Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Motorsports Specific Items
Old 08-12-2010, 05:40 AM   #1
birdman.1
Member#: 203611
2003 WRX
World Rally Blue
Default More for sale from the shop close out
Alright here goes a list of parts and there asking prices:
JDM Dash Cluster 100
STI Pink Injectors 350
Radiator, Fans,Shroud 175
top mount huge IC 150
Carbon Hood and Trunk 02-03 Vis 500 ea or 900 both
turbo has a price reduction, 480
redline oil pack 145
Axels front 5x100 hubs 80ea
Headlights JDM Styled 200
D2 Brakes front and rear 5x100 5000
Block heater plug in OEM 40
Diff cover 75
Headers 200
Full SS catless exhaust 500
4 wheel bearing rebuild w seals 200
up pipe 75
prodrive mud flaps 180
hoses, rad 150 turbo inlet 200
full samco hose kit(small hoses) blue 150
Oil cooler and relocate kit 280
Fuel rail Agency Power 300
APS tumbler deletes 330
STI Key 25
Okada Plasma Direct, Pack 690 Coil 290 total 950 both for 02-03
There are not pics of a lot of this stuff but i could if they are really needed.
birdman.1 is offline   Reply With Quote
Old 08-12-2010, 10:00 AM   #2
elawson
Member#: 254565
Default headlights
Are the headlights for 02-03??
elawson is offline   Reply With Quote
Old 08-12-2010, 10:22 AM   #3
Mechie3
Member#: 120152
More info on the oil cooler/relocate kit. Brand? Fitting Sizes? Pics?
Mechie3 is offline   Reply With Quote
Old 08-12-2010, 01:23 PM   #4
mattruk
Member#: 245408
99 STI RA
APS tumbler deletes. Are these for the 8 injector set up? Top feed? can you pm me some pics please
mattruk is offline   Reply With Quote
Old 08-12-2010, 01:36 PM   #5
birdman.1
Member#: 203611
2003 WRX
World Rally Blue
Head lights 02-03
Oil cooler relocate kit takes a sandwich plate on the stock oil filter location and allows you to mount the cooler wherever you want. It has the ability to be cut and moved anywhere. I don't remember what brand it is but i bought it in japan personally.
APS tumbler Deletes are for 8 injector set up.May take me a day or so to get the pic but if you go on rallysport direct you can seen them and all the info and specs
Old 08-12-2010, 01:53 PM   #6
birdman.1
Member#: 203611
2003 WRX
World Rally Blue
Heres the info on the APS tumbler Deletes:
The bolt on APS Tumbler Valve Delete Housing is a precision machined aluminium housing that replaces the stock Subaru component (which mounts between the cylinder head and the intake manifold/throttle body assembly) - and dramatically reduces the restriction between the throttle body and the inlet valves at high horsepower levels.
Also included in the APS Tumbler Delete system are two precision manufactured Throttle Position/Servo couplings. These components are mandatory for continued correct operation of the tumble control drive/feedback system. Without these components, the engine management system will detect a tumbler valve malfunction.
With plenty of room to grow your fuel system, this innovative component not only houses the stock WRX or STI injectors, but also has provision for 4 auxiliary Bosch style injectors for high horsepower applications. Thus providing the WRX performance enthusiast with the best possible drivability offered by the stock injectors and allows for the additional auxiliary injectors to be utilized only when needed at high power levels.
The auxiliary injectors can be mapped by most aftermarket engine management systems across the entire RPM range.
This kit does NOT include Servo Plates, Only Tumbler Delete Housing Included. Requires Additional Tuning.
Old 08-12-2010, 03:09 PM   #7
Geek Guy
Member#: 8151
2002 WRX Rally Car
Atlantic Rally Cup Champ!
Which JDM cluster? PM me some pics or details.
thanks,
-E
Geek Guy is offline   Reply With Quote
Old 08-12-2010, 03:57 PM   #8
buzzword
Member#: 123353
2006 AW STi
FLI tuned - [email protected]
pics of topmount?
buzzword is offline   Reply With Quote
Old 08-12-2010, 05:01 PM   #9
240sxsexy
Member#: 222487
What brand radiator shroud do you have?
240sxsexy is offline   Reply With Quote
Old 08-12-2010, 07:28 PM   #10
birdman.1
Member#: 203611
2003 WRX
World Rally Blue
I don't have a pic of the top mount but it is larger than stock STi and comes with Fittings and Hose.
The Radiator is a CX Racing I think, it has the dual fans and aluminum shroud and the Rad of course.
Old 08-13-2010, 12:03 PM   #11
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
pm sent on bearings
rjrutzky is offline   Reply With Quote
Old 08-13-2010, 03:09 PM   #12
haro15
Member#: 109135
2004 subaru wrx sti
NOT FACTORY
More Info On The Jdm Cluster???
haro15 is offline   Reply With Quote
Old 08-13-2010, 05:48 PM   #13
mattruk
Member#: 245408
99 STI RA
put some pics up
Old 08-14-2010, 02:08 AM   #14
birdman.1
Member#: 203611
2003 WRX
World Rally Blue
JDM cluster is sold
Old 08-24-2010, 11:20 AM   #15
birdman.1
Member#: 203611
2003 WRX
World Rally Blue
Lots of great stuff still for sale.
Old 08-31-2010, 05:19 PM   #16
benit0
Member#: 202204
02 WRX
still have the bearings?
benit0 is offline   Reply With Quote
Old 09-02-2010, 01:07 AM   #17
birdman.1
Member#: 203611
2003 WRX
World Rally Blue
bearings are sold
general cost for 500hp build? DIRTWRX Built Motor Discussion 56 02-24-2016 10:51 PM
exhaust flanges for custom exhaust kbobomber89 Newbies & FAQs 3 12-17-2010 08:54 PM
