Welcome to the North American Subaru Impreza Owners Club Wednesday June 3, 2015
Old 08-10-2010, 06:34 PM   #1
Christianl
Member#: 108727
Default Transmission Swap (95 Legacy to 96 Legacy)
I have a torque converter and 2nd gear that's dying on my 95 Subaru Legacy LSI Wagon. I managed to find a MY-96 Legacy 2.5GT sedan full transmission with 5000km. My question is if it'll fit directly? Where can I find the information and such? Please help?
Christianl is offline   Reply With Quote
Old 08-10-2010, 07:49 PM   #2
mike-tracy
Member#: 135290
2000 Impreza
BRP
No, the 96 GT had a 4.44 final drive, and your 95 LSI had 4.11, and the TCU's are different.
mike-tracy is offline   Reply With Quote
Old 08-10-2010, 09:30 PM   #3
kirbykirb
Member#: 183596
2005 WRX/9-2x
Obsedian Black Pearl
Yes it will fit, if you can try to get the rear Diff from the 96'. you don't need it but it will increase performance.
It will fit directly, you'll have to remove the bolts that hold the torque converter in place to the engine flex plate, and then the the exhaust has to come off. from headers to muffler. After that you'll remove the driveshaft and then its simple. Remove the dogbone that holts the transmission to the cars chassis, then 4 bolts that hold it to the engine (starter bolt, passanger side bolt and two nuts on the bottom) after that, you undo the harness connectors, and the shifter (which has a little pin; DO NOT LOOSE IT.) Then undo the CV joints and it will fall out
kirbykirb is offline   Reply With Quote
Old 08-11-2010, 04:33 AM   #4
mike-tracy
Member#: 135290
2000 Impreza
BRP
Incorrect, you cannot run this way, unless you have the FWD fuse in. You will literally overheat your tranny as it constantly tries to compensate for a difference in load front to rear.
2ndly, have you checked the service manual for his 95 LSI to see if the wiring harness is the same? 95 was a transitional year with all kinds of odd parts ranging from OBD-I to OBD-II to hybrid wiring for the compared to 96+. Does his tranny have the older or newer style connectors? Etc.
Old 08-11-2010, 03:45 PM   #5
kirbykirb
Member#: 183596
2005 WRX/9-2x
Hmmm so it will overheat... no idea about that. I thought it would just be a mismatched final drive that would give off decreased performance; not that it would ultimately destroy the transmission.
As for the service manual; I've done the swap before with a friend of mine but we had the diff as well cause it was included free so we elected to change everything out to make things much more simple and it was direct bolt in. 95 was a change year; but considering how the JDM 2nd gen legacy was in production before the USDM side alot did carry over.
Old 08-13-2010, 08:43 PM   #6
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
Hmmm... so it will overheat... No idea about that. I thought it would just be a mismatched final drive that would give off decreased performance; not that it would ultimately destroy the transmission.
Kirby -
In an all wheel drive Subaru the Final Drive gear ratio exists both in the rear differential and in the "transaxle" that drives the front wheels and is part of the transmission. If the front and rear axles are operating with different final drive gear ratios the transmission is in effect having to attempt to compensate for this difference which it reads as "wheel slippage". While the transmission is designed to do this for a limited traction situation, it isn't capable of doing so continuously.
Jonathan is offline   Reply With Quote
OK to Swap Rear Suspension from 98 Forester to 96 Legacy AWD Wagon? Bullwinkle Legacy Forum 8 01-23-2011 03:55 AM
transmission swap MA2 Newbies & FAQs 1 08-10-2010 02:04 PM
91-94 legacy EJ22T(91-94 legacy) Turbo only swap to 97 2.2 impreza?? Impreza_chic97 Subaru Conversions 3 10-29-2006 11:25 PM
considering swap, 95 legacy L skoaq Subaru Conversions 13 01-09-2006 03:41 PM
Wrx drivetrain swap in to 96 legacy serious Subaru Conversions 0 05-04-2003 05:04 PM
