Old 11-13-2012, 02:59 PM   #51
slamdspec
Member#: 267863
1998 Outback
any updates on this?
slamdspec is offline   Reply With Quote
Old 11-23-2012, 03:37 PM   #52
xjustinx
Member#: 196920
03 Wrx
Bump??
xjustinx is offline   Reply With Quote
Old 12-06-2012, 03:02 PM   #53
Purpose_Built
Member#: 222879
2003 WRX 60-1/td06h
Hybrid/6spd
Originally Posted by classicaddict View Post
This is over kill. Not to sound rude but there is ABSOLUTLY zero need for a six piston caliper on any car unless you expect to be hitting high triple digit speeds on a regular basis.
Pretty sure I spoke with you over the phone and you suggested using the lgt rotors. Iirc you used svx because the lgt dust existsat the time. If you made brackets for the lgt rotors they WOULD sell. Pair that with an h6 rear and you have fade free brakes at the track all day
A 6 piston caliper is pretty cheap and just as easy to mount as a 4 piston. Also just because its a 6 piston caliper doesnt mean its capable of scrubbing speed from high speeds constantly. The 135i and a few others have 6 pistons and the pistons melt if they see hard use.
If i am going to go through the process of upgrading my brakes then the real question is why not?
Calipers are about 500 new or about 700 for Porsche 6 pot radials used
Pads 130 new
Z06 350mm Rotors about 200 new for standard construction or another brand for the Porsche fitment
Custom stainless lines 60 @ hydraulic shop
Rotor pattern re-drill 100 for non STI
Steel brackets 6 hours or so worth of work if they arent radial mounts and less if they are radials.
Hub centric rings for the rotors x2 $30
To me this is just better than spending all that money for Sti Brembos or buying some cheap kit that wont hold to any kind of abuse.
Purpose_Built is offline   Reply With Quote
Old 12-11-2012, 06:04 PM   #54
slamdspec
Member#: 267863
1998 Outback
just bumping this to see if theres any news.
Old 12-17-2012, 11:25 PM   #55
xjustinx
Member#: 196920
03 Wrx
Any news WRXBrakes?
Old 12-18-2012, 10:59 AM   #56
KNS Brakes
NASIOC Storefront Vendor
Member#: 125739
2015 WRB WRX
Need Brakes? 919.420.0021
Got delayed a bit sorry.
Designer is on it now so we should be making a prototype for fitment within a week or so.
KNS Brakes is offline   Reply With Quote
Old 12-18-2012, 04:39 PM   #57
slamdspec
Member#: 267863
1998 Outback
^awesome. i guess now i can get on rebuilding my calipers
Old 12-19-2012, 06:42 PM   #58
xjustinx
Member#: 196920
03 Wrx
Bossin. Are front and rear brackets being made up?
Old 12-19-2012, 07:27 PM   #59
KNS Brakes
Member#: 125739
2015 WRB WRX
Old 12-19-2012, 08:30 PM   #60
classicaddict
Member#: 220619
04 wrx wagon
sooooooo much better than what i had. the one i bought used some janky looking hardware and a random number of washers as spacers. this looks rock solid.
classicaddict is offline   Reply With Quote
Old 12-21-2012, 02:22 PM   #61
KNS Brakes
Member#: 125739
2015 WRB WRX
I can have these ready in a few weeks.
I need about 5 players to start the game.
Old 12-21-2012, 02:58 PM   #62
slamdspec
Member#: 267863
1998 Outback
Im in. What are we looking at pricewise?
Old 12-21-2012, 03:14 PM   #63
KNS Brakes
Member#: 125739
2015 WRB WRX
$140/pair for the first buyers - minimum 5.
That gets the second prototype made so we can triple check and adds new good hardware.
Retail after that -$160/pair I think unless volume is much higher than I thought.
I do have access to everything else needed. Rebuilt cardones calipers, and of course pads/rotors etc.
