Old 08-11-2010, 11:16 AM   #1
dman918
Member#: 11202
2009 Infiniti G37X
Prev: 2006 STi with stuff
Default Oil pressure sender unit - which spot's best?
I have a 2006 STI and have a prosport oil pressure gauge I need to hook up. I do have a galley plug if I need it, but I was wondering what the best method is for me to hook this up?
Should I:
A. Go under the alternator
B. Go under the intercooler (requires a relocation kit, correct?)
C. Get a sandwich adapter (I have a Perrin EL header so it should fit?)
Thanks for your help. I'd prefer not to buy more stuff if I don't have to, but I also have a limited set of tools to work on the car.
Mike
dman918 is offline   Reply With Quote
Old 08-11-2010, 11:36 AM   #2
subaru3169
Member#: 55252
* pullup bar *
i think sammich adapters are prone to leak from what i've read
i think it might have been on scoobymods that had a pdf on the A & B locations.. i think from the factory, one was specifically for the oil pressure and one was for the oil temp.. i don't remember which is which though
subaru3169 is offline   Reply With Quote
Old 08-11-2010, 12:05 PM   #3
dman918
Member#: 11202
2009 Infiniti G37X
Thanks for the reply. I know that the stock oil pressure light is connected under the alternator, but I am not sure if that is a good move (just because it's an extra protection in case my gauge ever went out). Also, is it an easier place to get to as compared to under the intercooler?
Old 08-11-2010, 12:09 PM   #4
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Go with the OEM location, it's the idea spot since it's before splits to other galleys. Set your gauge to the OEM minimum for the alarm/light and if it fails, fix it
KillerBMotorsport is offline   Reply With Quote
Old 08-11-2010, 12:21 PM   #5
dman918
Member#: 11202
2009 Infiniti G37X
If I do go in that location, is there anything special needed for install? Galley plug, tools? Is it fairly straightforward (with room to fit the prosport fuel pressure sensor)?
Old 08-11-2010, 01:02 PM   #6
El Guapo
Member#: 234937
2004 STi
20G'd Blue
oil galley under the intercooler. just need to get a plug for the sender unit and spin it on with a crows foot wrench
http://forums.nasioc.com/forums/show...77&postcount=1
El Guapo is offline   Reply With Quote
Old 01-09-2011, 03:03 PM   #7
93V
Member#: 249092
2007 STI Limited
UGM #507/800
what did you end up doing for the sensor? OEM location?
if you swap oil pressure sensors, does it throw a warning light on your dash?
93V is offline   Reply With Quote
Old 01-09-2011, 03:24 PM   #8
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
The switch is ground activated so once you disconnect it the light will never come on, and no codes
If you use a gauge, just make sure to set the minimum pressure alarm/light. I recommend 14psi for OEM block/builds.
Old 01-09-2011, 04:19 PM   #9
wrxl98
Member#: 101244
2003 wrx sportwagon
silver cobb stage 2.5+
The factory oil pressure sending unit can easily be retained by using a tee fitting at the end of a relocation line and extending the factory sensor wire.
I saw in another thread that the factory sensor doesn't activate 'till oil pressure drops to 2 psi. not sure if that is true or not.
wrxl98 is offline   Reply With Quote
Old 01-09-2011, 04:48 PM   #10
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
2.1 psi to be exact.
If you have a gauge with a light/buzzer there's no point in making a T and keeping the OEM gauge. That just adds another point for failure, leaks, etc.
Old 01-09-2011, 08:13 PM   #11
93V
Member#: 249092
2007 STI Limited
UGM #507/800
awesome, thanks. will be using a Defi Racer gauge...so no warning lights but i will keep an eye on it (hence i am getting a gauge to do so).
would the T-fitting situation work? would there be enough room?
thanks again
Old 01-09-2011, 10:18 PM   #12
subaru3169
Member#: 55252
* pullup bar *
if anyone wants an oem oil pressure sender unit, i've got one lying around jic
Old 01-09-2011, 11:29 PM   #13
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I did not know those had no light/buzzer
Old 01-10-2011, 02:23 PM   #14
93V
Member#: 249092
2007 STI Limited
UGM #507/800
Not really a big deal. I bought the gauges so I could pay attention to them...
Another question for you KillerB: If I just unscrew the sensor, it will throw the warning light on the dash? If so, where can I disconnect the electrical harness so that I don't get that. Ideally I would just like to swap sensors and leave the stock one there, but I can completely remove the stock one if I need to in order to keep the light off.
Thanks again,
Chris
Old 01-10-2011, 02:44 PM   #15
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Good point.
If you unscrew and remove the sensor the light will NOT come on. Most people leave the connector dangling or tuck it away in case they want to go back to stock in the future.
Old 01-10-2011, 03:03 PM   #16
93V
Member#: 249092
2007 STI Limited
UGM #507/800
Ok. Still need to clarify haha.
Action 1: Unscrew NPT sensor from block
Action 2: Unplug electrical harness/connection? Where is this?
Or are you saying I only need to perform Action 1 and I can leave the NPT sensor dangling nearby?
Old 01-10-2011, 03:08 PM   #17
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Do #1, then unplug the sensor from the wire (it's just a single wire). Put sensor with the rest of your unused Suby stuff and tuck the now un-used connector out of sight.
Old 01-10-2011, 03:10 PM   #18
93V
Member#: 249092
2007 STI Limited
UGM #507/800
ohhhh...there is an electrical connection RIGHT ON the pressure sensor...now I follow. as long as I don't have to cut anything such that it is permanent, i'll do it.
Old 01-10-2011, 03:45 PM   #19
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
No cutting, just unplugging
Old 01-13-2011, 07:26 AM   #20
93V
Member#: 249092
2007 STI Limited
UGM #507/800
did this yesterday. had to temporarily disconnect the alternator but overall it was fairly easy. i used a socket to remove the stock sensor and was able to use an open-end wrench to tighten the new one. hardest part was getting the alternator back in haha.
thanks!
Old 02-15-2011, 07:06 PM   #21
Supraru
Member#: 23313
99' 2.5Rs
black
Recently bought the prosport 60mm gauges. Boost/egt/and oil pressure. Went to install last night and for one the sender seemed a little tight going into the stock location so I decided against doing it. Moved onto the boost gauge and realized id didn't really seem like there was enough wire to reach my defi gauge pod. Anyone have to lengthen their wires to be able to run to a defi gauge pod? Not really a huge deal just thought since that is one of the biggest locations for gauges in subaru's they would have wires long enough to reach. Advance auto didn't have that thin of wire to get some last minute so I bagged the whole project. haha
Supraru is offline   Reply With Quote
WTB : Wtb: oil pressure sender unit coqui2004miguel AKIC Private Classifieds 0 06-28-2010 11:59 PM
Prosport Premium Gauges 52mm Oil Pressure and Temp Remote Oil Pressure Sender Kit skribblez32 Interior/Dressup/Audio & Security 4 07-01-2009 03:50 PM
WTB: Oil filter sandwich adapter, or gallery plug for oil pressure sender psyber_0ptix Mid Atlantic Impreza Club -- MAIC 9 12-11-2005 02:26 PM
Help!, Oil pressure sender unit. Correct size? STR8OUT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-30-2002 01:34 PM
Which oil pressure sender? QA Guy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 02-21-2002 01:58 PM
