Vancouver Impreza Club
Old 08-09-2010, 01:47 AM   #26
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
Originally Posted by 2010 WRX Limited View Post
Anyways, the science of catalytic converters is even beyond me a little and I'm just paraphrasing what I've read elsewhere. So far, it seems that nobody has brought any actual science forward to disprove what I have been reading. But if it's out there I am open to it and I don't even care that much either way.
you've gotten bored and don't wanna play anymore?
you should really read the fine print. taken from the article that you posted and cited information from:
NOTE: The New York Times reporter's statement that nitrous oxides now comprise 7.2 percent of the gases that cause global warming appears to be wrong. If N2O is 7.2 percent of the greenhouse gases, and it's 300 times more potent than CO2, that would make it the primary greenhouse gas. The primary greenhouse gas is water vapor. Either the EPA has omitted water vapor altogether in its calculations, which would be very wrong, or the reporter misread the report and what the EPA actually meant was that N2O accounts for 7.2 percent of a putative warming effect. Quite different. The N2O figure should not be cited until verified.
You have to look beyond the new york times. They are doing exactly what you just did by paraphrasing information.
We do not need to disprove what you have been reading (and stating as truth). You need to back up what you've been stating.
also stated in the same article was this quote:
Car industry experts, however, favor less drastic changes. They propose cutting nitrous oxide production by adjusting catalytic converters in future models. They suspect that the gas is produced when the converter is warming up, and believe the converters could be redesigned to reach optimum temperature faster. That would also help them destroy other pollutants better.
Weaver said that measurements on more kinds of cars and light trucks would be needed to be certain about the size of the problem. But Weaver said, "It is quite clear that you produce nitrous oxide in a catalyst, in some circumstances."
interesting points i think. They 'suspect' that it happens when it is warming up.
Interesting finds, but more information is needed. These articles can not be taken to be 100% correct.
No I wasn't saying that it is it's own independent heat source. Only that the cat only functions by the engine being purposely tuned to have rich pulses.
this is incorrect. At idle, the AFRs will be bouncing back and forth between lean and rich causing these 'rich pulses'. This is a result of o2 sensor reading and the ecu interpreting the results causing 'lag' between the reading and the reaction. It is the only way for the engine to run smoothly. A car with no cats that has been 'tuned' to run without them for 'maximum performance' will still do this.
With that in mind, lots carbed cars had cats in them. They (when tuned correctly) would not run rich and did not have 'rich pulses' yet the cats still functioned perfectly.
Zefy is offline   Reply With Quote
Old 08-09-2010, 03:04 AM   #27
2010 WRX Limited
Member#: 217458
1989 Mazda Miata
Classic Red
Do catalytic converters help with global warming or not? Well no they don't. I have already backed this up with volumes of evidence. And I did read the part at the bottom too (it wasn't exactly fine print)
I found an article for those that are interested that does a good job of summarizing the costs and benefits:
http://indianhillmediaworks.typepad....-concerns.html
2010 WRX Limited is offline   Reply With Quote
Old 08-09-2010, 03:52 AM   #28
notjustforshow
Member#: 143277
05 STI PPP OBP
1098, Z1000
All very good points, but for the daily driver, isn't the "informed" decision to simply run a catalytic converter?
Even if you rationalized that having a test pipe all the way through is the best course of action, you still need to deal with everyone else, including the law giving you a hard time.
We can discuss how these things work, and how bad these things are for the environment etc, but bottom line "cost vs benefits" it will be better to run a catalytic converter in the GVA for a daily driven Subaru. This is the informed decision unless you like VI.
notjustforshow is offline   Reply With Quote
Old 08-09-2010, 04:20 AM   #29
dasnowman
Member#: 125450
Gone 07 SWP STi LTD
07 Nissan Nismo 4x4
This is a funny thread all I add is Cat's start forest and grass fires compared to it's non catted counter part.
Yes if you are looking to squeez every last whp out of your set-up an extra 5-10hp can happen from running cattless.
