Old 08-07-2010, 10:10 AM   #1
dsmtowrx
Member#: 48879
2010 STi 2.5xtr hsf6
Grey Stocker
Default ACC1, ACC2, ON3 Wiring Questions!
Little confused and have done a fair bit of searching. Trying to wire up an lc-1 with Auto Timer guage, and a Maddad Boostguage.
Question#1 - The Instructions say IG1(acc), and IG2(ig on) but we actually have acc1, acc2, and on3. So what to wire to what?
Question#2 - I need switched power even when cranking for the boost guage. I'm using HHH fuse splicers, anyone know a good fuse to splice into?
dsmtowrx is offline   Reply With Quote
Old 08-09-2010, 11:18 AM   #2
dsmtowrx
Member#: 48879
Grey Stocker
Any help out there? Thanks in advance.
Old 08-09-2010, 07:13 PM   #3
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
I suggest you use a fuse tap instead that way you don't splice into any wires. As for what to hook up to I think you may want to use ACC2 and ON. To find a fuse to tap on use a test light probe and check the power to fuse you want to use while changing the ignition switch to the positions and verify you have power to that fuse in those positions.
Old 08-10-2010, 10:22 AM   #4
dsmtowrx
Member#: 48879
Grey Stocker
Ya I am using fuse taps but was just wondering if anyone knew which fuses off hand. Haven't had a chance to test yet but will. Thanks.
How about headlight wire? Forgot to get that wiring diagram in my 36 hour window? ANyoneone know which one to wire to?
Old 08-10-2010, 11:13 AM   #5
Cougar4
Member#: 53443
Winestone
If you are talking about the wire for the illumination of the gauge the older vehicles used violet and orange wires for the illumination. The violet wire was tied to power and the orange wire was the controlled return side of the light. The light has to be isolated from ground. I'm not sure if the newer cars use the same colors or not.
6 spd swappers - Semi-famous Tranny 6 wire to 4 wire question gotboost02 Transmission (AT/MT) & Driveline 15 09-05-2008 08:27 PM
Wiring gauges, connecting wires, question shamrock 05 Electrical & Lighting 5 06-06-2008 04:19 PM
wiring question / ecu code question snailpower Engine Management & Tuning 4 01-07-2006 10:09 PM
quick wiring headlight wiring question Lordhowe Electrical & Lighting 0 11-23-2005 07:00 PM
wiring question- keep the amp power, speaker wires away from input wire? garie Car Audio, Video & Security 5 06-20-2003 06:25 PM
