Old 08-10-2010, 10:10 PM   #1
mbandi
Member#: 212393
05 2 Saab 9-2x's
Desert Silver & Black
Default Calling all engine build Guru's. Please help!
I was in the process of buildng my ej20 in my 02' WRX. I upgraded to an 09' Nitride Coated crankshaft, ACL bearings, new pistons, etc. After I installed the timing belt, I attempted to turn the engine over by hand to make sure everything was ok and could only get 170 degress of the crankshaft turning before it stopped. After tearing things apart I realized that the pistons are hitting the heads.
I was informed that the EJ crankshafts were interchangeable from 99 up. I'm not sure if that is the case.
Can I compensate with different Head gaskets? Am I completely screwed and need to completely disassemble the engine the rest of the way and buy an ej20 crank.
Please help. I'm at my wits end!
MB
mbandi is offline   Reply With Quote
Old 08-10-2010, 10:38 PM   #2
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
You have a 79mm (2.5) stroke crank but need a 75 mm crank (2.0 and 2.2).
Old 08-10-2010, 11:08 PM   #3
sorrowfulkiller
Member#: 170439
I <3 Lamp
what reddevil said, also you should be looking at the 04-05 wrx crankshafts not 06+ I don't believe the 04-05 are nitrided though, someone correct me if I'm wrong.
sorrowfulkiller is offline   Reply With Quote
Old 08-10-2010, 11:23 PM   #4
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
did you buy normal EJ20 pistons and rods?...if so, reddevil is 100% correct. The only nitrided 75mm stroke cranks are from the JDM EJ207 engines, I belive only the spec C....could be all sti's can't recall.
I get my own cranks treated. USDM EJ20 cranks aren't treated.
Old 08-10-2010, 11:33 PM   #5
MartinSTi05
Member#: 145145
2006 wrx STi
You could also get pistons with a 2mm raised comp height that will accommodate the increased stroke and have yourself a 2.1L
MartinSTi05 is offline   Reply With Quote
Old 08-10-2010, 11:35 PM   #6
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
The cranks are interchangeable in that they fit in the case and will work with the proper design, but you still have to match the dimensional buildup to get the right clearance to the head (1/2 stroke + rod length + comp height + deck clearance = deck height).
You have 2mm extra up-stroke that is pushing the pistons over-deck.
You have three options:
- swap to a 75mm stroke crank
- get new pistons with 2mm less meat between pin and top surface (2mm less comp height. These are generally called EJ20 "stroker pistons".)
- get new (custom) rods that are 2mm shorter (usually not the route people take for various reasons.)
A 2mm thicker headgasket will theoretically work, but I don't think anyone is going to recommend that option.
Concillian is offline   Reply With Quote
Old 08-10-2010, 11:37 PM   #7
Cbgrandtheftauto
Member#: 184977
99 Impreza RS
'13 BRZ
^^Beat me to it while I was reading the thread
this^ or find some shorter rods...I wouldnt trust running a super thick headgasket
Cbgrandtheftauto is offline   Reply With Quote
Old 08-11-2010, 02:27 AM   #8
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
At this point, I'd just buy some stroker pistons if I were you. They aren't totally "custom" anymore. A few companies (I think Wiseco and Mahle, possibly more) make and sell them off-the-shelf. If you do pick them up I think you will like the result. You end up with a very noticeable low-end/midrange torque gain.
CKxx is offline   Reply With Quote
Old 08-11-2010, 03:21 AM   #9
Prevent
Member#: 149114
Mahle makes a EJ20 stroker piston.
SUB193642I16 is the part number
It is .020" over though, however i do think they make a standard bore as well.
Prevent is offline   Reply With Quote
Old 08-11-2010, 10:39 AM   #10
mbandi
Member#: 212393
05 2 Saab 9-2x's
Neither of these companies seem to make a standard bore piston, which is what I would need.
Old 08-11-2010, 11:53 AM   #11
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Did you want stroke pistons? Because that is what you need. You just stumbled upon a fancy engine build. hahahaha
FuJi K is offline   Reply With Quote
Old 08-11-2010, 12:11 PM   #12
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
I hate it when that happens
sense of nature is offline   Reply With Quote
Old 08-11-2010, 12:17 PM   #13
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I should grab a phase1 2.2L crank and stuff that into a phase1 2.5L motor and put simple Eagle rods in there with custom pistons. That will be a nice cheap build!!! lolz!!! There are a handful of them at the local UPULL. If it's a '96 Motor, which has a LARGE combustion chamber just like the EJ257, the motor can be of use for the old skool guys who want a cheap de-stroked motor. lolz
damn these Subaru Legos.....
Old 08-11-2010, 12:28 PM   #14
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
Manley part number 620000C-4 would do what you need. It's their 92.0mm bore 8.5:1 piston that's made for a 79mm stroke. It's an off the shelf piston that should be available now if you were to call manley and order a set. Price for the set (Comes with wrist pins, rings, and wrist pin locks) should be at or less than 525
wrx_driver_2002 is offline   Reply With Quote
Old 08-11-2010, 01:59 PM   #15
korhan
Member#: 103202
09 sti09&00gc8
black&grey
wiseco does 92.00mm stroker pistons check this out
korhan is offline   Reply With Quote
Daishoo; Aquacow; Audiosavvy; all guru's please help!!!! Spec_C Car Audio, Video & Security 54 04-26-2008 04:13 PM
For all the Clutch Guru's, please help. AnthonyC.01 Transmission (AT/MT) & Driveline 1 03-30-2006 10:59 AM
calling all atlanta area residents....please help RS_4U2NV South East Region Forum 1 04-05-2005 12:16 PM
Calling all sway bar Guru's!! I_smoke_hondas Brakes, Steering & Suspension 8 01-23-2004 10:06 PM
Calling all Guru's, please help GboneRS Normally Aspirated Powertrain 10 09-29-2003 01:48 PM
