Closed Thread
Old 08-12-2010, 08:22 AM   #1
polarisboy385
Member#: 222041
2009 Impreza 2.5i
PRP
Default help, (ok ive double posted sorry mods)
this is a double post i know, so shutup about it
Ok so I want to start off by saying I've nnever had good luck with electrical..... that's all of that you need to know.
Here's the problem.....
I installed an old head unit I had in my truck into my subie, it was a good deck in the amount of power it delivered for the price so I kept it,
I made a flow chart of all the wires I needed to connect to what wires to do it properly. But I guess while driving over some contruction work and choppy road some of the wires came loose (once again I'm horrible at electrical work) I was listening to the radio today, and I heard a pop, the deck turned off and so did my clock and interior lights as well as my keyless entry.
So I figured I blew a fuse.. replaced the illumination fuse....... still didn't work..... I'm stuck
My buddy says it might have been a relay too.. what do you guys think it is?
i also looked under the hood in the engine bay fuse box and found the stereo fuse, not blown
i looked at the acc fuse and its not blown either
im really in a pickle
polarisboy385 is offline
Old 08-12-2010, 11:31 AM   #2
polarisboy385
Member#: 222041
2009 Impreza 2.5i
PRP
any suggestions are extremely appreciated, any sort of shot in the dark on what you think it would be
Old 08-12-2010, 10:55 PM   #3
Henry H
Member#: 184330
2008 Impreza 2.5i
Dark Grey Metallic
First off, let this be a lesson to you on doing your connections properly, soldering is the way to go. But if you crimp, you better pull on the connection to make sure it does not come loose. Then wrap up the wires with wire loom to protect the wires from abrasion.
After you fixed your radio wires, move on to the fuses. Sounds like you have a short. Relays don't go out as often so you're still probably looking at a fuse. Not sure why your lights, clock and keyless were tied in but you have to check those fuses first. I believe the lights and the clock are tied together so check the interior lights fuse. If your radio is still not on, then there is probably another fuse on the back of your radio.
Your radio should have its own fused power source. If you can't find it, run your own wire from the battery to your radio and fuse the wire closest to the battery.
Henry H is offline
Old 08-13-2010, 06:19 AM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Please do not crosspost.
Mulder is offline
Closed Thread
Double post sorry Team Scream SCIC Private Classifieds 0 05-05-2010 09:00 PM
double post sorry nova15566 Engine/Power/Exhaust 0 06-10-2007 08:48 PM
Double post. Sorry BlackedOut REX Tire & Wheel 0 04-14-2006 06:47 PM
double post.. sorry. Repsoul Member's Car Gallery 1 01-26-2006 05:26 PM
