Old 08-08-2010, 12:49 AM   #1
5SpdImpreza2010
Member#: 231561
2010 Impreza 2.5i
Dark Gray
Default CAI and Exhaust
Hey everyone,
I have a 2010 Impreza 2.5i Premium 5-door, and I was thinking about doing a few performance upgrades. My two main ideas are to get a CAI and a new exhaust system. I've done some research, and from what I've found, it seems that a CAI can cause some problems (most namely in the rain/driving through puddles). Some posts suggest going with a "hybrid" intake, which I'm not exactly sure of. As for the exhaust system, I've found one made by Subaru that seems to be just what I'm looking for. My only concern is if it is just four looks/sound, or does it actually boost my power, throttle response, etc. Here is its link - https://www.subaruonlineparts.com/pr...oducts_id=1136. In addition to these two mods, I also took a look into headers. It seems to me, though, that they are a modification mainly reserved for the wrx/sti models (or any turbo'd model), as they help increase upper end power in the rev range.
So, in short - Is it a good idea to invest in a CAI? Is the exhaust I found worthwhile in terms of power? Are headers meaningful for N/A Imprezas?
Thanks in advance!
-Michael
5SpdImpreza2010 is offline   Reply With Quote
Old 08-08-2010, 06:53 AM   #3
flightwatch
Member#: 231058
2012 Hyundai Sonata
terbo
There are literally thousands of threads that will answer your questions......but, I will try and answer them here.
The exhaust that you chose is probably made for the WRX and not the 2.5i. My suggestion is that you save yourself around $400-500 and get an exhaust shop to build you a custom exhaust. Either way, you will not see much (if any) gains from a cat-back alone. You will have to do headers-back to see any real gains.
You are correct that headers will shift your powerband to the right. The type of headers you get would also determine what type of power increase you will see. EL headers will give you the most gains, but you will not have the boxer rumble. UEL headers will not give you as much of a gain as EL's will, but you will have that unmistakable boxer rumble...99% of people will choose UEL's over EL's for the sound alone. Either route you go, it will require some customizing to make it work since there is currently no company that makes direct bolt-on headers for the '06 and newer N/A's.
The intake is up to you...do your own thing. Don't listen to everybody on here. Personally, I am running the hybrid. Not because somebody said that it was the safest alternative, but because I saw the best gains overall with that setup. I also tried a cai and a sri. I have run cai's on several cars that I owned, and I never had an issue. Remember, even on a lowered car, the filter on a cai is going to be sitting a foot or more off the ground and will be protected by the stock splash guards. On top of that, the filter would have to be completely submerged to start sucking water...that means you would have to be driving through a 2+ foot puddle to have issues. IMHO, you have to be acting like an asshat to start sucking water up the filter.
Hope that helps
flightwatch is offline   Reply With Quote
Old 08-08-2010, 09:53 AM   #4
cmiovino
Member#: 134005
2004 WRX Premium
I agree with most of the things in flightwatch's post. Mainly the exhaust is meant for sound, unless you do the entire thing AND swap to EL headers. That will net you a bit of power, but not much. Expensive too. Personally, I'd just roll with an axleback/muffler. No use doing a catback if you see near zero gains. It might sound slightly louder or a little different with the different midpipe. Not enough to justify the cost IMO.
And intake... oh boy... lol. Heated topic. I say no to the SRI and especially CAI due to the sucking up water thing. I understand it doesn't happen as much as people claim it does, but if there is any reasonable chance it could happen, it's not for me. Plus, I've done a lot of research and even just slapping a cone filter on the end of the MAF can make turbulent airflow, throwing the MAF off. This will usually cause your engine to run lean which is bad.
And finally, even if the intake doesn't suck up water or cause any AFR issues, it will shift the power band higher in the rev range. One of the benefits of the boxer engine and Subarus is their low end grunt. I'd like to keep that power.
So I dunno... the hybrid seems to be the way to go. You can try the others though.
Old 08-08-2010, 12:02 PM   #5
09suby
Member#: 222590
2009 Impreza 2.5i
Spark Silver Metallic
Intake, headers, and exhaust is not worthwhile to put on your car without a tune. And since you have a 2010 model, there is no definitions as yet for you to tune. I would suggest doing some suspension mods until you can be tuned. I would suggest a new set of tires, as the stock ones aren't that great. You can also do front sway bar upgrade,and add a rear sway bar. You can also do front and rear strut bars. You would be able to go fast in turns instead of fast in a straight line.lol
09suby is offline   Reply With Quote
Old 08-08-2010, 04:23 PM   #6
Wrencher86
Member#: 250463
2010 Impreza 2.5i
I have the same car as the OP and have the same questions. I"m glad that he asked and it's nice to see he's not getting flamed like I figured somebody would if they asked that. I know the stock response to these questions is "Do a search", but I've spent hours reading through these threads and haven't really come up with anything.
