Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine Management
Closed Thread
Old 08-06-2010, 05:21 PM   #1
maperformance
Vendor Sales Rating: (80)
Member#: 141043
2015 WRX
Default Low Price Guaranteed: Cobb Accessports / AEM EMS / Grimmspeed EBCS
_____________________________
Are you to busy to worry about tuning your own car? Would you like piece of mind knowing your vehicle's computer (ECU) is protected against accidental damage. Are you ready to spend less time fumbling with a laptop and more time driving?
We offer you the ultimate personal tuning solution for your 2008 or 2009 STi. Save time and money with the ability to conveniently reprogram your vehicle's computer (ECU) by selecting one of the pre-installed performance "maps" that automatically optimize settings such as the air/fuel ratio, ignition timing, boost and more for performance results you can instantly feel.
However, the AccessPORT is so much MORE than just a REFLASH DEVICE. It allows you to monitor fuel economy (average and real time), perform performance tests in order to estimate your 0-60mph and 1/4 mile time, read and decipher ECU trouble codes (CELs), and monitor live data via the OEM vehicle sensors which eliminates the need for costly aftermarket gauges.
Well now that your here, your obviously interested in monitoring those A/F's! Well MAPerformance is here offering you the best possible equipment to get the job done right, not to mention for the right price . From standard gauge type to full logging capabilities, its available! Check out the following IN STOCK brands we have to offer!
PM us for Prices that WON'T BE BEAT!!!
[/center]
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
I want to earn your business, PM me and tell us how we can become your one stop shop for performance parts today!
ACL / AEM / ACT / Cosworth / Grimmspeed / Invidia / Ksport / Manley / Mishimoto / PTE / Tomei / Turbosmart / Wiseco
maperformance is offline
Old 08-06-2010, 05:21 PM   #2
maperformance
Member#: 141043
2015 WRX
Series 2 Plug & Play Engine Management System
A complete engine control system that plugs into the factory harness and uses the factory sensors. AEM’s Series 2 Programmable Engine Management System (EMS) is more powerful than its predecessor.
  • Plugs directly into the factory harness. No rewiring necessary.
  • Maps can be password protected by the tuner to prevent unauthorized usage or sharing.
  • Tune using new USB communication port or serial port.
  • New smaller enclosure for reduced physical size.
  • 1MB of internal data logging.
  • Up to 12 peak and hold injector drivers.
  • Up to 8 direct-fire coil outputs.
  • Includes start up calibrations.
  • Works with all AEM gauges.
The Most COMPLETE and BEST PERFORMING Subaru BCS Ever Built!
* Get into Boost Much Quicker
(Flows 10% more than the competition)
* Plug and Play into OEM Harness
(no splicing wire like other BCS!)
* Factory Fit with clean install
* Works Safely with Factory Subaru ECU
(custom coil to match ECU)
* Nickel Plated Fittings as this is Built To Last
(not the easily breakable plastic fittings!)
* Easy to Install and Very Easy to Tune
* The Only Direct Bolt-IN BCS for all Subaru Models
GrimmSpeed introduces the most complete and easy to use 3-Port Electronic Boost Solenoid available on the market. Our aftermarket boost controller allows you to raise the OEM boost levels in a quick and efficient manner. If you try to raise the boost on the weak OEM boost solenoid it will start to become unpredictable and unable to maintain proper and safe boost levels. Using our solenoid you are able to spool your turbo quicker and maintain a rock solid boost level. We have made our solenoid to withstand 120psi, way more than any Subaru will see.
Revolutionizing the Subaru boost solenoid market, we have created model specific install brackets that allow you to directly fit our Boost Solenoid into your Subaru for a factory fit. No more Zip-tying! We give you the factory fitment you have been waiting for.
Staying with the OEM fitment theme, our Boost Solenoid uses a Subaru style wiring harness so you can simply unplug your OEM solenoid and plug ours in. No more cutting the oem wiring and crimping wires together!
Also new to the Subaru boost solenoid market, we have used ultra low-profile hose fittings to keep the unit as small and clean as possible. The hose fittings are nickel plated brass so you don't have to worry about them snapping off like the plastic hose fittings!
More Features:
  • Users can use AN fittings with the solenoid.
  • MAC Valve's has completely custom made the valve for us(only MAC valve on the market to be custom made for automotive tuning use).
  • Specifically designed by GrimmSpeed to work safely with the factory Subaru ECU (requires tuning) and to reliably handle the vibrations and temperatures of your engine bay!