Noise wise I have had both and the inside cabin noise from running cattless is a LOT louder... Noise out the tail pipe seemed close to the same.
dasnowman is offline   Reply With Quote
Old 08-09-2010, 04:33 AM   #30
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
my problem with it is you cited and paraphrased that "nitrous oxide is actually 300 times more potent as a greenhouse gas than carbon dioxide."
whether or not this is actual fact is unknown based on the note i quoted above. It is almost worse that you did read 'the fine print' because you know it could be false information yet you made it one of your key points.
you will avoid much grief the next time you make a thread like this by citing and linking your sources. It's a pain in the ass to do but it avoids some of this extra crap that goes along with these threads. If you can show how you came to your decision instead of just posting the decision it helps readers understand the whole story.
Old 08-09-2010, 04:53 AM   #31
notjustforshow
Member#: 143277
05 STI PPP OBP
1098, Z1000
Nitrous Oxide is 300 times more potent as a greenhouse gas than carbon dioxide is not an exact statement. This is why wiki and a lot of online sources fall apart when used as arguments.
C/N:
Greenhouse gas is any gas that traps heat in the atmosphere, however Nitrous Oxide is responsible for nitrogen loading, which in the end results in more acidic conditions, and not necessarily 300 times more heat retention than CO2.
Also, humans do not produce the most amount of N2O, which is at approximately 8:19 vs natural sources such as the ocean (dissipation into the atmosphere).
Source= me. I am a marine biologist, and not like George Costanza lol
Old 08-09-2010, 11:14 AM   #32
rs420
the cone killer
Member#: 157784
02 swapped bugeye
anthricite
I am confused by this thread
Once your catalytic converter reaches its operating temperature (known as "light off temperature" and usually between 400 and 600 degrees Fahrenheit) the catalyst compound coating the inner ceramics start to convert the three regulated harmful emissions into less harmful emissions. The three harmful emissions regulated by the EPA are Carbon monoxide (CO), Hydrocarbons (or VOCs for Volatile Organic Compounds), and Nitrogen compounds (NOx).
Carbon monoxide: Most of the used air leaving your engine is Carbon dioxide or CO2. But since combustion isn't always perfect or complete, some of the Carbon molecules only pick up one Oxygen to create carbon monoxide, a deadly, odorless gas. The catalytic converter creates a reaction between the CO and its surrounding air particles to create CO2 and H2O (water).
Hydrocarbons: A Hydrocarbon is any compound made of Carbon and Hydrogen that can be burned. Hydrocarbon emissions covers a range of harmful emissions, but they are all made up of unburned Carbon and Hydrogen. Hydrocarbons are harmful when breathed and contribute greatly to smog build up in urban areas.
NOxNitrogen compounds referred to as NOx have caused many an emissions test failure. NOx emissions are basically Nitrogen molecules that have combined with Oxygen and escape the engine unburned. NOx emissions cause smog and acid rain.
The compounds coating the inner structure of the cat literally strip, ram together, and otherwise muscle these emissions into less harmful gases and water, leaving the stuff that comes out of your tailpipe in much better shape.
so your telling us that the energy/environmental impact to make the catalytic converter that goes into cars vs the effectiveness of the cat reducing harmfull exhaust gasses is better to never have had cat's at all?
or your saying if you want to go catless there is no problem because you are not really letting more unburnt gas into the atmosphere by running no cats?
or that it wont change the decible level out the tail pipe, or change the smell at all?
rs420 is offline   Reply With Quote
Old 08-09-2010, 12:13 PM   #33
j y
Member#: 8829
GRB STI
I have nothing to add to this thread, but I DID get a chuckle here:
Originally Posted by tora View Post
... I just don't want factless facts posted unless they are in fact factual ...
j y is offline   Reply With Quote
Old 08-09-2010, 07:09 PM   #34
codem
Member#: 178560
2000 GC8
Driving is bad for the environment, I am a driver, therefore I do not care about the environment or if you have a working Catalytic Converters.
Yes, I did just say that!
codem is offline   Reply With Quote
Old 08-09-2010, 07:31 PM   #35
Burnman
Member#: 218087
95 Legacy
That ugly 'spruce' green.
Another thing to think of with regards to removing the cat(s) can be safety. Since the cat is scrubbing out carbon monoxide, extra attention (more than usual) should be paid with a cat-less car running in an enclosed space like a garage.
