Old 10-10-2012, 12:03 PM   #26
KNS Brakes
NASIOC Storefront Vendor
Member#: 125739
2015 WRB WRX
Need Brakes? 919.420.0021
We made some to work w/ the SVX rotor drilled to 5 x 100.
Only a few people asked about it.
Making it is no problem at all - selling it is another story completely.
KNS Brakes is offline   Reply With Quote
Old 10-11-2012, 02:18 PM   #27
SW21MR2
Member#: 60135
2005 Kona Stink-E
I must say, if there was a bracket to use the z32 aluminum calipers with STi or LGT rotors, I probably would have gotten them.
SW21MR2 is offline   Reply With Quote
Old 10-15-2012, 06:40 PM   #28
Purpose_Built
Member#: 222879
2003 WRX 60-1/td06h
Hybrid/6spd
I'm working on a cheap 350mm and 380mm solution using 6 piston calipers for the front. The rotors will be the most expensive part if they are made for this application using aluminum hats, otherwise a redrilled rotor could be used.
Cant decide on the calipers yet but i do need someones old busted WRX hub for measurements. I'll pay shipping of course and probably make more than one set of brackets which you will get at cost.
Purpose_Built is offline   Reply With Quote
Old 10-16-2012, 09:42 AM   #29
classicaddict
Member#: 220619
04 wrx wagon
This is over kill. Not to sound rude but there is ABSOLUTLY zero need for a six piston caliper on any car unless you expect to be hitting high triple digit speeds on a regular basis.
Pretty sure I spoke with you over the phone and you suggested using the lgt rotors. Iirc you used svx because the lgt dust existsat the time. If you made brackets for the lgt rotors they WOULD sell. Pair that with an h6 rear and you have fade free brakes at the track all day
classicaddict is offline   Reply With Quote
Old 10-16-2012, 10:02 AM   #30
KNS Brakes
Member#: 125739
2015 WRB WRX
I can get a few made easily.
I need a caliper to mess with. Should I get an AL or Cast Iron? I think the AL one are getting rare.
-Ken
Old 10-16-2012, 10:19 AM   #31
classicaddict
Member#: 220619
04 wrx wagon
-Ken
I don't doubt that. And they are known to flex anyway, we don't need a flexing caliper to possibly cause more pad knock back of the taper wheel bearing cars. Bit either way they are the same measurements.
Old 10-16-2012, 10:20 AM   #32
classicaddict
Member#: 220619
04 wrx wagon
Is there a difference in master cyl from sliding caliper wrx's to the 06-07?
Old 10-16-2012, 04:57 PM   #33
SW21MR2
Member#: 60135
2005 Kona Stink-E
Well, what's really the driving force behind this? When I think of this particular brake mod, I look at it as a poor man's upgrade costing similar or less to Subaru 4 pots, but benefit from a larger rotor.
I can see where there would be lack of motivation in doing this if it cost similar to second hand STi Brembos.
Old 10-17-2012, 10:18 AM   #34
classicaddict
Member#: 220619
04 wrx wagon
Wrx 4 pots, useless ricer upgrade. You gain very little if anything at all other than a large selection of pad types.
Sti brembos, great, forced to use 17+ inch wheels, very expensive.
Z32+lgt rotors. Can fit 16's, Same pads as Subaru 4 pots, calipers can be found for $150 for the set, rotors about $120. Rotors are a good bit larger than Wrx OE, can handle more heat, not stuck with only 17 inch plus wheels.
Old 10-17-2012, 10:53 AM   #35
KNS Brakes
Member#: 125739
2015 WRB WRX
I ordered some calipers from Cardone. $69/each + core.
I have my old proto brackets from the LGT setup so those should be a good starting point.
Calipers - $200
Brackets - $150ish at least
- That's $200 less than Brembo's give or take.
Old 10-17-2012, 11:26 AM   #36
SW21MR2
Member#: 60135
2005 Kona Stink-E
Well, Ken, I may ditch my Racing Brake 4 pot fronts just to try this out for isht and giggles.
Old 10-17-2012, 11:55 AM   #37
classicaddict
Member#: 220619
04 wrx wagon
The only "modification" that needs to be made is Subaru brake lines use a banjo bolt. Nissan uses a flare nut. Just get a small easy out and it will pop the brass flare out of the Nissan caliper. This takes seconds to do. I also sanded down the casting surface with sand paper and a block of wood to ensure the banjo washer sealed correctly.
Old 10-17-2012, 11:59 AM   #38
classicaddict
Member#: 220619
04 wrx wagon
To save on cost and parts being left on the shelf you could sell them as "made to order"
Also I would start an interest thread about these. This coming from a reputable vendor would get the ball rolling and help with people's general distaste of new ideas around here.
Old 10-17-2012, 12:09 PM   #39
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
It's hardly a "useless ricer upgrade". The advantages of fixed, opposed piston calipers vs. sliding calipers are well known and proven. There is no question, having open tracked my car repeatedly with both setups, that the 4-pots are better than the 2-pot sliders. And that's not an observation that's limited to me personally, nor is it an observation that is limited to the Subaru platform (re: 2-piston PBR Cobra caliper vs. 4-piston Brembo Cobra R caliper on same rotors).
