Old 08-09-2010, 12:19 AM   #1
KSubie
Member#: 142640
2008 STI
Accessport Stage 1 ACN
Default Car battery died headlights out!
So my battery died on my 08 Sti today and now my headlights arent turning on. Everything else works fine on the car (Brights, blinkers DRL's) has anyone ever heard of this? Thanks in Advance.
KSubie is offline   Reply With Quote
Old 08-09-2010, 12:21 AM   #2
scuba2708
Member#: 227872
2013 BRZ Limited
Galaxy Blue
dumb question...you did charge the battery or get a new one right???
scuba2708 is offline   Reply With Quote
Old 08-09-2010, 12:26 AM   #3
KSubie
Member#: 142640
2008 STI
Battery was charged, ive been driving around with it all day but didnt realize the headlights werent working till this evening
Old 08-09-2010, 12:29 AM   #4
scuba2708
Member#: 227872
2013 BRZ Limited
Galaxy Blue
hmm....are they HIDs? if it were me the first thing i would check out would be the lights themselves, ballasts, wiring, switch, and stuff along those lines because i would wonder if that is what caused the battery to discharge in the first place. A short in the headlight circuit would discharge a battery pretty quick.
Old 08-09-2010, 12:31 AM   #5
KSubie
Member#: 142640
2008 STI
the battery died because i left the keys in the "on" position when i was doing stuff with it this morning
Old 08-09-2010, 12:33 AM   #6
KSubie
Member#: 142640
2008 STI
the lights are the factory HID's
Old 08-09-2010, 12:34 AM   #7
scuba2708
Member#: 227872
2013 BRZ Limited
Galaxy Blue
well that'll do it also lol. um...I don't know much about HIDs but if someone who knows more can chime in would losing charge while on kill the balasts? if not then idk. check cheapest stuff first, see if fuse looks blown or if bulbs look burnt.
Old 08-09-2010, 12:29 PM   #8
KSubie
Member#: 142640
2008 STI
thanks for your help scuba, imma try and check the fuses later today. also i found out my brights dont stay on , they only light when im pulling the switch.
Old 08-09-2010, 12:59 PM   #9
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
If the brights are working this means the fuses are ok. It sounds like you have a problem with the combination switch for the lights.
Old 08-09-2010, 04:26 PM   #10
Henry H
Member#: 184330
2008 Impreza 2.5i
Dark Grey Metallic
I am not positively sure about how long the headlights stay on in our 08-11 subies but thankfully I never had a chance to "check" it. For all I know, if you leave your keys in the ON position and your headlights are on, the headlights would stay on until the battery dies.
Its possible that as your battery was draining with the lights on, the lights began to flicker. That flickering is the ballast struggling to keep the arc in your bulb going. This is baaaad for ballasts.
Since your other lights work fine and your car runs after the charge (make sure its at least 12v when not running), then your headlamp ballasts and/or bulbs are dead.
Henry H is offline   Reply With Quote
Old 08-11-2010, 12:22 PM   #11
KSubie
Member#: 142640
2008 STI
im gonna check the ballast and bulb later today, ill keep you guys updated. Thank for all the help!
When Electric-Car Batteries Die, Where Will They End Up? AVANTI R5 Non-Subaru News & Rumors 4 06-15-2010 02:17 PM
My battery dies if the car idles with the E-Brake on WRBLueGD2 Electrical & Lighting 66 04-16-2010 09:08 AM
Battery dying, car wont charge, help! wrxwhip Electrical & Lighting 6 08-02-2007 07:03 PM
Possible Battery Problem! Headlights Went Out! Please Help ... Tek Electrical & Lighting 2 08-18-2005 12:05 PM
worried about battery dying out...while using AP StealthfishWRX Engine Management & Tuning 5 06-28-2005 04:02 PM
