#1 |
Member#: 235589
International
Vehicle:1997 LGT Navy Blue |
Ok well first off i wanna start by saying good afternoon everyone and here is my question: My car is a 1.8l so if i used the phase 1 2.5l block will it work (keeping it n/a of course) and if so will it be street driveable ? I know its probably a stupid question but im still getting used to subaru's and thats the only reason why i asked.
#2 |
Member#: 136396
Vehicle:2012 wrx white |
Yeah it will definitely work! You can swap in just about any newer subaru motor and it will bolt up no problem! You'll likely have to do some custom wiring and other misc things but fitment and reliability are as good as you make it!
Mike |
#3 | |
Member#: 41986
NWIC
Vehicle:'06 STI/'85 Brat |
If I understand correctly, you're a good candidate for a high compression Frankenstein motor using your 1.8 heads on the 2.5 block. Search for the big-ass thread about it and see if it's right for you.Jacob |
#4 |
Member#: 5218
Vehicle:96L Most Over- Developed Beater |
I've done this.....not with the EJ18 heads, but with an EJ25D longblock mated with an old EJ20G manifold running on the stock EJ18 ECU.
Your compression ratio will be pretty high, but drivable on pump gas. Search for the "hi-compression frankenstein" thread and you'll get a ton of great info to answer any questions you might have. Have fun! Jay |
#5 | |
Member#: 41986
NWIC
Jacob |
#6 |
Member#: 235589
International
ok so im thinking 2.2 heads phase 1 from an earlier legacy on a 2.5l phase 1 block with the 2.2 intake and all that stuff but what power numbers am i looking at n/a all stock just the 2.2 heads on the 2.5 block ?
#7 | |
Member#: 41986
NWIC
![]() Jacob |
#8 |
Member#: 235589
International
well i have the 2.2 in the car and just had it freshened up which is why i suggested the 2.2 stuff vs the 1.8 stuff id have to get freshened up.
#9 |
Member#: 5218
The experts have chimed in.......years ago.
In the hi-compression frankenstein thread...... Cliffnotes: EJ18 heads on a EJ25 bottom end will give you about 11.5:1 CR. Still runnable on pump gas, premium maybe....but nothing wild. Power level? not sure but likely in the mid 140's. EJ22 heads on a EJ25 bottom end will give you about 11.1:1 CR. Power level has been posted around 150-155. I may be off on the numbers, it's been years since I read the thread. Jay |
#10 | |
Member#: 41986
NWIC
![]() 97gtguy: It looks like you got what you wanted, so good luck with the build ![]() Jacob |
#11 |
Member#: 235589
International
yes sir thank you guys for your help and hopefully soon ill be reporting with good news as the car is being delivered to me and will be here in about 10-15 minutes.
| Thread Tools | |
| Display Modes | |
| Question about re-assembling an engine... | RBT-Rex | Factory 2.0L Turbo Powertrain | 1 | 07-10-2010 07:09 AM |
| Really retarded question about putting a HDD through an x-ray machine | i_c_the_light | Off-Topic | 22 | 12-02-2009 09:39 PM |
| I'm putting together an Atlanta meet! | 2pt5RS | South East Region Forum | 107 | 12-31-2003 01:30 PM |
| Have you ever had to put a little animal out of its misery? | kevinsUBARU | Off-Topic | 38 | 06-06-2003 04:38 PM |
| Should we put together an info/recruiting packet? | Red-Imp | South West Impreza Club Forum -- SWIC | 14 | 11-01-2000 05:30 PM |