Old 12-21-2012, 03:24 PM   #64
KNS Brakes
Member#: 125739
2015 WRB WRX
Probably have to stop the pricing in here and take it to the group buy section or vendor announcement.
Old 12-21-2012, 04:59 PM   #65
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Curious...anyone use these? Wha is the front rear balance like? How much are the calipers and pads? What size wheels are needed? Standard or custom brake lines?
aboothman is offline   Reply With Quote
Old 12-21-2012, 05:26 PM   #66
jamal
Member#: 71875
98 Legacy GT
my wheels fit
Nice. Think I might go this way instead of the Subaru 4-pots once I wear out my current stuff. Think they'll fit under a 16" RS wheel?
If they piston sizes are the same as the Subaru caliper the bias should be pretty close to WRX 2-pots.
jamal is offline   Reply With Quote
Old 12-21-2012, 05:46 PM   #67
KNS Brakes
Member#: 125739
2015 WRB WRX
The rotors are LGT rotors - so 316mm by 30 mm. Much more heat mass.
The effective radius grows by about 7.5 % so front brake torque will increase.
Run it with the H6 Set up in the rear.
Probably needs 17's though.
Old 12-21-2012, 08:27 PM   #68
slamdspec
Member#: 267863
1998 Outback
Pricing is good with me. Couple questions. What year lgt rotors should I be looking for? Would the h6 upgrade be better then the 2pots in the rear? I have a full set of z32 calipers and was planning to run them all around.
Old 12-21-2012, 08:45 PM   #69
xjustinx
Member#: 196920
03 Wrx
Im in for a pair
Old 12-22-2012, 04:06 AM   #70
jamal
Member#: 71875
98 Legacy GT
my wheels fit
Originally Posted by KNS Brakes View Post
T
If the pistons are the same size as the Subaru 4-pot that works out to almost zero change in bias (1% less). The 4-pot has smaller pistons than the 2-pot.
Old 12-26-2012, 12:53 PM   #71
KNS Brakes
Member#: 125739
2015 WRB WRX
I was just going on the increase in rotor size from dia 294 to 316 mm.
Old 12-26-2012, 12:54 PM   #72
KNS Brakes
Member#: 125739
2015 WRB WRX
Any 05-09 LGT front rotor.
The rear Z32 calipers do bolt on but there is current;y not a convenient rotor solution or bracket solution that I know of.
Old 12-26-2012, 04:09 PM   #73
classicaddict
Member#: 220619
04 wrx wagon
Correct me if I'm wrong but the lgt uses 16 inch wheels no? So assuming you use a 16 with enough spoke clearance like the rs wheels they should fit. When I had this setup I was able to put my oem 04 wheels on but the caliper interfered with the spokes.
Old 12-31-2012, 04:12 PM   #74
04jaxwrex
Member#: 82762
2005 Saab 9-2x Aero
Desert Silver
FINALLY! Im in for a pair! I want meow! cant wait!
04jaxwrex is offline   Reply With Quote
Old 01-03-2013, 11:02 AM   #75
04jaxwrex
Member#: 82762
2005 Saab 9-2x Aero
Desert Silver
any update
WTT WRX front rotors/brackets for RS rotors/brackets + WTB WRX rear caliper brackets Jard MAIC Private Classifieds 9 11-24-2009 09:38 AM
WTB: 02+ WRX Front Caliper Brackets, H6 Rear Caliper Brackets JDMFLCL Private 'Wanted' Classifieds 4 10-30-2009 01:19 PM
WTB: Front WRX caliper bracket and rear Legacy caliper bracket 92XJET MAIC Private Classifieds 0 11-20-2007 10:37 PM
WTT: I want YOUR Rs rotors and caliper bracket for MY Wrx caliper bracket and rotors scobaru MWSOC Private Classifieds 6 12-10-2006 08:02 AM
WTB: WRX Caliper Brackets + H6 Caliper Brackets Krelkor Private 'Wanted' Classifieds 11 07-12-2004 03:28 PM
