Old 08-08-2010, 04:05 PM   #1
Keith Tobberman
Member#: 242853
2007 Impreza 2.5i
Satin White Pearl
Default BAD Water Spots
Hey,
I just washed my 09 Impreza outside. It is wicked windy so when I was done rinsing, most of the car was dry. I then ran to town to by some microfiber wax applicators and a buff rag. When I got back and started to apply the wax, I noticed that the waterspots stayed. I tries rinsing down and soaping up again, but after rinsing and this time drying, the spots are still there. I can feel them with my nail and it seems they are etched in. Am I screwed here?!?
-Thanks
Keith Tobberman is offline   Reply With Quote
Old 08-08-2010, 04:56 PM   #2
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
A couple of things here....
1) Even though you washed the car, as soon as you drove it you introduced road dirt/dust to the panels. Waxing the car in this condition will grind those particles against the finish and cause scratching/marring. You should only apply wax against a clean surface (i.e. like immediately after washing).
2) Generally speaking, wax/sealants are non-abrasive. They won't do much to remove water spots or other contaminants.
You need something that will help dissolve the mineral deposits left behind from the water drying on the surface. Vinegar is an excellent solution for this, is readily available and usually something that is already in many households. A paint cleaner could also help. In more severe cases you can try using a water spot remover like Chemical Guys WSR. If those don't work you can always resort to compounding/polishing.
Kean is offline   Reply With Quote
Old 08-09-2010, 12:03 AM   #3
Keith Tobberman
Member#: 242853
2007 Impreza 2.5i
Satin White Pearl
Thanks for the reply. I actually had gone to town on motorcycle to avoid getting the car dirty before waxing. Thanks for the tip though.
-Thanks
Old 08-09-2010, 12:07 AM   #4
Nagz
Member#: 211432
2012 WRX STI
Like Kean said, I would try a paint cleaner like "P21S paint cleanser". It's a very mild polish that will prep the paint for wax/sealant.
Nagz is offline   Reply With Quote
Old 08-09-2010, 12:31 AM   #5
Jay89
Member#: 205205
2007 WRX
Urban Grey
Heres a lesson for you. ALWAYS wash in the shade and on a warm sunny day. avoid direct sunlight if possible, and use clean distilled water if possible to rinse the car. otherwise waterspots can and will occur if left to air dry =p
you have several options.
1) go buy a otc paint cleaner and try to get rid of the water spots that way (i have never tried this method so i can not guarantee it)
2) use a clay bar to remove the contaminants and water spots. this usually works, but not a fool proof way.
now this third and guaranteed way to get rid of them takes much more effort, and a skilled hand.
3) Use a commercial polish such as SIP (menzerna super intensive polish II) and a circular polisher with a medium density CCS foam pad (white).
to be perfectly honest, if you want to have the best results, i would clay bar then polish with a circular polish. but if polishing is not within your ability, then i would suggest using a paint cleaner and clay bar. however, if not done correctly, it can scratch the car. i would use caution. good luck with getting rid of your water spots.
Jay89 is offline   Reply With Quote
Old 08-09-2010, 01:56 AM   #6
axleon2
Member#: 154117
2004 WRX
JAVA BLACK PEARL
Clay bar will work. If you don't have one or don't want one, you can use white distilled vinegar on your paint. As for your windows you can use lime away just be careful not to get it on your paint or plastic parts. I used both of these methods all the time when detailing cars as a profession and actually did it on my wife's car today.
axleon2 is offline   Reply With Quote
Old 08-09-2010, 02:46 AM   #7
EA82TRally
Member#: 73270
2002 WRX Wagon
Midnight Black Pearl
As was mentioned already, you can use a clay bar and it will do the job. One thing that I have found that works is Meguiar's Ultimate Compound. It works extremely well. I had the same problem with water spots(hard water at that; Yay California!) on an '04 Trailblazer that I just traded in and the Meguiar's Ultimate Compound took the spots right off. If I'm not mistaken, I bought it at AutoZone for under $8. Just a suggestion. Good Luck.
-Patrick
EA82TRally is offline   Reply With Quote
Old 08-09-2010, 03:14 AM   #8
GARGOYLE
Member#: 178918
AXELEON2 you BEAT ME,winner
never the less;Sometimes Koolaid ^ makes me ****ing sick.
I once got nearly persecuted for sharing this Info...
VINEGAR. Now go away.Thread over!
http://www.automedia.com/How_to_Elim...cr20020801hw/1
http://www.mydailydriver.com/driveway/swirl-marks
http://www.hdforums.com/forum/genera...e-vinegar.html
GARGOYLE is offline   Reply With Quote
Old 08-09-2010, 03:32 AM   #9
KraziAzn
Member#: 254327
Claybar man. it helps
KraziAzn is offline   Reply With Quote
Old 08-10-2010, 11:34 AM   #10
Vince F
Member#: 143802
2007 Imp 2.5i 5M Wgn
Crystal Gray
in 69' I had a black Dodge Charger, and tap water drying on it left rings. I had to get the water off fast. I thought it was minerals in the water, and added borax that softens water to the rinse. The rings of the spots were raised, not etched.
Vince F is offline   Reply With Quote
Old 08-10-2010, 12:12 PM   #11
Kean
Member#: 25187
'08 Foz Prem TGM
....cool, my first car was a '69 Charger SE (383ci w/a 727 trans). While it has seen better days, I still have it. ....I just need to get off my butt and start restoring it.