  • The only direct “bolt in” design for all Subaru models. Direct bolt in mounting bracket and hardware included! (specify which model before ordering)
  • Faster response and greater flow than any other valve out there. (by more than 10%!)
  • Nickel plated brass fittings. (unlike the competitors failure prone plastic fittings)
This BCS will handle all your boost control needs no matter what your power goals are.
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 08-06-2010, 05:22 PM   #3
maperformance
Member#: 141043
2015 WRX
more...
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 08-06-2010, 05:22 PM   #4
maperformance
Member#: 141043
2015 WRX
and one more
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 08-11-2010, 12:01 PM   #5
maperformance
Member#: 141043
2015 WRX
all pm's responded to. thanks for the inquiries gentlemen.
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 08-13-2010, 06:40 PM   #6
maperformance
Member#: 141043
2015 WRX
Get your red hot smokin deals here!
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 08-16-2010, 08:37 PM   #7
maperformance
Member#: 141043
2015 WRX
Pm Me!
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 08-24-2010, 02:08 PM   #8
maperformance
Member#: 141043
2015 WRX
Great deals today and each and every day!
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 08-24-2010, 02:16 PM   #9
berserksti
Member Sales Rating: (15)
Member#: 142113
Best vendor in nasioc!
berserksti is offline
Old 08-26-2010, 07:03 PM   #10
maperformance
Member#: 141043
2015 WRX
AWWW...It's customers like you that make the job that much better! Thanks for the kind words!
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 08-27-2010, 05:47 PM   #11
maperformance
Member#: 141043
2015 WRX
The best pricing around!
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 09-02-2010, 01:04 PM   #12
maperformance
Member#: 141043
2015 WRX
best prices around boys, come and get them.
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 09-03-2010, 07:32 PM   #13
maperformance
Member#: 141043
2015 WRX
Performance and prices that can't be beat!
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 09-06-2010, 01:42 PM   #14
maperformance
Member#: 141043
2015 WRX
That's right! We are open on Labor Day to save you money!
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 09-14-2010, 03:53 PM   #15
maperformance
Member#: 141043
2015 WRX
PM ME for the best and up to date pricing!
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 09-15-2010, 06:36 PM   #16
maperformance
Member#: 141043
2015 WRX
ttt.... let's keep things rolling.
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 09-16-2010, 03:51 PM   #17
maperformance
Member#: 141043
2015 WRX
Great prices each and every day!
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 09-17-2010, 06:44 PM   #18
maperformance
Member#: 141043
2015 WRX
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 09-20-2010, 02:38 PM   #19
maperformance
Member#: 141043
2015 WRX
Great deals here to be had!
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 09-21-2010, 06:25 PM   #20
maperformance
Member#: 141043
2015 WRX
Deals that will blow your mind and NOT your wallet!
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 09-22-2010, 07:54 PM   #21
maperformance
Member#: 141043
2015 WRX
come on boys who needs some deals on some parts?
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 09-23-2010, 05:54 PM   #22
maperformance
Member#: 141043
2015 WRX
Shoot me a message and let's talk parts!
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 09-24-2010, 05:32 PM   #23
maperformance
Member#: 141043
2015 WRX
I WANT to earn your business!
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 09-27-2010, 02:59 PM   #24
maperformance
Member#: 141043
2015 WRX
Mondays can still be fun days with savings like these!
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Old 09-28-2010, 07:20 PM   #25
maperformance
Member#: 141043
2015 WRX
Another day, another dollar saved at MAP
__________________
Ian Peterson
AIM:ipetersonatmap
651-348-8811 x 111
Closed Thread
Cobb AccessPORTS, TurboXS UTEC, GrimmSpeed-Perrin-HOA Manual/Elec Boost Controllers!! OAKOS Automotive Engine Management 210 10-09-2012 10:38 AM
Cobb Accessports - Overnight shipping / Tactrix Free Ground /AEM EMS/ Grimmspeed EBCS IAG Performance Engine Management 22 03-31-2011 03:14 PM
ny PRICE DROP: cobb accessport v2, blitz nur spec r, erz downpipe kstr0h Engine/Power/Exhaust 100 05-22-2010 01:36 PM
Cobb Accessport AEM UEGO WALBRO RC INJECTOR GATES TIMING BELT KOYO MIZU MISHIMOTO RAD jazzproparts Engine Management 5 04-20-2010 03:24 PM
**SOCAL** 05 WRX COBB AccessPort/AEM intake BlKsUbYkId Engine/Power/Exhaust 15 10-15-2006 01:57 PM
