Old 08-06-2010, 10:24 AM   #1
speednate54
Member#: 246049
2013 WRX
Tangerine Orange Pearl
Default SRI intake help with beather lines
ok i have a 2009 2.5i building an sri and i need to figure out what to do with the 3 breather lines.
theres 1 off each head it appears that is just a hose from the heads to the intake torque box
then theres one off the block that goes to a sensor that plugged into the torque box
basically question is do i have to plug them back into the intake or and i "t" them together and use a breather filter.
or
Should i just use a breather filter on the one with the sensor and plug the other 2 from the heads?
speednate54 is offline   Reply With Quote
Old 08-06-2010, 02:04 PM   #2
speednate54
Member#: 246049
2013 WRX
never mind i got it
Old 08-06-2010, 03:05 PM   #3
09suby
Member#: 222590
2009 Impreza 2.5i
Spark Silver Metallic
hey, can you post some pics, and a write-up on how to do it? thanks in advance
09suby is offline   Reply With Quote
oem intake manifold with fuel lines in good shape [BEST OFFER TAKES IT] jeremywrx15554 Engine/Power/Exhaust 6 07-16-2009 08:24 PM
Need help with vac line... Strng1dah Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-31-2007 01:12 AM
need help with coolant lines on a perrin rotated kit 03clipsegts Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 09-11-2007 12:29 PM
need help with coolant line hook up dt311 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-18-2005 05:01 PM
Help with coolant lines smacksube Normally Aspirated with bolt-on Forced Induction Powertrain 1 12-17-2002 10:03 PM