Old 08-10-2010, 12:51 PM   #12
Vince F
Member#: 143802
Crystal Gray
Better get after that Charger.)) I see a black 68' in my area. Mine got stolen, and that sent me on the path of small cars that handled great. 71' Mercury Capri, 86' Mustang SVO, and then the Impreza. Have a buddy who got the new Charger Hemi, then the Charger SRT8, Then the Challenger SRT8, Now a Camaro SS. He's young, and still trying to find himself. )))
Old 08-10-2010, 04:53 PM   #13
swygar
Member#: 253354
clay bar usually works
swygar is offline   Reply With Quote
Old 08-10-2010, 06:00 PM   #14
Kean
Member#: 25187
'08 Foz Prem TGM
….I know, I know.
I just purchased a 2010 Challenger R/T to replace my ’03 WRX. I always liked the ’69 Charger but the ’70 Challenger and the ‘Cuda were always favorites of mine. When Dodge reintroduced the new Challenger, I saw it as sort of a second chance. I’m also at a point in life where I wanted something full size, more comfortable yet still fun. I never thought it possible but the car does do a decent job capturing a bit of that muscle car essence I remember from my youth.
Your friend has had quite a few recent cars. I guess he’ll be wanting to a new Mustang 5.0 now? My co-worker has an SS that I’ve been wanting a ride in. ….I need to hit him up.
Old 08-10-2010, 06:01 PM   #15
Back Road Runner
Member#: 60082
2004 Forester STI
Mother's pre-wax cleaner works slick and preps the surface well for waxing. I've never toyed with a clay bar before, although that is a common solution for a lot of these things. I've been happy enough with the cleaner for water spots, dirt particles, and any oxidation on paint(no clear coat) or rubber parts. I've never not gotten a great surface after using it. The only thing it doesn't work well for is bugs, and I opt for a dedicated bug cleaner for that.
I've also found a spray on quick wax/detailer works well for a quick clean up, but it's not a great option for something actually dirty to start with. I have some Meguire's quick detailer spray, and I've come to like using it on my windows from time to time to get rid of light build up and to make rain just bead off, at least for a little while.
Old 08-10-2010, 10:19 PM   #16
Dane509
Member#: 204683
2004 STI
JBP
Kinda random, I had some water spots on my hood from my sprinkler system, and I could NOT get them off. This past week it rained pretty hard a few times, and I finally got a chance to wash my car the other day when the weather got better, and oddly enough after I hand dried my car like I always do, the water spots were gone. Kinda weird..
Dane509 is offline   Reply With Quote
Old 08-10-2010, 10:37 PM   #17
Smdavis27
Member#: 219455
2009 WRX Sedan
Satin White Pearl
Smdavis27 is offline   Reply With Quote
Old 08-10-2010, 10:50 PM   #18
Dane509
Member#: 204683
2004 STI
JBP
hahahah yeah, sorta like that.
Old 08-16-2010, 04:25 PM   #19
Interceptor-RX
Member#: 250572
2004 Pursuit Special
Interceptor-RX is offline   Reply With Quote
Old 08-16-2010, 04:47 PM   #20
midnighted
Member#: 131869
2002 BMW M3
Topaz Blue
when I had some hardcore water spots on my car from my apartments sprinkler system, sratch-x did wonders. I started with a claybar, then the scratch-x then nxt wax to finish it off. Also if you have it on your windows, rain-x makes a products that's like a paste that you can use that gets rid of them easily.
midnighted is offline   Reply With Quote
Old 08-16-2010, 05:20 PM   #21
Interceptor-RX
Member#: 250572
How exactly do you apply that stuff?
Just like a wax?
Old 08-16-2010, 06:03 PM   #22
midnighted
Member#: 131869
2002 BMW M3
Topaz Blue
yeah you just use a damp cloth, circular motion like a wax. It's called Rain-x X-treme clean. It's around $7 at pepboys but it was the only thing that I used that got rid of the water spots on my windows. I tried pretty much everything from Stoner's to CLR and none of them were able to do what this did.
here's a pic so you know what to look for too:
Old 08-16-2010, 06:13 PM   #23
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
Sorry to thread jack but......Thank you soooo much! I have hard water stains from our sprinklers and hope this works! Not even clay bar would take them off.
Layvon is offline   Reply With Quote
Old 08-16-2010, 06:19 PM   #24
midnighted
Member#: 131869
2002 BMW M3
Topaz Blue
lol np man. I had pretty much given up before I tried this. It takes some elbow grease to apply it but its well worth it. You can also use it on your headlights too if they are yellow\hazy.
Old 08-16-2010, 08:13 PM   #25
Interceptor-RX
Member#: 250572
Props.
Thanks man. Good to know.
My bad water pump led to a bad radiator pilfflip Legacy Forum 12 01-25-2007 10:34 PM
how to get water spots off? stentorian Interior & Exterior Modification 4 08-11-2002 03:07 AM
help me get rid of these blasted water spots please LEADFOOTINFASTRIDE Interior & Exterior Modification 0 07-23-2001 10:19 PM
$#@&*$ Water spots! Darwin Interior & Exterior Modification 9 05-08-2001 05:21 PM
Eek! Water spots! Islander General Forum Archive 12 06-21-2000 11:31 PM
Message Board Statistics All times are GMT -4. The time now is 08:35 PM.
