Old 08-12-2010, 09:48 PM   #1
ChrisII
Member#: 94381
Default weird turn signal problem, they keeps on
HI, as the title said, the turn signals keeping on all the time when I turn it on, whatever which side it is. I checked the bulbs, all works perfectly. Also, I pressed the Harzard button and the same problem comes out. Anyone have experienced this before and any resolution of it?
ChrisII is offline   Reply With Quote
Old 08-14-2010, 02:09 PM   #2
riffraff
Member#: 244244
1995 impreza
primer black
bump got the same problem
riffraff is offline   Reply With Quote
Old 08-15-2010, 01:52 AM   #3
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
I suspect there is a problem with the switch itself.
Old 12-20-2010, 07:27 AM   #4
Mirko
Member#: 164368
Mirko is offline   Reply With Quote
Old 12-20-2010, 09:24 PM   #5
Cougar4
Member#: 53443
Winestone
If you guys are saying the the lights don't pulse on and off when you use the turn signals then the flasher unit needs to be checked.
Weird turn signal dinging? wrxgirlie Electrical & Lighting 3 09-11-2007 12:05 AM
Cleared Headlight Turn signal Problem.. urabusXRW Electrical & Lighting 2 01-24-2006 10:22 AM
I've got LED turn signal problems chrisarella Interior & Exterior Modification 6 07-23-2005 02:19 PM
Tai light / turn signal problem, Help... WRXplatinum Electrical & Lighting 1 07-07-2005 09:50 AM
Turn signal problems...some help Herojin Electrical & Lighting 10 09-28-2004 06:50 PM
