Welcome to the North American Subaru Impreza Owners Club Monday October 24, 2016
Old 08-07-2010, 06:11 PM   #1
Member#: 75835
1992 dontask
Default shim bucket replacement?
friend of mine is rebuilding a 98 leg engine and he noticed that the shims will spin in place on some but not on a couple of them. should he replace these or does it not matter if they can do that?
TRBO_BXR is offline   Reply With Quote
Old 08-08-2010, 10:58 AM   #2
Member#: 254120
2004 sti
It does t matter. the will allcome out if you blow air under them, those are valve adjustment shims
vwbugpilot is offline   Reply With Quote
Shim buckets 98foreza Private 'Wanted' Classifieds 2 09-27-2009 12:57 AM
2.0L shimmed buckets, valves and springs upjeeper Engine/Power/Exhaust 0 09-21-2009 08:26 AM
wtb: valve shims/buckets ArmOinAwRx Private 'Wanted' Classifieds 1 11-24-2007 09:14 AM
Tech Works Shim Under Bucket Question-Where to get replacement shims? MY99 2.5GT Built Motor Discussion 14 04-19-2006 02:33 PM
valve shim remover/replacer tool erice1984 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-02-2005 01:51 AM
