Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 06-19-2002, 06:44 PM   #1
tydon
Member#: 12224
2000 RS;Spec Miata
Del Sol Si
Default broken voltage clamp = no prob.
heres the deal. I have a ludespeed turbo kit on a my 2000 rs. the voltage clamp was malfunctioning, making it impossible to drive my car. BTW, it was only when it the air temp was hot that the VC wouldnt work. anyway, i unhooked the VC. car ran fine, but i had to stay out of boost. one time it boosted, and the ecu immediately cut power.
here is the curious part. iver been waiting to get the VC covered under warranty, and i accidentally boosted again. but wait, there was no power cut. the bottom line is, with no voltage clamp, my car still runs fine up to 5psi of boost. i have no idea how or why this is, but it has been running great for a couple of days since i realized this.
tydon is offline   Reply With Quote
Old 06-19-2002, 07:25 PM   #2
ac_gohan
Member#: 1903
2000 2.5 RS-T coupe
T3/04 Link'd 2 10 PSI
Its because of the MAP sensor. It measures the manifold air pressure. If it is cutting off at 5 psi then it is working perfetly. See when you are running NA and you redline it to 6200 you get a fuel cut. The voltage is IIRC 4.1V at fuel cut. But when you turbo it, the manifold pressure reaches the maximum for the MAP sensor alot earlier because you are boosting. As long as you run the car under vacumn you should be fine. Get another voltage clamp if you want to boost.
Andy
ac_gohan is offline   Reply With Quote
Old 06-19-2002, 08:35 PM   #3
kaos200
Member#: 2692
Andy
read his post, he said he boosted up to 5psi, no VC, and it ran fine.
kaos200 is offline   Reply With Quote
Old 06-19-2002, 09:12 PM   #4
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
I've heard of several flukes like this before, personally I attribute them to a sensor that doesn't like reading beyond certain ranges or is scaled incorrectly. I would bet that it'd cut if you spiked around 7psi or something. If not... well, be happy with your bastard child of an ECU.
Old 06-20-2002, 02:50 PM   #5
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
yea, I have a friend whose turbo RS is like this too. Don't understand why
cRayZee is offline   Reply With Quote
voltage clamp spgavin Normally Aspirated Powertrain 0 10-04-2001 01:51 AM
Proper voltage clamp? SubaFastR Normally Aspirated with bolt-on Forced Induction Powertrain 3 09-02-2001 05:40 PM
Check valve vs voltage clamp? wcbjr Normally Aspirated with bolt-on Forced Induction Powertrain 1 08-28-2001 02:54 PM
voltage clamp, or check valve??? LVSUBARU Normally Aspirated with bolt-on Forced Induction Powertrain 15 08-24-2001 11:50 PM
Voltage clamp for MAP fix? NOT! JC SPORTS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-27-2001 09:23 PM
