#1 |
Member#: 241360
International
Vehicle:2002 JDM V7 STI White |
Hi. I have a 2002 JDM STI.
Rebuilt motor( detonation caused piston damage), but besides all bolt on mods, car is quite stock. Stock IHI VF30 turbo, boosting .95-1.0 bar on 95RON(useless fuel). Injen intake, full exhaust back to front. Was wondering if anyone could have a look at my data logs please. I would like to understand whats going please. I live in Swaziland, Africa, so no tuner here to explain to me. Tuner is in South Africa, so a bit far from me. Car is ECUTEK'd. If the wastegate duty cycle is low, its because I use a boot controller, and this is the low boost setting for the "useless" fuel. Used ECUEXPLOREr 3rd gear log http://spreadsheets.google.com/ccc?k...INUJEbnc&hl=en 1st-4th gear http://spreadsheets0.google.com/ccc?...lA&hl=en#gid=0 This is screenshot from Learnview but I dont think its working properly. The IAM value is cool though, it can read fault codes and reset ecu' https://docs1.google.com/document/ed...ExMMxao&hl=en#
#2 |
n00b Moderator
Moderator Member#: 10613
South East
Vehicle:2002 USDM WRX WRB |
from what i see 3rd gear log.
your only building 13psi of boost...right on par with 0.95 bar. 0.75 lamda..11.0 afr but you're only at wot for about 1.5 seconds.. |
#3 |
Member#: 120789
Vehicle:2005 USDM STi |
jaxscuby is saying you haven't given us complete data to look at.
go out and take 3 datalogs of 3rd gear, 2000 - 7000 rpm, and log these variables: rpm boost pressure turbo dynamics maf voltage maf airflow wideband afr calculated load injector duty cycle throttle position fbkc (feedback knock correction) flkc (knock learning) ask a question. what are you trying to learn from your datalogs? the list i gave you will inform you about open loop (wide open throttle) operation, but not much else. |
#4 |
Member#: 241360
International
Thanks guys...
Uh Im using ECUExplore and some of those parameters are not there(maybe they are and are called something else???) |
| Thread Tools | |
| Display Modes | |
| How do I read my Log? Does this log look OK to you? Knock? | scottjua | AccessPort | 3 | 05-21-2009 04:03 AM |
| Trying stage 2, please read my logs! | Jag82 | Open Source Reflashes | 4 | 10-21-2008 12:53 AM |
| Help Me Learn to Read My Logs, Por favor | Soon2BturbodRS | Engine Management & Tuning | 7 | 12-16-2007 10:19 PM |
| someone please read my log | boostdog | Commercial ECU Reflashes | 12 | 12-05-2007 03:26 PM |
| please help diagnose my UTEC log (and a wicked shift knock???) | TexRex2002 | Engine Management & Tuning | 9 | 11-25-2005 08:52 PM |
