old 06-07-2015, 01:43 PM   #16
paulmeisterpk
Member#: 84259
2000 2.5RS
Blue Ridge Pearl
Not to dig up an old thread, but I just had this same problem. Whenever I'd put fuel in, my car was hard starting and idled rough for a couple of minutes. I found a bad purge valve solenoid on the passenger side of the intake manifold that was stuck open, allowing gas vapor fumes to flow into the intake during refueling. Changed the part out with a new one from Subaru, and it took care of the problem. Hope this helps someone in the future.
paulmeisterpk is offline   Reply With Quote
Old 06-08-2015, 07:48 PM   #17
wtdash
Member#: 59182
2002 WRX GG>>
2016 Focus RS
And here's how to TEST IT.....>>>> HERE.
wtdash is online now   Reply With Quote
Old 06-08-2015, 10:34 PM   #18
jneiss19
Member#: 422223
2001 Forester
Purge valve solenoid, this happened on my wife's Buick. It pulled a code though.
jneiss19 is offline   Reply With Quote
After I filled up some gas, the car won't start zac5 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 11-17-2009 07:19 PM
won't start after a fill up John Kerr Normally Aspirated Powertrain 5 07-15-2008 02:12 AM
04 TS Jumpy after each fill up. BrysImpreza Normally Aspirated Powertrain 9 12-05-2006 01:49 PM
Car wont start after tank fill up!! SSsleeper96 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 12-22-2005 11:05 AM
Start up trouble after fill up. mmor101 Normally Aspirated Powertrain 0 10-24-2005 02:27 AM
