Old 08-09-2010, 11:30 PM   #1
bhilly82
Member#: 254417
09 Impreza
Peperika
Default new 09 Impreza, what mods should I do
I am not looking to make alot more power all i want is a little more exhaust sound and a better drop in filter. So my question is should i go with a full cat back or just get 2 mufflers welded on in place of the factory mufflers. There is a guy on ebay selling magnaflow cat backs for $510. Would going with a full cat back give me better fuel mileage over just 2 mufflers or would it be the same. That cat back is 2.5'' from what i have read you want 2.25-2.5'' with the n/a. Also should i go with the avo panel filter or the apexi.
bhilly82 is offline   Reply With Quote
Old 08-10-2010, 01:09 AM   #2
09suby
Member#: 222590
2009 Impreza 2.5i
Spark Silver Metallic
You shouldn't just put mufflers, it wouldnt make a difference performance wise, just sound. There are a few people on the forum running the AVO. There is actually a thread on High-flow panel for the 08-10. Also do you a manual or automatic. You could get a tune on 93 octane if you have a manual, and if you have an automatic they are in the process of supporting us for tuning. You could take a look at the thread named "the bad boys of phat botti tuning"
09suby is offline   Reply With Quote
Old 08-10-2010, 01:12 AM   #3
09suby
Member#: 222590
2009 Impreza 2.5i
I actually have a 2009 impreza, and am doing a full header-back. I also have an intake, and getting a tune on 93 octane.
Old 08-10-2010, 01:29 AM   #4
bhilly82
Member#: 254417
09 Impreza
Peperika
mine is a auto, the wife drives it the most so we got the auto for her. So i think i will go with a avo panel filter and the full cat back.
Old 08-10-2010, 01:54 AM   #5
09suby
Member#: 222590
2009 Impreza 2.5i
OK.I also have an auto. I know you probably heard a lot of negative things about k&n filters, but i have personally used them in vehicles for thousands of miles without issues. I actually had a k&n filter that I used for about 5,000 miles. I don't use it anymore since I have an intake. I would sell it you for like $25 obo. PM if you,re interested.
Old 08-10-2010, 10:12 AM   #6
Ogden
Member#: 1748
'09 Outback Sport
OBP over DGM
Read the NA exhaust thread "sticky" up above. It will have a lot of good information in it. If all you want is sound, then mufflers will do the trick. You could go with an used OEM WRX cat-back. It won't cost much (mine cast me $70), but it also will only give you a little more sound.
Still you could start with the OEM WRX cat-back, so you get a boost to 2.25-2.5 inch piping, then add the mufflers to that.
I've got an AVO panel filter an like it alot.
While you are modding, I would get a rear sway bar. You don't have one stock, and it makes a profound change in the car's handling. If you go with the OEM WRX sway, you can get one for around $100. You may need endlinks if it doesn't come with them, and you will need to get the mounting brackets and bolts from your dealer. It's a pretty easy DIY. For me, I would do this before the exhaust. It's a much bigger bang for your buck.
You can also get a rear sway bar from a lot of aftermarket manufacturers, but it will cost more.
Just as a note, the WRX and 2.5i rear sway bars are interchangelable, but the front ones are not. You'll have to get a 2.5i specific bar if you want to upgrade your front sway bar.
Ogden is offline   Reply With Quote
Old 08-10-2010, 07:51 PM   #7
msingell
Member#: 153097
2012 CRZ
PWP
rallitek 4eat trans bushing! the wife'll hate it, it creates a fair amount of Noise Vibration Harshness......
msingell is offline   Reply With Quote
Old 08-11-2010, 12:35 AM   #8
bhilly82
Member#: 254417
09 Impreza
Peperika
What intake did you use, i cant to seem to find any.
Old 08-11-2010, 05:50 AM   #9
09suby
Member#: 222590
2009 Impreza 2.5i
I actually have a custom intake that I built myself. But cosmoracing sells them, but they are currently out of stock, and avo also has one.
Old 08-11-2010, 05:07 PM   #10
bhilly82
Member#: 254417
09 Impreza
Peperika
Doesn't the stock air box get cold air from right under the hood? were the scoop looking thing do a good job, or is the avo option really all that much better then a avo panel filter. seems like it would suck more hot air in then the stock one, or is it all the same just with a open filter you get the sucking sound.
Old 08-11-2010, 05:51 PM   #11
09suby
Member#: 222590
2009 Impreza 2.5i
I don't know about the avo one, but I used to have a K&N panel filter, and I changed out to a custom intake, and it makes huge difference after 3500rpm.
trade in 02 wrx for brand spanking new 05 sti, what mod should i do first? SilverCWestWRX Newbies & FAQs 14 08-11-2004 05:01 PM
buying a wrx what mods should i do frist black Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 11-08-2002 10:57 PM
Recently got a wrx, what mods should I do first. StickyFinguz Newbies & FAQs 6 07-15-2002 01:32 PM
What mods should I do and when? AudiGuy General Forum Archive 7 08-09-2000 07:02 PM
