Old 08-09-2010, 02:30 PM   #1
BlackonBlueSubaru
Member#: 222448
04 WRX
Default Question on Voltage drop...
I have a turbo timer on my 04 wrx, and i use it mostly to view battery voltage. However when the radiator fan kicks on or i have the heater/AC fan on i can watch the voltage drop to 11 volts sometimes as low as 10... when the fans arent running the voltage indicator will rest at 13.9/14.0 volts. When it does dip i can view my dash lights and headlights dim significantly... Whats up with that? poor grounding? Is there a fix, like beefing up the grounds under the hood? anyone else see this happen? Any info is appreciated.
BlackonBlueSubaru is offline   Reply With Quote
Old 08-09-2010, 03:25 PM   #2
rkramer
Member#: 118209
2015 WRX Limitec
normal, yes for a subaru. fix the grounds and doublecheck your battery terminals.
Old 08-11-2010, 09:44 AM   #3
vien
Member#: 221538
2003 wrx/ylw wheels
darkness.................
get a voltage stabilizer kit it really works for our subarus
vien is offline   Reply With Quote
Old 08-11-2010, 07:17 PM   #4
motorhead1359
Member#: 206671
1998 Teh Unicorn
Green
make a grounding kit
motorhead1359 is offline   Reply With Quote
Old 08-12-2010, 10:12 AM   #5
rkramer
Member#: 118209
2015 WRX Limitec
snakeoil.... worthless and not needed.
subaru's have crappy grounds. Fix that.
Old 08-12-2010, 10:52 AM   #6
van_dutch
Member#: 198633
2004 WRX
The drop to 10 seems a little low.... Some drop is expected. Cleaning the grounds is never a bad idea.
van_dutch is offline   Reply With Quote
Old 08-12-2010, 02:45 PM   #7
BlackonBlueSubaru
Member#: 222448
04 WRX
I just did the mod in my shop 30 min? I ran 8 Ga. from battery - terminal to chassis drivers side ground to passenger side ground and to both sides of top intake and to alternator bolt... I do idle smoother, and my voltage drop isnt quite as much as previously stated now the lowest drop is 12.2 volts from as low as 10 before mod. Cool thanks fellow Subies...
Voltage drop s_nold Car Audio, Video & Security 14 07-06-2004 09:21 AM
Voltage drop OK? lupohki Car Audio, Video & Security 2 05-14-2004 02:41 AM
voltage drops and theory in general? (lets compare #s) wayoutwest Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-12-2002 08:33 PM
voltage drop in stock system forque Car Audio, Video & Security 3 07-19-2002 10:56 PM
Question on voltage settings for A'PEXi Auto Timer Sparks Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-16-2002 09:31 AM