Does anybody know what kit to start with for the hybrid intake? I'd rather not have to hack up one of the $15 ebay kits into thirty pieces. How about a good DRY drop in filter?
Wrencher86 is offline   Reply With Quote
Old 08-08-2010, 05:22 PM   #7
cmiovino
Member#: 134005
2004 WRX Premium
The kits you start with are the ebay ones you hack up. It's very easy to modify. There are no hybrid kits that come pre-cut and ready to install.
Good dry drop in filter is the AEM dryflow or Apexi. Though, regular paper ones work just fine. You'll see no difference.
Old 08-08-2010, 06:29 PM   #8
Wrencher86
Member#: 250463
2010 Impreza 2.5i
Is the ebay kit the only one out there, though? I'm not concerned about the work, it's just that judging by the pictures around here it doesn't look very good when you get done. Also heard about some fitment issues.
AEM doesn't seem to offer any direct fit drop ins. Not that I could find, anyway. The filter is more about convenience and saving money. I had an AEM filter on my Honda and loved it. Just rinse it every six months or so and slap it back on the car.
Old 08-08-2010, 11:07 PM   #9
flightwatch
Member#: 231058
2012 Hyundai Sonata
terbo
09Suby is 99% right. The best performance mod you can do to our car is to get a tune. It doesn't net significant gains, but the drive-abilty is amazing. The stock tune is fine for the bolt-ons...when you start doing more serious upgrades (cams, pnp) is when you would need to be tuned. Irregardless, a tune is a great thing to get done since the stock Subaru maps are absolute dog poo.
An ebay intake might be your only way to go...unless you really want to ruin a $300 intake. Either way, you will have to hack the pipe up to make it fit...you guys have a lot more junk in the way than the older cars do.
Old 08-09-2010, 02:03 AM   #10
tylere
Member#: 175548
2008 Impreza 2.5i
metalic grey
i have a cat back from lachute performance for my 2008 2.5i. (http://www.lachutesubaru.com/cgi-bin...categoryid=532) it ran me about a grand with shipping (its from canada) and i got it around 2 years ago when the car first came off. it sounds really good for NA. I also had a CAI from cosmo racing. i would not buy that intake again. they gave me the wrong mounting bracket and it wound up rubbing a hole in my air conditioning and caused about $500 worth of damage.
tylere is offline   Reply With Quote
Old 08-09-2010, 04:34 AM   #11
flightwatch
Member#: 231058
2012 Hyundai Sonata
terbo
Holy crap...They are ridiculously expensive. They want $755.00 for just a downpipe w/cat. I didn't spend that much on my entire exhaust (headers-back.)
Old 08-09-2010, 12:21 PM   #12
resident1155
Member#: 92659
2002 Impreza RS
I personally feel that ANY CAI does wonders for manual subies, but makes the 4EAT automatic transmission turn to rubbish. I had the cobb intake on for 3 years, it made the car sound like a space ship and it just ran like crap. The choice is yours, I wouldn't worry about the car gulping up water though. The only intake that goes that far into the fender well is the Injen. I would go for something of a hybrid intake and run some flexible tubing (available at autozone or pepboys) from the stock intake (remove snorkus/silencer crap) to the fender well. Worked like a charm for me and retained stock appearance.
resident1155 is offline   Reply With Quote
wtb: cai and exhaust for 07 wagon r.l.brown SCIC Private Classifieds 20 07-04-2007 07:52 PM
wtb: cai and exhaust for 07 wagon r.l.brown Private 'Wanted' Classifieds 1 07-01-2007 10:37 PM
New CAI and Exhaust Hossamk Normally Aspirated Powertrain 6 09-11-2005 03:49 PM
Just got a cobb cai and stromung exhaust, little help please. kamil212 Normally Aspirated Powertrain 8 07-24-2005 06:52 PM
CAI and exhaust? Teflon2 Newbies & FAQs 5 04-29-2002 01:06 AM
Message Board Statistics All times are GMT -4. The time now is 07:51 AM.
