Old 08-12-2010, 02:42 PM   #1
havoc2005
Member#: 248626
Default Power shut off for a brief second while driving
Has anyone experienced an issue where the whole power in the car shuts off for a brief second while you are driving. I was driving to work this morning several times the power shut off, headlights, radio, and any other electrical components. I was still driving, the car itself did not shut off. I've been having issues since I installed my fogs. Occasionally the car doesnt turn on and I have to pop the hood and wiggle the negative terminal. Could a bad terminal wire cause the issue stated above even though the car is already running?
havoc2005 is offline   Reply With Quote
Old 08-12-2010, 09:20 PM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
The battery connections should be snug enough they don't turn when pushed on. I suggest you clean the battery connections and tighten them correctly. If that doesn't solve the trouble then there may be an ignition switch problem.
After a long drive and shut off for 10 minutes, wouldn't start afterwards... elitescouter Newbies & FAQs 4 03-14-2010 01:24 AM
car shuts off while driving reeksti Service & Maintenance 5 03-07-2006 11:40 AM
Car shuts off while driving (post for a friend) BlueTDimly Normally Aspirated Powertrain 4 12-30-2002 12:25 PM
Engine shut off while driving I drive a WRX wagon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 04-10-2002 03:51 PM
car shuts off while driving.... sethiscope Service & Maintenance 3 03-11-2002 03:36 PM
