Closed Thread
Old 06-02-2008, 07:16 PM   #1
szeny
Member#: 81383
07 335i e90
TiAG/Dakota Black
Default Blower motor/relay problem?
Was driving home from Vegas and had FAN only on (no ac) and started smelling burnt electrical. Slowed down to pull over and a puff of smoke came from under the glovebox. Now the blower/ac/vent does not work.
Are there relays or something I can check or is it the blower motor? Any help works. Thanks.
szeny is offline
Old 06-03-2008, 12:27 AM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
The problem may be with the motor or it could be with the speed resistors. Since you had some burning going on the trouble should be pretty obvious if you check things out.
Cougar4 is online now
Old 06-03-2008, 01:43 PM   #3
szeny
Member#: 81383
07 335i e90
TiAG/Dakota Black
Well ya... Im just wondering WHAT to check
szeny is offline
Old 06-03-2008, 05:51 PM   #4
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
check any wires that connect to the blower, and also open the cover for the in cabin air filter (remove it if you got it) and smell for a burnt smell from in there.i can check blower motor specs tonight at work if i remember or tomorrow.
ProdriveDreams is offline
Old 06-03-2008, 10:41 PM   #5
Cougar4
Member#: 53443
Winestone
I recommend you check the speed resistors and the motor itself. The resistor can be located from the connection between the motor and the resistor block. To check the motor try connecting 12 volts directly to the motor.
Old 06-04-2008, 12:48 AM   #6
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
duh good call, long day at work has me thinking ass backwords.
+1 for the above statement. Also the resistor is intigrated into the fan control switch on the HVAC, although it LIKELY (doesnt rule it out entirely) isn't the resistor box if the blower doesn't work even when the switch is on 4.
Old 06-04-2008, 02:11 AM   #7
szeny
Member#: 81383
07 335i e90
TiAG/Dakota Black
Cool thanks guys ill givew this a try
szeny is offline
Old 07-05-2010, 02:35 PM   #8
626Wagonizer
Member#: 249535
2002 WRX EJ20
Pearl Blue
pretty old post but hopefully i get some help. My blower in my 02 bugeye wagon stop blowing this morning. The ac works and climate controls work but no air comes out. I checked the fuses under the driver side and pulled every single one of them and all are fine. Now what i have read theres this relay i got to check, but i got no clue where is at and how it looks. If this is the problem how would i know the relay is bad and how much would it cost to replace it. Oh and where can i buy it? thanks guys..
626Wagonizer is offline
Old 07-05-2010, 09:13 PM   #9
Cougar4
Member#: 53443
Winestone
If you need a relay I think you can get one at a parts store or the dealer for sure. Check to see if you have voltage getting to the motor. If you do then the relay is ok and the problem is most likely with the resistor pack. It will be mounted in the ducting near the motor.
Old 07-06-2010, 12:39 AM   #10
626Wagonizer
Member#: 249535
2002 WRX EJ20
Pearl Blue
oh ok.. what i been doing is tapping this part that i think is the relay. Its located right in the bottom of the passenger side next to the blower and it has a plug plugged directly on it. Im guessing thats the relay. I found out that once i give it a quick tap the blower starts working. So i want to replace whatever part is not working before the tapping stops working....
Old 07-06-2010, 11:20 AM   #11
Cougar4
Member#: 53443
Winestone
It sounds like that is the resistor pack for the speed control. If it is mounted on the air ducting then that is what you need to replace. The relay is located by the dash fuses I believe.
Old 07-06-2010, 11:54 PM   #12
626Wagonizer
Member#: 249535
2002 WRX EJ20
Pearl Blue
yeah your right on that one! thanks ill make sure what it is and replace it
Old 08-10-2010, 11:06 AM   #13
626Wagonizer
Member#: 249535
2002 WRX EJ20
Pearl Blue
ok so i checked the resistor pack and unplugged it while the blower was on speed 4. It continue to blow but at really low speed! i kept tapping the resistor part and underneath the actual motor and it speeds up and slows down. Sometimes it just stops. Could this be a much bigger problem than the resistor itself? anyone have similar issues or ideas what my next step should be?? thanks please help!!!
Closed Thread
Blower Motor Relay Location? pdpdad Electrical & Lighting 2 04-17-2008 02:55 PM
blower motor relay location? 25thIMPREZA Service & Maintenance 1 07-22-2006 04:02 PM
Blower Motor on heater Problem slowme Electrical & Lighting 5 11-02-2004 10:17 PM
('93-'01) blower motor? Kalins1 Impreza Forum 2 09-28-2001 09:42 AM