Burnman is offline   Reply With Quote
Old 08-09-2010, 08:03 PM   #36
banman
Member#: 12408
2006 Legacy GT
My only comment on this thread is:
all else being equal (which it isn't), a car with cats will produce more CO2 than a car without - the catless car will just produce more CO and unburned HCs instead. That's about the only indisputable fact here. Is the (small) increase in CO2 emissions worth the benefits in urban air quality? Probably, but that's a pretty complex cost-benefit argument.
As for GHG potential of CO2 vs N2O, here's a chart from the IPCC 2007 Assessment Report:
banman is offline   Reply With Quote
Old 08-09-2010, 09:05 PM   #37
FunkMasta
Member#: 66985
2001 2.5RS sold
2012 2.0 Hatch
finally, an actual scientist.
Stephen, you've been gone too long!
FunkMasta is offline   Reply With Quote
Old 08-09-2010, 09:20 PM   #38
2010 WRX Limited
Member#: 217458
1989 Mazda Miata
Classic Red
Ha, I was too busy debating to notice that. That was funny. As far as what decision one should make about buying a catted or catless exhaust part or system, I don't know. For someone in a newer car, they may never have to take it through aircare. But if it is against the law to use a catless exhaust then thats something to be aware of. The forest fire risk is actually a very compelling reason to use a catted system. Does anyone know if any of the fires we are fighting in BC right now were caused this way?
Old 08-10-2010, 12:20 AM   #39
Burnman
Member#: 218087
95 Legacy
I thought the old diesels without particle traps were the fire-starters.
And I believe it is against the law to modify, change or remove a functioning factory cat.
Old 08-10-2010, 01:04 AM   #40
FunkMasta
Member#: 66985
2001 2.5RS sold
2012 2.0 Hatch
i have seen this.
A Friend of mine popped a tire and slid off a road onto some grass in his evo, called a tow truck and thought everything would be fine. A few minutes later the grass caught fire, and his entire car went up in smoke before he could move it.
Old 08-10-2010, 07:54 PM   #41
Jeff54
Member#: 129503
2002 It's resting
6 > 4?
y'alls a bunch of pansy mofos
Jeff54 is offline   Reply With Quote
Old 08-10-2010, 07:59 PM   #42
Burnman
Member#: 218087
95 Legacy
"Smells like... victory." (the sergeant guy from Apocalypse Now)
Old 08-10-2010, 08:04 PM   #43
Jeff54
Member#: 129503
2002 It's resting
6 > 4?
Old 08-10-2010, 09:10 PM   #44
tryallzee
Member#: 179947
1994 LS400
AWESOME haha
tryallzee is offline   Reply With Quote
Old 08-11-2010, 12:05 AM   #45
2010 WRX Limited
Member#: 217458
1989 Mazda Miata
Classic Red
Thank you Jeff. As we all know, he who has the best visuals wins. I was thinking about this thread today as I was driving home smelling some RHD Land Cruiser Deisel for like 10 minutes before I even saw it. That can't be good for your lungs, but it was a mint looking truck.
Old 08-27-2010, 11:15 PM   #46
pedaltime
Member#: 221903
2005 WRX
Java Black
How much do really benefit do you from catless exhaust?
pedaltime is offline   Reply With Quote
Old 08-28-2010, 06:19 AM   #47
iRomey
Member#: 254547
iRomey is offline   Reply With Quote
Old 08-28-2010, 01:24 PM   #48
rs420
the cone killer
Member#: 157784
02 swapped bugeye
anthricite
Tuner told me something I never heard before about catalytic converters..... sburck Newbies & FAQs 6 07-22-2010 05:11 PM
true or false about catalytic converters BriGuy Newbies & FAQs 7 10-16-2006 08:07 PM
Couple of questions about Catalytic Converters crxtls2 Normally Aspirated Powertrain 6 12-31-2005 11:27 PM
P and PGT Rally rules about Catalytic converter. Need help Rallyspec Motorsports 3 11-21-2001 03:38 AM
Some interesting facts about weight reduction Imprezer WRX Forum Archive 5 02-25-2001 10:33 PM