If you can get an affordable way to make the Z/2.5GT setup work, that's great. I might even change my setup when it's time to replace my DBA rotors. But there's no need to go overboard trying to make your case about why it's better than the other options out there.
... and help with people's general distaste of new ideas around here.
I assume by "around here" you mean around the planet? Because there used to be a vendor that made adapter brackets, and they stopped doing so. Presumably, they didn't stop making them because interest was so high that they just couldn't keep up with production and didn't know what to do with all the money they were making.
Pat Olsen
Old 10-17-2012, 12:32 PM   #40
KNS Brakes
Member#: 125739
2015 WRB WRX
That's right - I forgot about that.
Old 10-17-2012, 12:44 PM   #41
SW21MR2
Member#: 60135
2005 Kona Stink-E
Will the banjo bolt thread in there just fine?
Old 10-17-2012, 01:42 PM   #42
classicaddict
Member#: 220619
04 wrx wagon
Pat Olsen
I don't track my car as I don't make enough expendable income to justify doing so, nor do I honestly have much intention of running this setup personally. But I can not see much difference between a fixed and sliding caliper using the same rotor and same pad compound other than more clamping force via mechanical movement, but not enough improvement to justify tue price people want for those calipers.
Also, my comment was aimed more so towards the fact that people seem to do that swap simply for looks alone.
As for the global Z brackets. Correct me if I am wrong but those were primarily over seas, no? I can't remember what rotor they used but I seem to recall rotor machining being needed? After all of that you are close to an Sti swap cost. Machine cost, over seas shipping cost, z32 calipers were not nearly as cheap either. Because of the hassle and the fact their domestic market had a plethora of options (both oem and aftermarket) readily available is the reason they died off.
Onto the topic of fear of change or something new. All I personally ever see if 80% of the crowd following the status quo, best example. "dude! That's so dumb! Why would you get rid of your access port IT'S AMAZING ZOMG LIK TOTS MA GOATS!" oh yea? My open source cable cost me $50, sold the ap for $200, flashed a known good stg2 base map, gained substantially more power, recorded more agreeable af mixtures, went from 19mpg to 25mpg.
Old 10-17-2012, 01:42 PM   #43
classicaddict
Member#: 220619
04 wrx wagon
Yes. Same size and pitch.
Old 10-18-2012, 09:38 PM   #44
ladyinred05
Member#: 135978
Is this for the fronts only or all corners?
ladyinred05 is offline   Reply With Quote
Old 10-18-2012, 09:52 PM   #45
ToddMcF2002
Member#: 135007
2014 STi Hatch
Crystal Black Silica
Personally I'm dying for some alternatives. Brembo's are a seriously flawed product. On the track the dust seals burn up. The only sleeved bolt seems to be the banjo. The mounting holes are prone to seizing and stripping. The bleeders likewise. Even replacing the OEM bleeder screws are difficult ($65 each... really?) A single rear 2 piston caliper is $700 from the dealer. The OEM rebuilt kit is 100 for just the fronts.
I'm in the middle of rebuilding mine and I'm really not happy. I think I should have gone with Wilwood. Screw dust boots!
ToddMcF2002 is offline   Reply With Quote
Old 10-19-2012, 09:08 AM   #46
SW21MR2
Member#: 60135
2005 Kona Stink-E
http://forums.nasioc.com/forums/show....php?t=1567707
It appears the Nissan 2 pot rears will bolt up with an adapter or 2 pot backing plate, but it sits out further. I'm sure another bracket could be made that would make the caliper sit in about 3mm closer to the hub to correct that. Either that or find another rotor.
Old 10-19-2012, 12:52 PM   #47
KNS Brakes
Member#: 125739
2015 WRB WRX
I've got the calipers, my old SVX sized bracket, and a knuckle and of course a rotor so I can start fitting this up.
Old 10-21-2012, 01:45 PM   #48
xjustinx
Member#: 196920
03 Wrx
I def want in when these are made! Group buy maybe??
xjustinx is offline   Reply With Quote
Old 10-21-2012, 05:01 PM   #49
slamdspec
Member#: 267863
1998 Outback
I'd be down for a group buy. I've had the calipers. I've just been trying to find some brackets.
slamdspec is offline   Reply With Quote
Old 10-22-2012, 02:59 PM   #50
KNS Brakes
Member#: 125739
2015 WRB WRX
Working on it as soon as possible
WTT WRX front rotors/brackets for RS rotors/brackets + WTB WRX rear caliper brackets Jard MAIC Private Classifieds 9 11-24-2009 09:38 AM
WTB: 02+ WRX Front Caliper Brackets, H6 Rear Caliper Brackets JDMFLCL Private 'Wanted' Classifieds 4 10-30-2009 01:19 PM
WTB: Front WRX caliper bracket and rear Legacy caliper bracket 92XJET MAIC Private Classifieds 0 11-20-2007 10:37 PM
WTT: I want YOUR Rs rotors and caliper bracket for MY Wrx caliper bracket and rotors scobaru MWSOC Private Classifieds 6 12-10-2006 08:02 AM
WTB: WRX Caliper Brackets + H6 Caliper Brackets Krelkor Private 'Wanted' Classifieds 11 07-12-2004 03:28 PM
