Old 08-13-2010, 11:01 AM   #1
fatso
Member#: 227527
2005 WRX
Default Weird starting issue.
This morning while driving to work a cop decided to pull me over and told me to shut off the engine. When I got rid of the cop. I tried to turn the engine on but nothing happened, the engine didn't even cranked, my WRX was downhill so I decided to let it go and release the clutch as soon as I caught speed the engine started perfectly. I went driving back home and tried to start the car and it worked.
Anyone have a guess of what could've have happened?
Thanks in advance.
fatso is offline   Reply With Quote
Old 08-13-2010, 12:01 PM   #2
mostasteless
Member#: 52631
2004 WRX
Had a similar problem a while back. The car would always start up if it had been sitting for a couple hours but if I drove it for about 10 minutes, turn off the car and tried to restart it 50% of the time it would crank but not start and the rest I would get nothing. If I let it sit for about 15 min it would start again. Swapped the battery and haven't had a problem since.
mostasteless is offline   Reply With Quote
Old 08-13-2010, 12:21 PM   #3
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
The trouble could be with the battery but it it could be other things also like bad battery connections. I suggest you first clean the connections and make sure they are snug tightened to the posts, not overtight, which will stretch the connector. If that doesn't help have the battery checked out doing a load test on it.
Old 08-13-2010, 02:22 PM   #4
fatso
Member#: 227527
2005 WRX
You guys hit on target.
Battery was dying. Just bought a Optima Gel Battery and problem fixed.
Thanks!
Old 08-13-2010, 04:06 PM   #5
Cougar4
Member#: 53443
Winestone
Glad to hear you got the trouble solved. Thanks for the feedback.
Old 08-14-2010, 01:03 AM   #6
fatso
Member#: 227527
2005 WRX
Here are the results.......( Weird considering the battery didn't gave any symptoms of going down)
Newbie with a weird starting issue - 2002 OBS Surestick Newbies & FAQs 2 12-04-2008 01:42 PM
Weird fueling issue. Not enough fuel, add a pump now insanely rich???A/F weirdness. Defiant Autospeed Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 21 11-19-2007 04:30 AM
Weird starting issue WRXSleeper Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-23-2007 01:27 AM
Weird Brake Issues lbk16 Brakes, Steering & Suspension 8 05-04-2001 08:24 PM
Weird alarm issues on my Legacy wagon. gtguy Legacy Forum 0 08-31-2000 10:19 PM
