Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 08-08-2010, 07:19 PM   #1
Craig-STi/GTI/944
Member#: 148817
2007 STi, 85 944
95 Range Rover, 92 F-150
Question Tire Fitment
Can you fit 265 or 275 on a 17" wheel with rolled fenders on an '07 with coilovers?
Also, 225-50-18, which is the rough equivalent to 24/68-18. Stock 225-45-17's are 25.0" tall, the 24/68-18 are 26.7"
What offsets would be recommended for both?
I have 245-40-17 on the stock '07 wheels for now.
Craig-STi/GTI/944 is offline   Reply With Quote
Old 08-08-2010, 07:42 PM   #2
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
On my wrx I am running an 18x9.5 +35 wheel with a 275-35-18 tire. I have rolled front and rear fenders and camber....
bhhamblin is offline   Reply With Quote
Old 08-08-2010, 09:46 PM   #3
zizux
Member#: 199836
2011 STi
No idea how the gr and gd differ but I have 265's on 9" wheels with a 38 offset. I did have to roll the rears abit. Stock susy
Sent from my iPhone using Tapatalk
zizux is offline   Reply With Quote
Old 08-10-2010, 08:20 PM   #4
Gonz#75
Member#: 101841
1998 2.5RS
mostly black
Gonz#75 is offline   Reply With Quote
Old 08-10-2010, 08:25 PM   #5
Lil' Biggie
Member#: 93992
'06 EVO MR,
'89 240SX, '07 Yaris
They don't make a 24/68-18. And a Michelin 24/64R18 is much wider than a normal 225.
Lil' Biggie is offline   Reply With Quote
Old 08-10-2010, 10:16 PM   #6
wantsti
Member#: 134764
04 sti
java black pearl
You can do anything if you have enough$$$$$$$$$$$$
wantsti is offline   Reply With Quote
Old 08-11-2010, 01:49 AM   #7
Craig-STi/GTI/944
Member#: 148817
2007 STi, 85 944
eh, calculations are fun when you are off on one digit....
such are the joys of being up for 2 days straight.
the "64" not "68" comes to be 25.19xxxx", so height and width will not be an issue.
Even if it is closer to a 245-40-18, it will still only be 25.7" OD
Old 08-11-2010, 02:04 AM   #8
Craig-STi/GTI/944
Member#: 148817
2007 STi, 85 944
Originally Posted by Gonz#75 View Post
Thanks Gonz. I should be out a couple times before the season is over...
Long story, but the car is finally being fixed.
This has been the calculator I've been using for years.... http://www.miata.net/garage/tirecalc.html
I like the one you posted much better
Old 08-11-2010, 12:19 PM   #9
Lil' Biggie
Member#: 93992
'06 EVO MR,
I have no clue how you came up with a 24cm racing slick being as wide as a 225mm street tire. But here are accurate numbers for a comparison.
MICHELIN® Pilot Sport PS2
Tire Size: 225/40ZR18
Diameter: 25.1"
Section Width (in) on Rim (in): 9.2" on 8" Rim
Acceptable Rim Widths: 7.5" to 9"
Tire Size: 245/35ZR18
Diameter: 24.8"
Approximate Tread Width: 8"
Section Width (in) on Rim (in): 9.8" on 8.5" Rim
Acceptable Rim Widths: 8" to 9.5"
MICHELIN® Racing Slick
Tire Size: 24/64R18
Diameter: 25.3"
Approximate Tread Width: 8.9"
Section Width (in) on Rim (in): 10.0" on 9.5" Rim
Acceptable Rim Widths: 8.5" to 10.0"
Tire Size: 245/40ZR18
Diameter: 25.7"
Old 08-11-2010, 03:21 PM   #10
soundsofsnow
Member#: 230039
94 Miata
come at me bruh
That miata net calculator is decent, but I like this one better:
http://www.rimsntires.com/rt_specs.jsp
soundsofsnow is offline   Reply With Quote
Old 08-11-2010, 04:46 PM   #11
Craig-STi/GTI/944
Member#: 148817
2007 STi, 85 944
You know, the point of a forum like this is to come and get input from others.
I put up the wrong screen shot, that was for another size I was looking at. Yes, I do know that 24cm = 240mm and that 68cm ~ 25.1" .... damn that base 10 math is like uber hard... I crossed out the whole bit in my original post, which was flawed due to a number of unrelated reasons.
If you had actually read the full post, you would have seen
"Even if it is closer to a 245-40-18, it will still only be 25.7" OD"
I would say more, but I don't want to bring myself down to your form of interwebz forum "pwning". I'm not the only person on here that feels this way.
On a good note, soundofsnow, I agree with you and gonz on the "rimsntires" calculator being much better than miata.net's
... I'm sure some witty retort will follow ...
Old 08-11-2010, 05:04 PM   #12
Lil' Biggie
Member#: 93992
'06 EVO MR,
Whatever, you repeatedly made it seem as if you believed the tires were the wrong size, either height or width. All I did was post accurate information, if this is "pwning" you, then good for me I guess... Stop being a retard!
Old 08-11-2010, 05:06 PM   #13
Craig-STi/GTI/944
Member#: 148817
2007 STi, 85 944
Is that the best you can come up with?
Old 08-11-2010, 05:09 PM   #14
Lil' Biggie
Member#: 93992
'06 EVO MR,
Sorry I tried to help... Good luck with your tires.
Old 08-11-2010, 05:16 PM   #15
Craig-STi/GTI/944
Member#: 148817
2007 STi, 85 944
No, Brody and Gonz helped.
Old 08-11-2010, 07:59 PM   #16
Lil' Biggie
Member#: 93992
'06 EVO MR,
No worries, be as bitter as you like. I'm happy as a clam, my new wheels got here today!
Old 08-11-2010, 09:59 PM   #17
Craig-STi/GTI/944
Member#: 148817
2007 STi, 85 944
Should that impress any of us?
Old 08-12-2010, 02:51 AM   #18
Lil' Biggie
Member#: 93992
'06 EVO MR,
Ya, probably as you will need to take a sledgehammer to your car to shove 1.5" smaller wheels under it.
Old 08-12-2010, 06:59 AM   #19
Craig-STi/GTI/944
Member#: 148817
2007 STi, 85 944
You are running a Rota Grid, correct? So they clear your calipers and brake ducts just fine? Also, how much camber? With the camber bolts and adjustments on the coilovers, I can get quite a bit. This size would be just a "daily" tire, maybe try autocross, but not track. I ran STU last year, so I was limited to a 245 tire with a 140 or greater treadwear rating.
Old 08-12-2010, 10:20 AM   #20
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
pixors out of boxes stat! I have been waiting to see this wheel in a decent width and offset.......you bastard, you have to much "play" money
06HAWKMAN is offline   Reply With Quote
Old 08-12-2010, 02:48 PM   #21
Lil' Biggie
Member#: 93992
'06 EVO MR,
I dropped them off at my garage at the track, so no pics until Saturday.
tire fitment question (getting no response in tire forum) Spooled Southern California Impreza Club Forum -- SCIC 7 05-17-2003 01:51 PM
tire fitment? newbie1 Brakes, Steering & Suspension 0 08-10-2002 01:33 AM
Q re Rim & Tire Fitment on WRX Wagon SC WRX Brakes, Steering & Suspension 2 07-22-2002 10:02 PM
Tire Fitment Calculator daytontp Brakes, Steering & Suspension 2 02-05-2002 10:10 PM
