Old 08-06-2010, 08:29 PM   #1
Chandy69
Member#: 16087
02 WRX
Back seat with your mom
Default Can you reccomend a good soldering Gun!
Hey Guys,
I'm sick of having a POS one.. I'm looking to spend like 30-40 bucks on a decent soldering gun. Any suggestions?
Home depot? Lowes? Radio Shack?
Where should i go?
Chuck III
Chandy69 is offline   Reply With Quote
Old 08-06-2010, 08:41 PM   #2
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Get an iron, not a gun.
What do you need it for?
I use one of these:
Amazon.com: Weller SPG80L Marksman 80 Watt Stained Glass Soldering Iron: Home ImprovementAmazon.com: Weller SPG80L Marksman 80 Watt Stained Glass Soldering Iron: Home Improvement
For heavy gauge stuff like soldering R/C car batteries together or <10 gauge wire.
I use the Hakko equivalent of this:
Amazon.com: Weller SP40LK 40 Watt Soldering Iron Kit: Home ImprovementAmazon.com: Weller SP40LK 40 Watt Soldering Iron Kit: Home Improvement
for general purpose stuff.
The key is to get the wattage and tip size right for the job you're doing. You want enough heat stored in the tip so that you need to keep it on the joint no more than 2-3 seconds before it's hot enough to flow solder. And not so large that it's ready in 1/2 a second and your dumping tons of extra heat in there.
Think of the tip as a reservoir for the heat. Small tips for small jobs and large tips for large jobs. Wattage is more about recovery time than anything else, until you get to the point that you're soldering like 6 gauge wires, then you need all the heat you can get.
40 watt is good for general purpose. Get multiple tips so you can select the right size for the job. Get at least one chisel tip, those are good general purpose tips as you can use the narrow part of the chisel if you need a little heat and the flat side of the chisel for quicker heating / larger joints.
Concillian is offline   Reply With Quote
Old 08-06-2010, 08:44 PM   #3
Chandy69
Member#: 16087
02 WRX
Well right now i want it for small wires & Stereo. Next I plan on relocating my battery under my seat. So I woud like to make my terminal connections as nice as possible.
Where do i find large wire crimps? I assume i woudl have to do it in a vice?
Old 08-06-2010, 09:17 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Old 08-06-2010, 09:21 PM   #5
Chandy69
Member#: 16087
02 WRX
Yes i did a :Search: I didn't see any manufactures of Irons to use
Mulder
Your in NYC.. Arnt you getting ready to go out!
Old 08-06-2010, 10:59 PM   #6
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
I used these when i was into car stereo for 1/0 gauge Crimps were nice and neat compared to the vice
http://www.harborfreight.com/hydraul...ool-66150.html
fastnoypi is offline   Reply With Quote
Old 08-08-2010, 06:38 PM   #7
classicaddict
Member#: 220619
04 wrx wagon
snap on butane solder gun = beez kneez!
classicaddict is offline   Reply With Quote
Old 08-09-2010, 01:05 PM   #8
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
Purhcasing a butane iron like the one above that was suggested is great idea I think. It think Master may make the one shown above. Check them out.
Old 11-27-2013, 08:53 PM   #9
sackytar
Member#: 149262
03WR Rallycar/FXT/OB
PrimerGrey
Butane ones are not all that nice. Unless its 90 degrees where you are working.
sackytar is offline   Reply With Quote
Can you reccomend a good installer for DVD vid. systems In N.Orange? for wifes SUV Drew888 Southern California Impreza Club Forum -- SCIC 6 09-28-2006 01:03 AM
Can anyone reccomend a good machine shop on the North Shore? Schleppy New England Impreza Club Forum -- NESIC 5 02-28-2005 10:44 PM
Can anyone reccomend anything good to eat/drink before working out... Schleppy Off-Topic 38 02-25-2004 05:07 PM
Can anyone reccomend a good body shop? Odin Tri-State Area Forum 8 01-12-2004 10:57 AM
can anyone reccomend a good honda shop in houston? jmott Texas Impreza Club Forum -- TXIC 5 05-15-2002 05:26 PM
