Old 08-12-2010, 10:08 PM   #1
turboed22
Member#: 93364
1998 '98 Impreza RST
'14 BRZ
Default Tachometer Signal/Testing
My standalone ECU is running a 36-2-2-2 trigger wheel but my factory cluster's tach is wired for a 6/7 trigger wheel so I have a problem because the factory ECU is not seeing an engine speed, therefore not sending the proper waveform signal to the needle motor in the cluster. Is there a way to get the waveform signal from the coil or anything else to get the factory tach needle to work?
Car is a 1998 2.5RS with a megasquirt ECU. I actually had the tach working for a test setup but I cannot seem to get it working again.
Is there a way to test the needle motor to see if it is burned out?
turboed22 is offline   Reply With Quote
Old 06-30-2011, 07:23 AM   #2
TheAznal
Member#: 287036
Hi,
I'm having a similar issue as you describe... I have a standalone ECU that reads from a 36-2-2-2 wheel and cant get the factory tach to work anymore.
I was under the impression it might be from an inline "pickup or holdup" device that would alter the voltage between the ECU and tach... but cant seem to locate it. Any other thoughts?
Thanks,
Adrian
'92 legacy turbo
TheAznal is offline   Reply With Quote
weird turn signal problem, they keeps on ChrisII Electrical & Lighting 4 12-20-2010 09:24 PM
Wanted: 2011 STi sedan for exhaust testing AQ Motorsports Southern California Impreza Club Forum -- SCIC 20 08-25-2010 12:53 AM
AM signal issue bozbot Car Audio, Video & Security 7 08-13-2010 02:21 PM
MSI to begin testing with Redline Oils MSI Press Releases 0 08-12-2010 10:32 AM
7k RPM tachometer to 8k RPM tachometer swap - any idea what's involved? Patrick Olsen Subaru Conversions 8 08-04-2007 10:05 AM
