Old 08-10-2010, 02:07 PM   #1
Cowabunga
Member#: 64086
Default Springs sitting okay?
Since I did this by myself, I'm nervous I may not have them seated correctly, could you guys give me a confirmation? For the record, no clunking. While the bottom moved away from the notch maybe 3/4", it's the top that concerns me. The spring is not 100% flush with the top hat, and I'm not sure if that's how it's supposed to be. It didn't seem like it was going to recess all the way into the spring though so that the top part of the spring is flush all the way around. Does it look ok to you guys?
Anyway, I took pictures. Does it look okay to you guys?
Cowabunga is offline   Reply With Quote
Old 08-11-2010, 08:27 AM   #2
Cowabunga
Member#: 64086
Also, theres no rubber isolator needed at the bottom right?
Old 08-11-2010, 03:02 PM   #3
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Any chance the spring is upside-down? It's been a while since I've messed with stock springs/dampers, but I seem to recall that one end was smaller than the other.
I imagine once the weight of the car is on the assembly that the spring will seat itself fully.
On a somewhat unrelated note, if you put a RETURN between each of the images they won't run together.
Pat Olsen
Old 08-11-2010, 03:06 PM   #4
Cowabunga
Member#: 64086
Pat,
These are the fronts, which you are correct they are a different size top to bottom. The bottoms are the bigger, so as far as that goes they are in the right position.
I added the RETURN, so it's easier to distinguish pictures...
Old 08-12-2010, 02:39 AM   #5
that one legacy
Member#: 103665
what year is your car? cause that looks nothing like the springs or the mounts on either of my cars.
that one legacy is offline   Reply With Quote
Old 08-12-2010, 08:04 AM   #6
Cowabunga
Member#: 64086
2008 LGT.
FS : (IL) front sti strut mounts, eibach sportline springs ilikebmx999 Suspension/Brakes/Handling 14 10-17-2010 07:39 PM
V6 sti springs - sitting too low Hitokiri Brakes, Steering & Suspension 4 04-11-2004 02:22 AM
Whiteline Springs sitting funny Turbo GC4 Brakes, Steering & Suspension 1 03-14-2003 09:41 AM
Trip to the dealer... springs upsidedown??? wich way do they sit?? BlackWagon Brakes, Steering & Suspension 0 07-29-2002 11:17 PM
update: sit springs are not quite so harsh now that jmott Texas Impreza Club Forum -- TXIC 4 07-26-2002 04:57 PM
