Welcome to the North American Subaru Impreza Owners Club Wednesday June 3, 2015
Old 08-09-2010, 06:09 PM   #1
cvalianos02
Member#: 253766
2002 wrx
black
Default Trying to get new injectors for my 02 wrx but not trying to spend a lot of money?
I heard 840cc are good for the price but i want other opinions
cvalianos02 is offline   Reply With Quote
Old 08-10-2010, 01:21 AM   #2
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
What are your goals?
STi injectors are cheap and a great start.
Smoke is online now   Reply With Quote
Old 08-10-2010, 02:11 AM   #3
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
Get one of the following, will probably get it to you shipped for $200 or less.
07 STi Injectors
06-07 WRX Injectors
STi JDM Pink Injectors
I'm not sure about 08-10 WRX/STi's though, I'd double check with someone else.
Jubert69 is offline   Reply With Quote
Old 08-10-2010, 02:33 AM   #4
fastwrx25
Member#: 126441
03 bugeye
cut the injector caps, mod your stock injectors.
fastwrx25 is offline   Reply With Quote
Old 08-10-2010, 02:42 AM   #5
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
If he were to do this, he'd have to get them flow tested and most of the time they are going to be all different flow rates.
Old 08-11-2010, 12:37 AM   #6
cvalianos02
Member#: 253766
2002 wrx
black
Ok thanks
Old 08-11-2010, 01:07 AM   #7
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
You "heard" 840cc were good? Good for what? You shouldn't listen to your ricer friends.
Awful advice for the reason that Jubert stated.
It is impossible to help the OP considering he hasn't posted any details whatsoever. I'm shaking my head at some of the answers people have given thus far.
Byzantium is offline   Reply With Quote
Old 08-11-2010, 01:09 AM   #8
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
1600cc ones are good for the price but doesn't mean you should get them.
OP, WHY DO YOU NEED BIGGER INJECTORS?
Old 08-11-2010, 01:32 AM   #9
ToneWrx02
Member#: 239095
2002 Wrx
Run 1000cc get injector dynamic for 460$ run e85 and be happy with new found torq!
Lol I'm actually buying them tonight and alot of other stuff, I have purchased from this store before and they are fantastic. They hook me up with good deals and fast shipping super honest. http://realstreetperformance.com/sto...2257a8e6b82a82
i order it by phone and if you buy alot of things at once they will make you a package deal. And it really is a good deal. And you don't gave to run e85 just get a good tune with it and u will be fine. Or just get jdm sti pinks and be happy with spending same amount. There perfect but I'm aiming for more power in the future with my awesome build.
ToneWrx02 is offline   Reply With Quote
Old 08-11-2010, 02:16 AM   #10
sburck
Member#: 191491
2011 Forester
Ok thanks
Still trying to figure out why you need new injectors, and what you want them to do for you.
Anyways,
If one of them stopped working replace with stock... otherwise ask your tuner.
sburck is offline   Reply With Quote
Old 08-11-2010, 03:17 AM   #11
ToneWrx02
Member#: 239095
2002 Wrx
Anyways,
I looked and I think he is going to do a vf39, uppipe, and tune, so I think he would be good with Sti pinks unless he want to run e85 then 850cc would be good for that.
Old 08-11-2010, 12:27 PM   #12
Crimeboss
Member#: 232043
2005 WRX
Take your stock ones out. Send them and $100 here:
http://www.witchhunter.com/subarumod1.php4
You will now have flow tested reliable 820's.
Crimeboss is offline   Reply With Quote
Old 08-11-2010, 12:31 PM   #13
Byzantium
Member#: 207826
85k 2002 WRX
Ha, if he only sends $100 he will never see them again. If he's only going VF36 as the other person stated, he only needs 550s.
Old 08-11-2010, 05:12 PM   #14
cvalianos02
Member#: 253766
2002 wrx
black
I was thinkin about getting the pink sti injectors but there kind of expensive but if its worth it then ill get those im getting a vf39 and a new fuel pump and a tune so i need the injectors.
