Old 08-06-2010, 06:14 PM   #1
nitro1956
Member#: 230682
Default Replacement Short Block ID
I have a 2003 Outback wagon with the normally aspirated 2.5 engine. I have bought a used short block to put in it.
The used short block has these markings:
Rear of engine, top of flange which goes against the bell housing:
9641189662303
Rear of engine, top of flange which goes against the bell housing,
left half part of the block:
C288213
Also, stamped in a sort of ink:
top rear of block, right side half: 2004 08 07
top rear of block, left side half: 2004 D8 06
...Please help id this engine..it's a 2.5, but date of manufacture ?
A block for a NA engine ?
...I'm looking for confirmation that the block can be switched out OK with my existing short block which is presently in the wagon.
Thanks..
nitro1956 is offline   Reply With Quote
Old 08-07-2010, 02:54 AM   #2
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
What car did your used shortblock come from?
~Josh~
Old 08-07-2010, 10:52 AM   #3
nitro1956
Member#: 230682
...I don't know what kind of Subaru the used block came from......all I know is that it's a 2.5...and looks to be in great shape.
Old 08-07-2010, 12:35 PM   #4
Burnout
Member#: 4721
2002 2.5 RS
1997 Brighton
The VIN should be stamped on the side, of the right side of the bell housing. That will tell you what it came out of and what year.
Burnout is offline   Reply With Quote
Old 08-07-2010, 03:48 PM   #5
nitro1956
Member#: 230682
On the side of the right half is the block is stamped:
JF1SG63615G725196
this is a VIn number I guess but I can't decode it.
Old 08-07-2010, 05:02 PM   #6
jamal
Member#: 71875
98 Legacy GT
my wheels fit
SG is 2nd gen forester. Pretty sure 6 is n/a, it should be fine to use. Don't use the stock headgaskets though; get some for an sti
jamal is offline   Reply With Quote
Old 08-07-2010, 09:14 PM   #7
nitro1956
Member#: 230682
Curious...why use STI headgaskets ??
Old 08-07-2010, 09:48 PM   #8
dstan
Member#: 120386
2000 BRP 2.5RS Coupe
Wow the 89 Civic is fast
they are better
dstan is online now   Reply With Quote
Old 08-07-2010, 10:36 PM   #9
nitro1956
Member#: 230682
Will the compression ratio be any different ?
And if the block is a 2005 ( Forrester ), what year(s) STI headgaskets should be used ?
( Of course I'm going to be using the original heads out of my 2003 Outback wagon )
FS : EJ20 short block guitar72186 Engine/Power/Exhaust 6 08-12-2010 02:39 PM
Replacing short block RSdriver05 Normally Aspirated Powertrain 10 01-28-2010 02:53 PM
WTB: short block to replace 98 2.5RS block austenf740 TXIC Private Classifieds 3 02-14-2007 02:59 AM
Most common reason for short block replacement? JayRed02WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 01-08-2006 07:59 AM
When replacing short block, do you need to resurface... kenlee Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 16 12-20-2005 10:19 PM