Old 08-11-2010, 05:41 PM   #15
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
VF39 + new fuel pump + tune will be fine for any injectors I listed previously.
Old 08-11-2010, 07:02 PM   #16
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Great idea, but maybe better if he were to send them off, especially if he plans on getting some consistency
True unfortunately, much harder than it looks
Good advice, but you do not need 1000cc injectors like a lot of people think just to run E85.. but not a bad place to start either if you plan on going bigger ever, 1000cc's can be great.
Yep!
The pinks go well with the 39, great power with a good tune!
Will
GrimmSpeed is online now   Reply With Quote
Old 08-12-2010, 08:49 AM   #17
Crimeboss
Member#: 232043
2005 WRX
Modding your top feed light blue (3920) $25 each
I don't admit to being a rocket scientist.... However last I knew $25.00 x (4 injectors in his motor) was actually indeed $100 dollars.
Old 08-12-2010, 12:23 PM   #18
Byzantium
Member#: 207826
85k 2002 WRX
Uh, no. That's how much he will buy your injectors for.
modified Subaru top feed
For you folks that down time is an issue, we do have a limited number of matched sets of these injectors for sale. They flow within 1% of each other.... Typically 2 to 4 times closer than the average set because they are tested and grouped together from a large number or injectors.
They are ready to install, and come complete with test data. You can send us your stock injectors back for $100 refund.
Wouldn't be very smart of him to provide a service that he doesn't make any money off of it, esp considering for part of the service (cleaning and flow testing) he already charges $19 /per.
Old 08-12-2010, 01:12 PM   #19
Crimeboss
Member#: 232043
2005 WRX
Wrong. You can buy the ones he already has pre-matched and modded from other peoples cores. However, IF you go to your car. Take yours out (leaving your car down). Mail to him, they charge $100 to mod/test/clean the ones you just sent out. They then send those same ones back to you. What you are thinking and quoted was the option to buy ones already pre matched and done for $250. THEN you send yours back for a core refund of 100. Thus you've just spent an extra $50 for the convenience of not being with out injectors and ones that are better flow matched.
I am not saying that's not ideal. The set you send may not match perfectly with regard to flow rates. However since this kid was looking to get good flow rate at a savings, this is a great deal. They typically aren't that far off anyway. That's if you can go with out injectors in your car for about a week.
Old 08-12-2010, 01:15 PM   #20
Byzantium
Member#: 207826
85k 2002 WRX
And you're still wrong. Persistent bugger aren't you. You're talking to me as though I were an idiot and I hadn't dealt with WitchHunter before. They charge $150-$210 for injector modding. Email Gordon and ask him what he will do for $100.
Old 08-12-2010, 01:24 PM   #21
Crimeboss
Member#: 232043
2005 WRX
*sigh* I just did it a few months ago. Sent him my blue's (as I had pinks already in my car) and they were modded to 820cc for $100 dollars. I was looking at DW's but someone I work with suggested I send in my unused blue's and have it done. Received them back cleaned, modded, and with all new rubber rings and seats. Also had a sheet containing flow data. They've been working great. These are for top feed by the way. Maybe your thinking side feed? Those are $50ea to mod.
It's right here:
"Modding your top feed light blue (3920) $25 each "
And you're still wrong. Persistent bugger aren't you. You're talking to me as though I were an idiot and I hadn't dealt with WitchHunter before. If he only sends $100 they will call him and ask what he wanted. They charge ~$180 for injector modding.
new graphics for my 02 WRX GooberTard Member's Car Gallery 36 12-09-2008 02:57 PM
Where to get headlight "eyelids" for an 02 WRX? Your opinion on them madmax02 Interior & Exterior Modification 7 04-04-2008 05:35 PM
My new tires for my 02 wrx TheNookie Off-Topic 6 04-03-2006 10:47 AM
Where to get 15" wheels for an 02 WRX Silver Bullet 02 Motorsports 20 06-04-2004 01:01 PM
